VirtualLarry
- Aug 25, 2001
- 56,587
- 10,225
- 126
so it looks like there is still a 4Ghz wall on these.
That's unsurprising, since these aren't the 12nm refresh parts. However, probably a greater percentage of yields clock closer to 4Ghz now.
I think you're wrong, but I'm not about to sift through pages of crap I already read.
No one with half a brain could expect a part with these specs, at this price, at this power, to compete with the latest Intel CPU's as well as be in the GTX 1050 range. The reviews are overwhelmingly positive from what I've seen.
So you are wrong? Because we're both saying the same thing. Maybe try reading a little better.No, your facts are not right, because if you set the memory to 512MB in the bios the IGP still uses UP TO 2GB while gaming!!!! last time im going to say this to you, thats why the results are almost the same.
My facts are perfectly fine in the fact that there is a setting in memory usage between 512MB, 1GB, and 2GB for its minimum allocation, then it can go up to 2GB.
The number 8100 is larger than 2400, Socket 1151 has more numbers in it than AM4, and NVIDIA has more marketshare than AMD. These are also facts that have just about as much relevance as your statement. You were the on who has spent much of this thread discussing about AMD has to address cheaper and cheaper, because budget is so crucially important. You are also the same person who is advocating that someone should pay 18%-22% more for something that gains 2-5 Average FPS at "Normal" or Low settings. For the memory, at this GPU performance level, if this is really a problem, it should be easy to find benchmarks that show the 2GB usage from the GPU as being a tangible burden. If you're trying to justify people paying more for that, then I would assume it makes more of a difference than just a paper spec sheet.As for the rest im just saying 6GB of usable ram < 8GB of usable ram, what is a completely valid point, wharever you like it or not, and 4GB is not enoght for some games today. So i would expect if you have 8GB you will want to upgrade it later on, if you have 2x4GB and 2 slots is a problem, another 100% valid point. The rest is you trying to find something to complain about what i said.
Nobody is claiming this is the generation APU that sticks a fork in the dGPU for basic gaming. That's a strawman. 7nm though? Could be.Quick maths (in USD):
Integrated GPU:
Dedicated GPU:
- AMD B350 motherboard: ~60
- AMD Ryzen 3 2200G: 100
- 2x8 GB DDR4-3200: ~190 (CL 16), ~220 (CL 14)
- Total: 350-380
- 1x8 GB DDR4-2666: ~90 for CL 15
- NVIDIA GeForce GTX 1050: ~110 (standard), ~150 (current, inflated pricing)
- Total: 400, gives 2x gaming performance
You misread what I wrote. I am not saying there was any expectation that RR would match a GTX 1050.
I am saying people said the 1030 is irrelevant as a gaming GPU, so it doesn't matter, so matching it is somewhat irrelevant for gaming purposes, when a 1050 was a realistic minimum, or as I put it, 10 pages+ before reviews came out:
"I can't believe we have had almost 50 pages of arguing how Raven Ridge will match a low end GPU that almost no one would buy for gaming anyway."
...This one is all about is about putting a higher performing iGPU on a Ryzen CPU to beat Intel for PC's without dGPU's. I'm guessing that you are not that market. But a lot of other people are.
Not everyone is a gamer, let alone a AAA gamer. Quite the opposite in fact. However, considering those involved in this discussion, AAA gaming is going to matter. In that aspect this APU was never going to make much of a difference. For the general market though it is huge. It gets Zen into any computer whereas it was restricted to those with a dGPU before. It should sell very well, and that what matters most to AMD. That provides them with $$$ to develop bigger and greater products that will benefit us.
Because that's what people are throwing up there to try and devalue RR. Since it's matching the 1030 now people, not just you, are using the 1050. If it had matched that then people would make it the 1060 because you need higher detail.You misread what I wrote. I am not saying there was any expectation that RR would match a GTX 1050.
The dGPU's days are numbered. And in that world AMD has the advantage. This is just a wakeup call.
People with anti AMD bias don't want to simply compare it to other iGPU's. .
Interesting, both Newegg and Amazon Canada are sold out of the 2400g. Low initial stock or somkin' sales I wonder. I went with the 2200g and there are still those around to be had.
It's the CPU side that really completes the picture that makes RR a winning part
GT 1030 is even more pointless because that thing is basically an HDMI upgrade for old computers,
That is by no means an average price. Looking on PC Part Picker they run from a low of $83 to a high of $150. You do have a good selection (5) under $90 though.That would be ~$85, looking at Newegg and Amazon.
The $34 CDN HD 5450 and GT 710 cards are HDMI upgrades for your older PC. Actually, you can go cheaper and buy a VGA to HDMI splitter, but then again I'm realizing that you are making an extreme statement, and isn't accurate.
2200g is much better value anyway.
It is not, the 2400G is a better value on the mid term, 50% better throughput at 60-70% higher price is not excessive given the absolute numbers.
I am astonished there are people suggesting a 7 year old platform for gaming, to people on a tight budget right now. Gaming is a hard workload, how long until one of those old components fail? What warranty recourse can you offer those that can ill afford to replace the components any time soon? It makes no sense to me, to even bring such a dubious solution into a thread like this. I will give you all the benefit of a doubt that it is sincere but (to me anyways) misguided advice, and not something agenda driven.
And watch the price of the high end DGPU when they don't have the volume low and mid level cards to support them. You'll be looking at Quadro and Firepro pricing for gaming cards.Well said. AMD has a APU which will satisfy millions of PC users who want a low budget PC for productivity and can provide entry level gaming. Anybody who cannot see what AMD has achieved today in 2018 is basically in denial. For the complete realization of the AMD Fusion and Vision 25x20 goal and eventual obsoletion of the 100-120 sq dGPU we will most likely see it when 7nm APUs arrive in H1 2020. 6-8 Zen 2 cores, 1536 Navi cores, 4 GB HBM2 on a single package should basically seal the deal.
I assume some sarcasm there.Soo... how well do these mine crypto? If they're half decent at it, they'll double in price in just a few days.
Well said. AMD has a APU which will satisfy millions of PC users who want a low budget PC for productivity and can provide entry level gaming. For the complete realization of the AMD Fusion and Vision 25x20 goal and eventual obsoletion of the 100-120 sq mm dGPU we will most likely see it when 7nm APUs arrive in H1 2020. 6-8 Zen 2 cores, 1536 Navi cores, 4 GB HBM2 on a single package should basically seal the deal.
Have you actually been reading this thread? The speculation all along has been that the performance would be in the range of the 1030. That is pretty much how it turned out. Now whether that is a reasonable performance for a gaming desktop is another issue altogether.LOL The "won't touch a 1030 " bridge have now shifted their goalposts to the gtx 1050 in the wake of the somewhat surprising benchmarks
Why stop there 1050ti is much better! Then you might as well just grab a 1060
Though Those 1070's look tempting..
