AMD Ryzen 5000 Builders Thread
B-Riz
1,595
765
LikeLinus
11,518
670
Is it correct that the recommended RAM is DDR4 3200? Funny thing, I have 32GB in a machine that is DDR4 3200 and I was thinking about throwing another 32GB. But I may replace the hardware with a 5900x setup. So should I get 3200 or should I get faster RAM? The idea I could use the 64GB until moving it over to a 5900x is available would be nice!
Martimus
4,490
157
AMD kept the same memory controller as Zen 2. In fact the entire IO die is exactly the same die they produce at Global Foundries in order to meet their WSA with them.
Reactions: Mopetar
DrMrLordX
23,223
13,301
The Anandtech article had a blurb on that. "All four processors have the same official memory support at DDR4-3200, and the 105 W TDPs will offer a turbo power of 142 W, which is the same as the current generation Ryzen processors."
Okay. That will help people with builds and power requirements. Thanks for pointing that out (and @Kenmitch). Most VRMs that can hold up to a 3900x or 3950x should be fine for a 5900x.
Zstream
3,395
277
So... back at it again in a different thread. What's the best memory again ? I'm looking for 32gb of ram under $200 that's at least 3600 speeds.
13Gigatons
7,461
500
Huh? Why not buy a 3600 for $180ish? Still a great all around CPU.
Yes but the 2700x could be had for $129 and the 2600x could be had for $79. The x470 motherboards were $85....those were some sweet prices.
Today $129 gets you a 4-core CPU.....2020 is just bad.
Reactions: KompuKare
JustMe21
324
49
AMD is now too expensive....never thought I would see that day. I wish I had stockpiled the 2000 series when they were in clearance. It had plenty of horse power.
People will still have the option to buy the 3000 and lower series, so if you don't like the prices, go previous gen. It's not like game performance was terrible with previous gen processors. Or wait for AMD to introduce their lower cost SKUs, which they should because people preferred the lower TDP SKUs as the power consumption was lower and the performance difference was negligible.
I am disappointed that the 5800X didn't release with a base clock of 4 GHz. I've been waiting for an AMD processor that could hit 4 GHz base and wasn't on the Bulldozer architecture.
Reactions: killster1
DrMrLordX
23,223
13,301
Zen3 should be about the same as Zen2 in terms of what memory it likes. So I'm just going to be a broken record and recommend Micron e-die again!
That's binned for 3600 out-of-the-box. If you want to save a little and don't mind more tweaking (and risking the silicon lottery) then you can get about the same ICs here:
For some reason Amazon has the DDR4-3200 kit for $115, which is a lower price than what you can find for the DDR4-3000 equivalent. Very interesting.
Base clock is misleading. It's hard to find anything that will run at that clockspeed. You have to have truly awful cooling and run something like Prime95 SmallFFT or one of those awful PrimeGRID workloads to get close to base clocks.
JustMe21
324
49
While most applications typically run at above base clock speeds with Precision Boost 2 enabled, you still have to wonder why we even have a base clock speed under 4 GHz any more.
thigobr
248
192
I am shopping around for a new ATX motherboard. I am on the fence between Asus Crosshair X570, MSI X570 Unify and Gigabyte Aorus X570 Master... I like the 3 M2 slots from the last boards and I read some bad experiences around the Gigabyte (but I like their VRM implementation and heatsink)...
What do you guys recommend? I will be using a 5950X and either 4x8GB B-die DIMMs or the current 2x32GB M-die
GoodRevrnd
6,801
581
Is the unify one of the revised boards that came out with the X570 Tomahawk? 3 nvme has my interest...
Dave3000
1,548
114
Will the upcoming 5900x have 12 cores per a CCX (only one CCX), or 6 cores per a CCX (2 CCX's), or will it be 8 cores on one CCX and 4 core on the other CCX (2 CCX's)? I'm debating to myself whether I should go for the 5900x over the 5800x if I mostly use my PC for gaming. Also is memory write bandwidth crippled to half on the 5800x and 5600x like it was with Zen 2 chips below the 3900x or do all Zen 3 chips get full memory write bandwidth this time? So basically the two things I'm wondering about is the cores per a CCX on the 5900x and the memory write bandwidth on the Zen 3 chips below the 5900x.
Hitman928
6,754
12,500
It'll be a 2 x 6 CCX configuration.
TitusTroy
335
40
is a 5900X worth the extra $100 over a 5800X if using it primarily for gaming?...will double the cache and 50% more cores make any real difference?
Hitman928
6,754
12,500
So a single 8-core CCX is better than a two 6-core CCX's for gaming, for now and most likely 3-4 years into the future?
We don't know for sure yet because we don't know all the changes that were made for Zen3. For Zen2 it seemed some games did better with 1 CCD (3800x) and other games did better with 2 CCDs (3900x). I would expect the gaming difference between a 5800x and 5900x to be rather small in either direction but we'll have to wait and see from reviews. The longevity question is interesting with the new gen of consoles coming very soon now with way more powerful CPUs than the previous gen. Who knows how much that will translate to needing more CPU on the PC side but my guess is for the next 3-4 years, 8c/16t CPUs should be fine.
TitusTroy
335
40
which games did better with 2 CCD's?...I'm curious if it's a specific type of game
Hitman928
6,754
12,500
I don't know off hand, I just know that some games had the 3900x higher and some had the 3800x (or even 3700x sometimes) higher. You can check Anandtech's bench section or the last little bit of Hardware Unboxed (youtube) reviews, they will show you how the CPUs did across each game tested without having to click through a bunch of pages or watch the full video.
DrMrLordX
23,223
13,301
It's really just there for the suicidal AVX2-heavy applications that drive maximum current.
reqq
31
35
im going 5900x over 5800x over gaming..just because i need to have 12 cores lol.. but i can see 5800x might be faster in some games..but also other way around.. must be scenarios that 5800x needs to wait on a "free" thread while 12 core have more of them right? Then 5900x have doubled cache..not sure if thats helps or not in gaming
Reactions: lightmanek
