Originally posted by: edm
Man, I'm really regretting not buying this while it was still in stockhopefully it will come back.
Originally posted by: styrafoam
Got mine up and running today and i really like it, i probably would have paid full price for it had i known how nice it was beforehand.
To answer some questions:
All of my fans are on the lowest setting, top fan is off, and the case is nearly silent. Your video card and psu will have a large effect on this, but the case itsself is very quiet on low. I can hear my hdd access over the fan noise, just a plane old 7200rpm WD.
HDD racks are moveable, each of the 2 racks has room for 3 hdd's. Racks fasten with thumbscrews, and are pulled forward out of the case for service. There are 3 positions for the 2 fan/hdd racks, which ever postion is unoccupied by a rack will be where you mount your optical drives.
None of the fans have filters.
If your power supply has what might be considered a short atx or 12v cpu plug lines there is a good chance that they wont reach your motherboard as the power supply mounts in the bottom/rear of the case. I need to pick up an extension for my 12v line, the fit is tight enough to bother me.
Originally posted by: SuPrEIVIE
this case seems very good and at this price there is no question to get it, but a few months ago i got the P180 from frys and it seems to be less vulnerable to dust than this case, the 900 has way to many holes, shouldnt dust be a huge problem with this case?
Ya I felt exactly the same way when I got it for $115 after $25 MIR. I was really glad I got it after CompUSA did a $50 IR 2 weeks later and I was able to price adjust.Originally posted by: styrafoam
ALl you really need to do is take a compressed air can to it.
I don't quite see what the issue would be. It's a very open case with lots of airflow.
is V1.1 the newest one out ?
That's what I received today
Originally posted by: chizow
Those interested in this case for a new case build and care about cabling/airflow/aesthetics:
a modular PSU with braided wires goes a long way. My wiring is pretty tidy but there's tons of unused wires coming out of my TP-650W and they're not braided so it looks a bit messy. If I knew I was moving into this case I would've spent the extra $50 or so for a modular case with tidy wires.
Originally posted by: blacklit
does this get loud with all those fans?
... and
- are the hd cages removable?
- does it have fan filters?
thanks ~
I've got a modular PS with braided wires and believe me when I say it doesn't help much. In my case I've got the following power leads:
1 x 4-pin MB power
1 x 4-pin MB power
4 x fan power (5 with optional side)
2 x Optical drives
3 x Hard drives
2 x Video
All of that fit pretty 'clean' in my Sonata. Inside the 900 it's a jumbled mess. This case moves a bunch of air but easy to work in it isn't.
