AMD X2 / Pentium D & AutoGK DivX Encoding
Your compressibility is waaaaayyyy off 99% versus his 32%...notice you missed the target 1400mb or 2 cds...Looks like 3 cds which menat the file ended up being larger as well....
I am running it again right now. Something strange is going on, it's been extremely inconsistent. It's been running for 40 minutes on the first pass and is only 54% of the way done.
Technonut do you have the widescreen version or the full screen version? I have the widescreen, if you have full screen thats probably part of my problem. I had to change a setting to get 528x224 as it was doing 720x320 on auto.
Thanks for taking the time to do the runs stevty2889.... 🙂
When I ran AutoGK, I just pretty much followed the linked guide to the letter, using those settings.... ( most everything "auto" 😉 ) I have not fooled with AutoGK much myself. I thought it would be interesting to see actual benchmarks from others on this forum instead of quick ones done from reviews on other sites.
I still need to list some different DVDs to try. I would like to see more results from other X2 rigs @ different OC's.
EDIT: stevty2889: I also have the widescreen version. Did you follow the DVD Decrypter settings to use in the guide?
I follwed the DVD decryptor settings exactly as they were in the guide, and the AGK settings as well, but it set mine to 720x320 for some reason, I un-installed and re-installed everything, gonna try again and see if it makes a differance. I missed "--- When you get to the part about additional tasks, we recommend that you
DO NOT check the ?Decode All Supported 4CCs?? box, as it is better to have DivX decode DivX, Xvid to decode XviD, etc." the first time I installed, so maybe that was part of the problem. I re-installed with that box un-checked, I'll see how the results come out this time.
OK, ran it again after re-installing.
[8/21/2005 9:08:24 PM] AutoGK 1.96
[8/21/2005 9:08:24 PM] Job started.
[8/21/2005 9:08:24 PM] Input dir: C:\FELLOWSHIP\VIDEO_TS
[8/21/2005 9:08:24 PM] Output file: C:\FELLOWSHIP\VIDEO_TS.avi
[8/21/2005 9:08:24 PM] Audio: English
[8/21/2005 9:08:24 PM] Subtitles: none
[8/21/2005 9:08:24 PM] Codec: DivX
[8/21/2005 9:08:24 PM] Target size: 1400Mb
[8/21/2005 9:08:24 PM] Started encoding.
[8/21/2005 9:08:24 PM] Demuxing and indexing.
[8/21/2005 9:10:56 PM] Target bitrate is: 643kbps
[8/21/2005 9:10:56 PM] Running compressibility test.
[8/21/2005 9:13:28 PM] Duration was: 2 minutes 31 seconds
[8/21/2005 9:13:28 PM] Speed was: 84.53 fps.
[8/21/2005 9:13:28 PM] Compressibility percentage is: 42.42
[8/21/2005 9:13:28 PM] Using softer resizer.
[8/21/2005 9:13:28 PM] Chosen resolution is: 528x224 ( AR: 2.36 )
[8/21/2005 9:13:28 PM] Predicted comptest value is: 45.52
[8/21/2005 9:13:28 PM] Running first pass.
[8/21/2005 9:46:41 PM] Duration was: 33 minutes 12 seconds
[8/21/2005 9:46:41 PM] Speed was: 128.77 fps.
[8/21/2005 9:46:41 PM] Running second pass.
[8/21/2005 10:21:11 PM] Duration was: 34 minutes 29 seconds
[8/21/2005 10:21:11 PM] Speed was: 123.97 fps.
[8/21/2005 10:21:11 PM] Splitting video into: C:\FELLOWSHIP\VIDEO_TS.cd1.avi
[8/21/2005 10:21:58 PM] Splitting video into: C:\FELLOWSHIP\VIDEO_TS.cd2.avi
[8/21/2005 10:22:40 PM] Job finished. Total time: 1 hour, 14 minutes 15 seconds
Also running it on my pentium-m @2.4ghz for the heck of it 57m 57s for the first pass, 26% done with the second pass.
And here's the pentium-m...finaly...
[8/21/2005 9:08:25 PM] AutoGK 1.96
[8/21/2005 9:08:25 PM] OS: WinXP (5.1.2600).2
[8/21/2005 9:08:25 PM] Job started.
[8/21/2005 9:08:25 PM] Input dir: C:\Downloads\DFI\FELLOWSHIP\VIDEO_TS
[8/21/2005 9:08:25 PM] Output file: C:\Downloads\DFI\FELLOWSHIP\VIDEO_TS.avi
[8/21/2005 9:08:25 PM] Audio: English
[8/21/2005 9:08:25 PM] Subtitles: none
[8/21/2005 9:08:25 PM] Codec: DivX
[8/21/2005 9:08:25 PM] Target size: 1400Mb
[8/21/2005 9:08:25 PM] Started encoding.
[8/21/2005 9:08:25 PM] Demuxing and indexing.
[8/21/2005 9:11:20 PM] Target bitrate is: 643kbps
[8/21/2005 9:11:20 PM] Running compressibility test.
[8/21/2005 9:15:10 PM] Duration was: 3 minutes 50 seconds
[8/21/2005 9:15:10 PM] Speed was: 55.74 fps.
[8/21/2005 9:15:11 PM] Compressibility percentage is: 42.42
[8/21/2005 9:15:11 PM] Using softer resizer.
[8/21/2005 9:15:11 PM] Chosen resolution is: 528x224 ( AR: 2.36 )
[8/21/2005 9:15:11 PM] Predicted comptest value is: 45.52
[8/21/2005 9:15:11 PM] Running first pass.
[8/21/2005 10:13:09 PM] Duration was: 57 minutes 57 seconds
[8/21/2005 10:13:09 PM] Speed was: 73.77 fps.
[8/21/2005 10:13:09 PM] Running second pass.
[8/21/2005 11:11:17 PM] Duration was: 58 minutes 7 seconds
[8/21/2005 11:11:17 PM] Speed was: 73.57 fps.
[8/21/2005 11:11:17 PM] Splitting video into: C:\Downloads\DFI\FELLOWSHIP\VIDEO_TS.cd1.avi
[8/21/2005 11:12:06 PM] Splitting video into: C:\Downloads\DFI\FELLOWSHIP\VIDEO_TS.cd2.avi
[8/21/2005 11:12:52 PM] Job finished. Total time: 2 hours 4 minutes 26 seconds
And I am now running again on the X2, but set the affinity so it's only using 1 core, so that should give a close approximation to how it would run on a single core A64 at the same speed.
That is 19% faster then Technonuts P4 rocket....Technonut that is a kick arse P4 you have....I would love to see vapoochill on an X2...You ought to try one....
I will likely try the test ina few days but since I dont have the movie I may have to borrow it from MarkFW900. I am running 4% fastsr then Stet right now but with much faster ram speed. I will laso run it at 2.664ghz for my best time. That is 7.6% faster then stets cpu....Let see if it translate into a linear gain...
Hey Stet can you run the test on the Return of the King movie...I have that one....
Also how do you set it to use an older codec if you have the newer codec installed???
Here's the results I got when setting the affinity to use a single core, 8 minutes faster than the Pentium-M@2.4ghz:
[8/21/2005 11:11:44 PM] AutoGK 1.96
[8/21/2005 11:11:44 PM] OS: WinXP (5.1.2600).2
[8/21/2005 11:11:44 PM] Job started.
[8/21/2005 11:11:44 PM] Input dir: C:\FELLOWSHIP\VIDEO_TS
[8/21/2005 11:11:44 PM] Output file: C:\FELLOWSHIP\VIDEO_TS.avi
[8/21/2005 11:11:44 PM] Audio: English
[8/21/2005 11:11:44 PM] Subtitles: none
[8/21/2005 11:11:44 PM] Codec: DivX
[8/21/2005 11:11:44 PM] Target size: 1400Mb
[8/21/2005 11:11:44 PM] Started encoding.
[8/21/2005 11:11:44 PM] Demuxing and indexing.
[8/21/2005 11:14:04 PM] Source aspect ratio: 16:9
[8/21/2005 11:14:04 PM] Source resolution: 720x480
[8/21/2005 11:14:04 PM] Target bitrate is: 643kbps
[8/21/2005 11:14:04 PM] Running compressibility test.
[8/21/2005 11:17:49 PM] Duration was: 3 minutes 44 seconds
[8/21/2005 11:17:49 PM] Speed was: 57.07 fps.
[8/21/2005 11:17:49 PM] Compressibility percentage is: 42.42
[8/21/2005 11:17:49 PM] Using softer resizer.
[8/21/2005 11:17:49 PM] Chosen resolution is: 528x224 ( AR: 2.36 )
[8/21/2005 11:17:49 PM] Predicted comptest value is: 45.52
[8/21/2005 11:17:49 PM] Running first pass.
[8/22/2005 12:12:11 AM] Duration was: 54 minutes 21 seconds
[8/22/2005 12:12:11 AM] Speed was: 78.66 fps.
[8/22/2005 12:12:11 AM] Running second pass.
[8/22/2005 1:06:36 AM] Duration was: 54 minutes 23 seconds
[8/22/2005 1:06:36 AM] Speed was: 78.61 fps.
[8/22/2005 1:06:36 AM] Splitting video into: C:\FELLOWSHIP\VIDEO_TS.cd1.avi
[8/22/2005 1:07:19 AM] Splitting video into: C:\FELLOWSHIP\VIDEO_TS.cd2.avi
[8/22/2005 1:08:00 AM] Job finished. Total time: 1 hour, 56 minutes 16 seconds
And I do have return of the king, I'll do that one tommorow I am about to fall asleep in my chair..
So 1hr 14min versus 1hr 56min.....
single core 2.475ghz is 31.8% slower then Technonuts P4 4.4ghz
dual core 2.475ghz is 18.9% faster then Technonuts P4 4.4ghz
dual core vs single core at 2.475ghz is 56.7% faster....
It appears to me the Divx codec is OK at SMP but at 56.7% it leaves something to be desired...
I am doing the LOTR-return of the King now with guide setup and then I will run it at single core and then I will run it with the superior (IMO) Xvid codec....
One thing I notice out of the gate is in the 1st pass I am not holding a 100% cpu usage...I am seeing 68-82% a majority of the time...I will take a screenshot....So there appears to be the proof it is not taking advantage of all of the power...
My next test should be run the test again as I continue my downloading and watching a movie and see if my times still hold....
[8/22/2005 2:09:44 AM] AutoGK 1.96
[8/22/2005 2:09:44 AM] OS: WinXP (5.1.2600).2
[8/22/2005 2:09:44 AM] Job started.
[8/22/2005 2:09:44 AM] Input dir: D:\RETURN_OF_THE_KING\VIDEO_TS
[8/22/2005 2:09:44 AM] Output file: C:\test\LOTR-King.avi
[8/22/2005 2:09:44 AM] Audio: English
[8/22/2005 2:09:44 AM] Subtitles: none
[8/22/2005 2:09:44 AM] Codec: DivX
[8/22/2005 2:09:44 AM] Target size: 1400Mb
[8/22/2005 2:09:44 AM] Started encoding.
[8/22/2005 2:09:44 AM] Demuxing and indexing.
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_1.VOB
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_2.VOB
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_3.VOB
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_4.VOB
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_5.VOB
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_6.VOB
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_7.VOB
[8/22/2005 2:13:45 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_8.VOB
[8/22/2005 2:13:45 AM] Source aspect ratio: 16:9
[8/22/2005 2:13:45 AM] Source resolution: 720x480
[8/22/2005 2:13:45 AM] Found NTSC source.
[8/22/2005 2:13:45 AM] Source seems to be pure FILM.
[8/22/2005 2:13:45 AM] Output will contain 289081 frames
[8/22/2005 2:13:45 AM] Audio size: 675,193,344 bytes (643.91 Mb)
[8/22/2005 2:13:45 AM] Overhead: 9,094,912 bytes (8.67 Mb)
[8/22/2005 2:13:45 AM] Video size: 783,718,144 bytes (747.41 Mb)
[8/22/2005 2:13:45 AM] Target bitrate is: 520kbps
[8/22/2005 2:13:45 AM] Running compressibility test.
[8/22/2005 2:16:25 AM] Duration was: 2 minutes 39 seconds
[8/22/2005 2:16:25 AM] Speed was: 90.48 fps.
[8/22/2005 2:16:26 AM] Compressibility percentage is: 19.39
[8/22/2005 2:16:26 AM] Using softer resizer.
[8/22/2005 2:16:26 AM] Chosen resolution is: 416x176 ( AR: 2.36 )
[8/22/2005 2:16:26 AM] Predicted comptest value is: 60.80
[8/22/2005 2:16:26 AM] Running first pass.
[8/22/2005 2:45:49 AM] Duration was: 29 minutes 22 seconds
[8/22/2005 2:45:49 AM] Speed was: 164.02 fps.
[8/22/2005 2:45:49 AM] Running second pass.
[8/22/2005 3:16:21 AM] Duration was: 30 minutes 31 seconds
[8/22/2005 3:16:21 AM] Speed was: 157.82 fps.
[8/22/2005 3:16:21 AM] Splitting video into: C:\test\LOTR-King.cd1.avi
[8/22/2005 3:17:09 AM] Splitting video into: C:\test\LOTR-King.cd2.avi
[8/22/2005 3:17:55 AM] Job finished. Total time: 1 hour, 8 minutes 10 seconds
That is flippin fast from the old days....
Here is some of my usage pics...
CPU usage First Pass
CPU usage 2nd Pass
Starting Xvid test on same file.....
I notice it is more multithreaded as first pass is more like 79-90% cpu usage.....
[8/22/2005 3:27:03 AM] AutoGK 1.96
[8/22/2005 3:27:03 AM] OS: WinXP (5.1.2600).2
[8/22/2005 3:27:03 AM] Job started.
[8/22/2005 3:27:03 AM] Input dir: D:\RETURN_OF_THE_KING\VIDEO_TS
[8/22/2005 3:27:03 AM] Output file: C:\test\LOTR-KingXvid.avi
[8/22/2005 3:27:03 AM] Audio: English
[8/22/2005 3:27:03 AM] Subtitles: none
[8/22/2005 3:27:03 AM] Codec: XviD
[8/22/2005 3:27:03 AM] Target size: 1400Mb
[8/22/2005 3:27:03 AM] Started encoding.
[8/22/2005 3:27:03 AM] Demuxing and indexing.
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_1.VOB
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_2.VOB
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_3.VOB
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_4.VOB
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_5.VOB
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_6.VOB
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_7.VOB
[8/22/2005 3:30:59 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_8.VOB
[8/22/2005 3:30:59 AM] Source aspect ratio: 16:9
[8/22/2005 3:30:59 AM] Source resolution: 720x480
[8/22/2005 3:30:59 AM] Found NTSC source.
[8/22/2005 3:30:59 AM] Source seems to be pure FILM.
[8/22/2005 3:30:59 AM] Output will contain 289081 frames
[8/22/2005 3:30:59 AM] Audio size: 675,193,344 bytes (643.91 Mb)
[8/22/2005 3:30:59 AM] Overhead: 2,009,472 bytes (1.92 Mb)
[8/22/2005 3:30:59 AM] Video size: 790,803,584 bytes (754.17 Mb)
[8/22/2005 3:30:59 AM] Running compressibility test.
[8/22/2005 3:35:29 AM] Duration was: 4 minutes 29 seconds
[8/22/2005 3:35:29 AM] Speed was: 53.61 fps.
[8/22/2005 3:35:29 AM] Compressibility percentage is: 22.34
[8/22/2005 3:35:29 AM] Using softer matrix.
[8/22/2005 3:35:29 AM] Using softer resizer.
[8/22/2005 3:35:29 AM] Chosen resolution is: 528x224 ( AR: 2.36 )
[8/22/2005 3:35:29 AM] Predicted comptest value is: 57.07
[8/22/2005 3:35:29 AM] Running first pass.
[8/22/2005 4:08:30 AM] Duration was: 33 minutes 0 seconds
[8/22/2005 4:08:30 AM] Speed was: 145.96 fps.
[8/22/2005 4:08:30 AM] Expected quality of first pass size: 51.77
[8/22/2005 4:08:30 AM] Running second pass.
[8/22/2005 4:53:29 AM] Duration was: 44 minutes 58 seconds
[8/22/2005 4:53:29 AM] Speed was: 107.12 fps.
[8/22/2005 4:53:29 AM] Splitting video into: C:\test\LOTR-KingXvid.cd1.avi
[8/22/2005 4:54:18 AM] Splitting video into: C:\test\LOTR-KingXvid.cd2.avi
[8/22/2005 4:55:02 AM] Job finished. Total time: 1 hour, 27 minutes 58 seconds
It appears the Xvid codec takes longer but it is rumored to doa better job especially when the source is high quality liek a DVD rip would be...I will have to do some QC tetsing...
CPU usage 1st Pass
the 2nd pass had moments in the 90-99% range but I didn't get a screenshot...
Nice results! 🙂 It is great to see a real-world task benchmarked for a change. 😉 Using LOTR (either Fellowship or ROTK) works well also since they are long movies.
The X2 is indeed very quick....
stevty2889: Job finished. Total time: 1 hour, 14 minutes 15 seconds (Fellowship Of The Ring)
Duvie: Job finished. Total time: 1 hour, 8 minutes 10 seconds :Q (ROTK)
I am picking-up ROTK on Wednesday, and will post results.
You know that I will.... 😉 I have just been holding-out for a mobo designed and optimized for the X2 before I make a move. Who knows though, I may just go ahead and grab a nForce 4 939 mobo and X2 sooner.... 🙂 EDIT: I just happen to have the VapoChill 939 installation kit sitting here gathering dust.... I have not heard of the X2 having the "cold bug" , so it should work....
I noticed the same thing, alought I was staying between about 75-85%. When I ran it on one core, it used 100% of the core.
Probably an IO limitation. If Duvie could come over and help me figure how to run this thing, we could try it on my Opterons w/SCSI. They are the same speed as a stock 4400+, but I get sustained read/write at over 200k, instead of 40-50k on IDE and SATA.
HEY TECHNO....
What really with the difference of Xvid versus Divx?? Notice how my Divx chose a lower resolution...Though I have to admit when I watched them at a drug open size of approx 720 they both looked pretty good...The divx file seemed a little better in color as the Xvid was rather bright,however the Divx I think is not as good in the fast action sequences....
What happened to all the features of sharp, bicubic, etc....No really options for tweaking it seems.....Maybe that is why it is the auto program....less thrills
IO limitation??? Interesting.....I guess that is a possibility when you are pulling 100-160fps or nearly 6-7 times real time (using the forced film 24fps).......
HEY TECHNO....
Personally, I think both codecs turn-out decent backups... Like I said, I have not fooled with AutoGK much. I think that it is great to be able throw a few (or more) movies on a single DVD-R, and have watchable quality.. 🙂 EDIT: I backed-up a 2 hour flick using AGK/DivX, and the quality using the 1 CD (700MB) option was pretty damn good.
I did a couple of XviD runs of LOTR (Fellowship) before, but for some reason it kept re-running the first pass. Still not bad time considering 😉 :
[8/20/2005 1:34:59 PM] Running compressibility test.
[8/20/2005 1:34:59 PM] Writing the following script to E:\loth for xvid\agk_tmp\lotr for_comptest.avs
[8/20/2005 1:39:30 PM] Duration was: 4 minutes 30 seconds
[8/20/2005 1:39:30 PM] Speed was: 47.40 fps.
[8/20/2005 1:39:30 PM] Compressibility percentage is: 29.52
[8/20/2005 1:39:30 PM] Using softer matrix.
[8/20/2005 1:39:30 PM] Using softer resizer.
[8/20/2005 1:39:30 PM] Chosen resolution is: 560x240 ( AR: 2.33 )
[8/20/2005 1:39:30 PM] Predicted comptest value is: 55.86
[8/20/2005 1:39:30 PM] Running first pass.
[8/20/2005 1:39:30 PM] Writing the following script to E:\loth for xvid\agk_tmp\lotr for_movie.avs
[8/20/2005 2:15:06 PM] Duration was: 35 minutes 36 seconds
[8/20/2005 2:15:06 PM] Speed was: 120.09 fps.
[8/20/2005 2:15:07 PM] Expected quality of first pass size: 41.11
[8/20/2005 2:15:07 PM] Trying to adjust settings.
[8/20/2005 2:15:07 PM] Chosen resolution is: 416x176 ( AR: 2.36 )
[8/20/2005 2:15:07 PM] Predicted comptest value is: 75.47
[8/20/2005 2:15:07 PM] Re-running first pass.
[8/20/2005 2:15:07 PM] Writing the following script to E:\loth for xvid\agk_tmp\lotr for_movie.avs
[8/20/2005 2:43:42 PM] Duration was: 28 minutes 35 seconds
[8/20/2005 2:43:42 PM] Speed was: 149.58 fps.
[8/20/2005 2:43:43 PM] Expected quality of first pass size: 67.63
[8/20/2005 2:43:43 PM] Running second pass.
[8/20/2005 3:20:17 PM] Duration was: 36 minutes 34 seconds
[8/20/2005 3:20:17 PM] Speed was: 116.91 fps.
[8/20/2005 3:20:18 PM] Splitting video into: E:\loth for xvid\lotr for.cd1.avi
[8/20/2005 3:21:15 PM] Splitting video into: E:\loth for xvid\lotr for.cd2.avi
[8/20/2005 3:22:11 PM] Job finished. Total time: 1 hour, 49 minutes 39 seconds
I will post my LOTR ROTK times after I pick it up and run it tomorrow......
Here's my ROTK, but since mine was fullscreen rather than wide screen my resolution is differant.
[8/23/2005 3:09:02 PM] AutoGK 1.96
[8/23/2005 3:09:02 PM] OS: WinXP (5.1.2600).2
[8/23/2005 3:09:02 PM] Job started.
[8/23/2005 3:09:02 PM] Input dir: C:\RETURN_OF_THE_KING\VIDEO_TS
[8/23/2005 3:09:02 PM] Output file: C:\RETURN_OF_THE_KING\VIDEO_TS.avi
[8/23/2005 3:09:02 PM] Audio: English
[8/23/2005 3:09:02 PM] Subtitles: none
[8/23/2005 3:09:02 PM] Codec: DivX
[8/23/2005 3:09:02 PM] Target size: 1400Mb
[8/23/2005 3:09:02 PM] Started encoding.
[8/23/2005 3:09:02 PM] Demuxing and indexing.
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_1.VOB
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_2.VOB
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_3.VOB
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_4.VOB
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_5.VOB
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_6.VOB
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_7.VOB
[8/23/2005 3:11:35 PM] Processing file: C:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_PGC_01_8.VOB
[8/23/2005 3:11:35 PM] Source aspect ratio: 4:3
[8/23/2005 3:11:35 PM] Source resolution: 720x480
[8/23/2005 3:11:35 PM] Found NTSC source.
[8/23/2005 3:11:35 PM] Source seems to be pure FILM.
[8/23/2005 3:11:35 PM] Output will contain 289081 frames
[8/23/2005 3:11:35 PM] Using bitrate spikes control.
[8/23/2005 3:11:35 PM] Audio size: 675,193,344 bytes (643.91 Mb)
[8/23/2005 3:11:35 PM] Overhead: 10,518,272 bytes (10.03 Mb)
[8/23/2005 3:11:35 PM] Video size: 782,294,784 bytes (746.05 Mb)
[8/23/2005 3:11:35 PM] Target bitrate is: 519kbps
[8/23/2005 3:11:35 PM] Running compressibility test.
[8/23/2005 3:14:51 PM] Duration was: 3 minutes 15 seconds
[8/23/2005 3:14:51 PM] Speed was: 73.93 fps.
[8/23/2005 3:14:51 PM] Compressibility percentage is: 25.28
[8/23/2005 3:14:51 PM] Using softer resizer.
[8/23/2005 3:14:51 PM] Chosen resolution is: 416x320 ( AR: 1.30 )
[8/23/2005 3:14:51 PM] Predicted comptest value is: 27.12
[8/23/2005 3:14:51 PM] Running first pass.
[8/23/2005 3:54:04 PM] Duration was: 39 minutes 13 seconds
[8/23/2005 3:54:04 PM] Speed was: 122.83 fps.
[8/23/2005 3:54:05 PM] Running second pass.
[8/23/2005 4:34:54 PM] Duration was: 40 minutes 48 seconds
[8/23/2005 4:34:54 PM] Speed was: 118.04 fps.
[8/23/2005 4:34:54 PM] Splitting video into: C:\RETURN_OF_THE_KING\VIDEO_TS.cd1.avi
[8/23/2005 4:35:43 PM] Splitting video into: C:\RETURN_OF_THE_KING\VIDEO_TS.cd2.avi
[8/23/2005 4:36:28 PM] Job finished. Total time: 1 hour, 27 minutes 26 seconds
[8/24/2005 2:26:15 AM] AutoGK 1.96
[8/24/2005 2:26:15 AM] OS: WinXP (5.1.2600).2
[8/24/2005 2:26:15 AM] Job started.
[8/24/2005 2:26:15 AM] Input dir: D:\RETURN_OF_THE_KING\VIDEO_TS
[8/24/2005 2:26:15 AM] Output file: C:\test\LOTR-DIVX.avi
[8/24/2005 2:26:15 AM] Audio: English
[8/24/2005 2:26:15 AM] Subtitles: none
[8/24/2005 2:26:15 AM] Codec: DivX
[8/24/2005 2:26:15 AM] Target size: 1400Mb
[8/24/2005 2:26:15 AM] Started encoding.
[8/24/2005 2:26:15 AM] Demuxing and indexing.
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_1.VOB
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_2.VOB
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_3.VOB
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_4.VOB
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_5.VOB
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_6.VOB
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_7.VOB
[8/24/2005 2:30:11 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_8.VOB
[8/24/2005 2:30:11 AM] Source aspect ratio: 16:9
[8/24/2005 2:30:11 AM] Source resolution: 720x480
[8/24/2005 2:30:11 AM] Found NTSC source.
[8/24/2005 2:30:11 AM] Source seems to be pure FILM.
[8/24/2005 2:30:11 AM] Output will contain 289081 frames
[8/24/2005 2:30:11 AM] Audio size: 675,193,344 bytes (643.91 Mb)
[8/24/2005 2:30:11 AM] Overhead: 9,094,912 bytes (8.67 Mb)
[8/24/2005 2:30:11 AM] Video size: 783,718,144 bytes (747.41 Mb)
[8/24/2005 2:30:11 AM] Target bitrate is: 520kbps
[8/24/2005 2:30:11 AM] Running compressibility test.
[8/24/2005 2:32:46 AM] Duration was: 2 minutes 34 seconds
[8/24/2005 2:32:46 AM] Speed was: 93.62 fps.
[8/24/2005 2:32:46 AM] Compressibility percentage is: 19.39
[8/24/2005 2:32:46 AM] Using softer resizer.
[8/24/2005 2:32:46 AM] Chosen resolution is: 416x176 ( AR: 2.36 )
[8/24/2005 2:32:46 AM] Predicted comptest value is: 60.80
[8/24/2005 2:32:46 AM] Running first pass.
[8/24/2005 3:01:37 AM] Duration was: 28 minutes 50 seconds
[8/24/2005 3:01:37 AM] Speed was: 167.01 fps.
[8/24/2005 3:01:37 AM] Running second pass.
[8/24/2005 3:31:15 AM] Duration was: 29 minutes 37 seconds
[8/24/2005 3:31:15 AM] Speed was: 162.63 fps.
[8/24/2005 3:31:15 AM] Splitting video into: C:\test\LOTR-DIVX.cd1.avi
[8/24/2005 3:32:05 AM] Splitting video into: C:\test\LOTR-DIVX.cd2.avi
[8/24/2005 3:32:52 AM] Job finished. Total time: 1 hour, 6 minutes 37 seconds
This is my time at 2.618ghz....same settings as above...
[8/24/2005 10:23:15 AM] AutoGK 1.96
[8/24/2005 10:23:15 AM] OS: WinXP (5.1.2600).2
[8/24/2005 10:23:15 AM] Job started.
[8/24/2005 10:23:15 AM] Input dir: D:\RETURN_OF_THE_KING\VIDEO_TS
[8/24/2005 10:23:15 AM] Output file: C:\test\LOTR-DIVX3.avi
[8/24/2005 10:23:15 AM] Audio: English
[8/24/2005 10:23:15 AM] Subtitles: none
[8/24/2005 10:23:15 AM] Codec: DivX
[8/24/2005 10:23:15 AM] Target size: 1400Mb
[8/24/2005 10:23:15 AM] Started encoding.
[8/24/2005 10:23:15 AM] Demuxing and indexing.
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_1.VOB
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_2.VOB
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_3.VOB
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_4.VOB
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_5.VOB
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_6.VOB
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_7.VOB
[8/24/2005 10:27:12 AM] Processing file: D:\RETURN_OF_THE_KING\VIDEO_TS\VTS_01_8.VOB
[8/24/2005 10:27:12 AM] Source aspect ratio: 16:9
[8/24/2005 10:27:12 AM] Source resolution: 720x480
[8/24/2005 10:27:12 AM] Found NTSC source.
[8/24/2005 10:27:12 AM] Source seems to be pure FILM.
[8/24/2005 10:27:12 AM] Output will contain 289081 frames
[8/24/2005 10:27:12 AM] Audio size: 675,193,344 bytes (643.91 Mb)
[8/24/2005 10:27:12 AM] Overhead: 9,094,912 bytes (8.67 Mb)
[8/24/2005 10:27:12 AM] Video size: 783,718,144 bytes (747.41 Mb)
[8/24/2005 10:27:12 AM] Target bitrate is: 520kbps
[8/24/2005 10:27:12 AM] Running compressibility test.
[8/24/2005 10:29:45 AM] Duration was: 2 minutes 33 seconds
[8/24/2005 10:29:45 AM] Speed was: 94.15 fps.
[8/24/2005 10:29:46 AM] Compressibility percentage is: 19.39
[8/24/2005 10:29:46 AM] Using softer resizer.
[8/24/2005 10:29:46 AM] Chosen resolution is: 416x176 ( AR: 2.36 )
[8/24/2005 10:29:46 AM] Predicted comptest value is: 60.80
[8/24/2005 10:29:46 AM] Running first pass.
[8/24/2005 10:58:04 AM] Duration was: 28 minutes 18 seconds
[8/24/2005 10:58:04 AM] Speed was: 170.21 fps.
[8/24/2005 10:58:04 AM] Running second pass.
[8/24/2005 11:27:41 AM] Duration was: 29 minutes 36 seconds
[8/24/2005 11:27:41 AM] Speed was: 162.75 fps.
[8/24/2005 11:27:41 AM] Splitting video into: C:\test\LOTR-DIVX3.cd1.avi
[8/24/2005 11:28:28 AM] Splitting video into: C:\test\LOTR-DIVX3.cd2.avi
[8/24/2005 11:29:14 AM] Job finished. Total time: 1 hour, 5 minutes 58 seconds
This was done at 2.664ghz...I tried with 200 divider and tighter timings but it appears it like the bandwidth more then timings...So I ran 233 divider but with cas 3-5-5-10...I tested already before and I dont think I could get my ram to be stable at 3-4-4-8 at this speed. I think it got EEU's in F@h but did not when I tested it at 3-5-5-10...I only have 2.85v to give...
Nice times Duvie... 🙂
I am running AGK ROTK on my primary rig now... Will post results soon.
BTW, OT (My thread though 😉 ) What kind of rip times are you guys getting? On ROTK my Plextor 716-SA did:
Average Read Rate: 8.5x
Maximum Read Rate: 12.0x
Total: 11m 16s
Total: 11m 16s
I have a Liteon 163 and I dont remember seeing a 12x but I did hit 10x but started at around 4x so my average is likley only 7x...That is some nice rip speeds on a dual layer disc.....
I owuld have to go do it again to get something official like yours...Does it keep a log file of it???
