Originally posted by: spam
-It is wrong as has been said, when no published drivers are used to establish a base line of performance.
Again, arguable, but OK. Also, should we really use publicly available drivers on a card that isn't publicly available (NV38)? Remember, Det 50 will be shipping with NV38.
-It is wrong because you are making a category mistake, you are comparing apples to oranges. A beta game is not comparable to beta drivers in the context of this hardware review. Drivers are used universally in all tests. HL2 is one test among many. If you had used a published driver in addition to the beta's all would be fine. It would give a more balanced review of the hardware.
Yes, it would. Problem is, many people may not be using 45.23 drivers with NV38. AFAIK, 52.14 is very close to the final WHQL driver that will ship with NV38.
-You disagreed with the possiblity that it would be withdrawn or never published. You have disputed the history of withdrawn beta drivers but as the above link in this thread shows, it is tactic that has been used in the past. What do you think of the withdrawal of the Laura Croft AOD benchmark?-Why did Nvidia pressure its business partner to withdraw it? Why was LC AOD benchmark not used?
Not sure what you're referring to here.
-HL2 was included in the bundle. The reason you would test it is that it would be a critical factor in whether the public would purchase the card or not.
Same can be said about the 52 series drivers. Fact is, it's more important to look at many different games than it is many different driver sets. You should really wait for the verdict on these new drivers before condemning them. If they turn out to be poor like the 51 series, then you have a point.
-finally your argument contradicts itself . If you use Beta drivers then it is alright to test with a beta game!!!!- but you did not do that so you invalidate you own argument. Stating it in it's negative corollory If it is not right to test with Beta games then it is not right to test with Beta drivers.
I don't see how I said that anywhere. In fact, I'm now not quite sure if what you said makes any sense.
Sazar, I think I answered some of your points above. Though, it's clear I'm not going to change your opinion on this situation. We've already mentioned on several occasions that the HL2 blog numbers have to be taken with a grain of salt. What more can be said to not make those numbers misleading?
