Antarctic Sea Ice Hits Record Low
Roger Wilco
4,822
7,233
The clock keeps ticking.
"The January 2023 Antarctic sea ice extent hit a record low for January at 1.25 million square miles, which is about 700,000 square miles below the 1991-2020 average. This January’s extent was roughly 210,000 square miles smaller than the previous record low from January 2017."
Reactions: Captante and Pohemi
Franz316
1,026
551
Arctic ice also in awful shape for this time of year. Given the high winter temps we've already seen, this year is going to be a scorcher. Only to be beaten by next year's scorcher. Would hate to be the people born today.
Reactions: Roger Wilco
Jaskalas
35,947
10,286
Next time it snows, I'll make a snowball and show it to Congress. Cold is still Cold, no denying that. It's called science, bitches!
Me Ape. Me Smart.
*pounds chest
Reactions: Pohemi
dawp
11,347
2,710
Fascism will solve everything. Trump supporters will get air conditioners.
more like swamp coolers
well the see level will need to rise a bit over 200ft to submerge florida's capital of Tallahassee.
SMOGZINN
14,359
4,640
When sea ice melts, it has no effect on sea level. When the ice on land melts and runs into the ocean, then sea level will rise.
As far as know that would only be true if the water was evenly distributed across the planet, but it is not. The ice at the poles represents a lot of water sequestered so that it can't move around. Add it back as liquid and the tides will become more extreme. We are already seeing this happening.
Reactions: hal2kilo
Paratus
17,691
15,939
Yes and no. Sea level rise occurs due to melting ice from land but also from the thermal expansion of water as it warms.
The biggest issue with floating Antarctica ice is it’s holding back a lot of land ice. If enough melts and breaks off it will allow enough land ice to flow into the ocean to significantly raise sea level. As it warms it will thermally expand making things even worse.
MtnMan
9,437
8,843
Water expands when it freezes, and that's why it floats. Ice floating displaces the exact same amount of water as it contains.
Does your iced tea glass overflow when the ice melts?
MtnMan
9,437
8,843
Ice floating in a body of water displaces exactly the same amount of water that it contains. Ice is less dense than liquid water, thus it floats.
Roger Wilco
4,822
7,233
Sea ice also reflects a lot of sunlight. The absence of ice allows the oceans to absorb more solar energy, thus further contributing to warming.
Reactions: hal2kilo
MtnMan
9,437
8,843
I wasn't saying that the melting ice isn't alarming, my point was to those that think that melting sea ice will raise sea level.
fskimospy
55,594
Roger Wilco
4,822
7,233
As others have said, thermal expansion is a direct result of melting sea ice.
Indirectly, warmer oceans will make a warmer planet, and a warmer planet will melt land ice quicker.
Reactions: hal2kilo
SMOGZINN
14,359
4,640
I was not talking about displacement, I was talking about tidal movement of water. Ice barely moves at all due to gravitational tides (at least on Earth) water moves a lot. Change a significant volume of solid water to liquid and you get more extreme tides, and thus costal flooding even without any extra displacement.
thilanliyan
12,065
2,278
Liquid water expands when heated. It's miniscule in your cup for example, but make it an ocean and it will probably make a difference.
