Originally posted by: Duvie
Seems pretty good.....
Gaming looks better but ofcourse AT used high res but turned off all AA and AF...so not comparable to other sites....
I see great ocing but nowhere do they list the temps they got...It maybe th efact they are running the Asus i975x mobo that is widely considered to be off 15-20 degrees....
I also learned something the X6800 is the only cpu with totally unlocked multis...can you say like the FX of AMD???
We weren't GPU limited though, thus it's more of a CPU test. If you're GPU limited, it's kinda pointless to see those benches. It's like turning v-sync on..
well ofcourse the other sites are using like 4xAA and 8xAF...you dont match their numbers....
You should have ran the 640x480 numbers for cpu test and then ran moderate gaming settings with 1280x1032 with no AA and then 1600x1200 with AA for the heavy gamers...
You would have been gpu limited had you tested it that way...if you dont think so then just look at almost a half dozen of th esites that have done reviews showing this....
The 2.4GHz E6600, which outperformed the FX-62 in most benchmarks at stock speed costs $223
Originally posted by: DaveSimmons
That's 2 articles (AT, HardOCP) saying power consumption of Core 2 under load power is only a little below X2's, so it looks like TechReport's numbers are the wrong ones.
Still, much faster while using 6-10 watts less puts them ahead in every area including power consumption.
The 35 watt AMD X2 3800+ also looks like a nice part for mini machines, since all 3 reviews show it using at least 40 watts less under load. That is if they every actually ship any to more than review sites.
Originally posted by: theteamaqua
oh yeah words on the street is that AMD's 4x4 is not going so well. hicookie in xs said that early benchies r not looking well, but im pretty sure they'll find a way around it
if u have air cooling get E6700, E6600 .. X6800 is simply too hot, at stock its power cunsumption is like 90w compare to E6700's 65w. its good for oc b/c when using ln2, phase (whch i dont rust, air never fails, never make any mistake and its there forever) it has unlucked multi and that really helps to get to say 5.2GHz by coolaler 9.7 sec pi 1m
Originally posted by: pacho108
the board used for the intel test system, is it compatible with both crossfire and sli?
im asking because according to compgeek's benches he used that board with 2x7900gt's
Ah, thanks for clearing that up, I skimmed past the motherboard details to get to the charts 🙂Originally posted by: coldpower27
No TechReports are correct, if you read the article you would have noticed that Anandtech uses ATI RD580 chipset which is more efficient in the power department then the nForce 590 SLI that Techreport uses.Originally posted by: DaveSimmons
