NostaSeronx
It's more a metal layer respin and some added instructions here and there. The architecture is 99.8% the same as Bulldozer.It will be. Piledriver is only an architectural update of Bulldozer.
Yup and ivy bridge is a 3-8% improvement over sb, while running hotter and lower overclock.
Chickens and hatching come to mind.
On avg. the 3570K and 3770K OC to at least 4.6GHz on good air cooling.
And if your bringing up Microcenter.
FX 4100 $89.99 + free motherboard
FX 6100 $109.99+ free motherboard
FX 8120 $139.99 + $50 off select motherboards
And I'll say what I said in another leaked pricing thread, with the FX 8120 priced at $140-$160 depending on retailer, who would buy Piledriver?
Right, because everyone goes for 5GHz overclocks. 🙄
On avg. the 3570K and 3770K OC to at least 4.6GHz on good air cooling, and most people running and OCing 2500K/2600Ks were at around 4.5GHz.
Heat only becomes an issue when you raise voltage significantly. Like with Sandy Bridge, that was typically right at 4.7GHz. Is it gonna run around 10-15C hotter than SB at normal OCs? Yes, but as long as you don't go over 80-85C in something like IBT you'll have thermal headroom.
Taking average OCs in mind it's really no different. You can easily get 4.5GHz out of a 3570K or 3770K with a $30 cooler like a Corsair A50 or CM Hyper 212+. Of course, you quickly forget about the fact it consumes a good amount less power than SB.
Nice try, though.
For those who might have a fx x4 or something,it could be a possible upgrade for those not wanting a whole new motherboard and a i5/i7 but who need more crunching power.
Nah There's really no compelling reason for anyone with a sb to sidegrade to Ib. Most sb clocks were at or just below 5ghz, what you're selling is pure FUD. You gain nothing and lose a bunch of money in the process. AMD offers much more value for consumers hard earned dollars.
And yes, as you pointed out, the heat is an issue. And it costs more. So basically you agree that Ib is hotter, clocks lower and is more expensive. So IOW pretty much what I said.
And your conclusion was, "nice try"?
If AMD offers so much value, why does Intel win every category of the best CPU for the money in the Toms Hardware monthly evaluation?
There were some OEM only 4+GHZ Xeon's and this Xeon can turbo to 4.1GHZ. And there is IBM's POWER that go to 5GHZ.The fx 8350 looks pretty epic,basically the first 4ghz stock core clock chip to ever to be produced,to my knowledge.
As long as you go by the CPU support list you should be fine. So if board supports 125W "old" FX CPUs it will support,with proper BIOS, the Piledriver FX 125W models.Possibly, as long as the motherboard can handle the power draw.
There isn't, but you just said that Sandy Bridge is better than Ivy Bridge which it is not. Ivy Bridge equivalents cost the same amount, anyway, so it's foolish to buy SB right now. Yes, runs at higher temps, and? It's made to take the heat, and if you took a class in thermodynamics you'd know temperature does not equal heat output like you make it sound to be. It consumes a good amount less power than SB.
And most 2500Ks and 2600Ks overclocked on average to 4.5-4.6GHz. Just because a few people here could get to higher than that doesn't mean everyone can. If you could get 4.8-5GHz without insane levels of voltage you had a golden chip.
And AMD offers no such thing as more performance for you dollar. Rather, they offer more mediocrity for your dollar. The FX-4100 needs to be overclocked just to keep up with a Core i3-2120/3220, and it consumes nearly twice as much power as well. As far as their APUs go, the only reason why they're giving you a CPU and GPU for $130 or under is because both parts are mediocre. At least Intel can see the logic and give you a good CPU instead, since you can easily upgrade to a discrete card. Most consumers care more about CPU than GPU/IGP performance, contrary to what many gamers here would have you believe.
What if I had to render 100 pictures?OMG I had to wait 15 seconds instead of 8 seconds to render my picture. /wrists
We are so splitting hairs at this point its beyond silly.
FX 4300 4 cores @ 3.8 - 8MB - 95W ------- $131.62
FX 6300 6 cores @ 3.5 - 14MB - 95W ------ $175.77
FX 8320 8 cores @ 3.5 - 16MB - 125W ----- $242.05
FX 8350 8 cores @ 4.0 - 16MB - 125W ----- $253.06
Those two 8 cores will have to perform better than a i5-3570K, otherwise it's going to be another failure for AMD.
http://hothardware.com/News/AMDs-Ne...-Architecture-PreOrder-Info-Leaks-To-The-Web/
This "good enough" attitude is so nasty. There is a concept, I don't know if people are familiar with it. It is called "progress"...
Good enough is good enough for some people. The only hit I take from my 8120 is in games, and it hasn't been enough for me to notice. Otherwise I'll render a few photos a month, run a few applications, and browse the internet. Sure I'm not going to be as fast as many modern Intel rigs in most cases, but the $80 difference for my processor and the i5 was enough to convince me to go for the cheaper option. Maybe in two years when I buy a new computer, the extra power from bulldozer will total to the $80 I saved. I like both companies, and I do wish I had an Intel rig because they're pretty amazing, but honestly what I have now is "good enough"
Anyway talking about Vishera, they better perform as well as they claim, or it is gonna be a big hit for AMD. I got suckered into bulldozer and upgraded my mobo prematurely, but I'm not gonna do that again. Maybe when it's cheaper it will be worth upgrading. Those prices are asking a little too much right now for what will probably be the performance that should have come with bulldozer.
The PC hooked to my TV is a Athlon X2 and is "good enough" for recording TV shows, web browsing, office productivity, and my daughters games (Barbie Pet Shop, etc). If it fried itself I would look seriously at Trinity as a replacement because its got a "good enough" CPU and a good GPU at an excellent price.The "good enough" is just an excuse by fanatics for the lackbuster performance from their favourite company. A oneway love affair tho.
anything close to or exceed 200 will be pointless, as piledriver cores only add like 10-15% more performance compare to BD, you might as well add a little and get ivy.
Did you see the Cinebench R11.5 vs Cinebench R13(with R14 render)?Are there any vishera benches that I'm not aware of?
