Originally posted by: isekii
Is there any way to disable the LED's on the fan ?
last thing Iwant is a riced out computer box
You can with a pair of wire cutters
Otherwise you can replace them with non-LED fans with a bit of work. The ones embedded in the drive cages are set in there pretty good with the wires tucked. I didn't look that closely when installing them but it wouldn't be as simple as just removing 4 screws. The back one is easily replaced. Either way, you should be able to sell the 3 old fans for at least as much as you paid for the replacements.
As for noise, I guess its relative but I was extremely surprised by how quiet everything runs. The reason I looked for a case like this to begin with was because of how quiet my Thermaltake Typhoon and Trio's PSU 120mm were. The 5 x 120mms added from this case are slightly louder than the Typhoon's 120mm, but my WD Raptor X is the loudest component in my case by far.
