Aliens helped build ancient wonders
BUTCH1
20,433
1,769
A lot of stone, sandstone, most limestones, is soft and easily carved. Much of the more intricate ancient stonework you see is created of these materials. Stone carvers today have better tools, but still use essentially the same manual techniques.
Fair enough, but how could they drill these precision holes without a drill or the ability to make a steel drill bit!?,
norseamd
13,990
180
the extreme perfection of the lines is amazing, then at the whole site there are countless more examples of fitting extremely large, precision-cut stones together at Puma Punku. Construction experts working with today's powered tools have gone on record as saying "I don't know if we could do it nearly as well". I'd rather doubt it was ancient aliens but clearly these people had discovered/invented a technology that is unexplainable to modern man..
some guy figured out that hot air balloons were technologically feasible back then
HeXen
7,838
38
The rocks do not weight 1000s of tons. Not even close. Some of them weigh only a ton or two. The largest being around 80 tons. This is easily movable with hundreds or thousands of people, with enough leverage and enough time.
Everything on the History Channel should be taken with a grain....I mean, a bottle of salt.
lol, hundreds of thousands of people. The amount of space required, rope needed , social skills and management necessary alone is a feet of astonishment moreso than the size of stones and placement.
I can think of an easier way to do it. Level out the land underneath the stones and chisel the stones as they naturally rest. The idea that some stones come from hundreds of miles away is absolute theory and is only based on current geographical locations and there is no hard evidence to support the notion. Doesn't mean granite stones were not already there, why not just remove what is under a pile of stones and chisel out block formations of each stone. Lots of rocky areas where stones just pile on top of each other. Or maybe they used a heard of elephants and whipped them into pulling the stones.
7 degree ramps is another method and doesn't require too many people using logs as rollers. Another would be using Sand to lower the blocks into place as the sand pours out of a built structure.
Anything but aliens, c'mon now.
A demonstration showed using sand and a tall log of sorts with rope spiraled so that each side pulls and it twists the log and the sand carves into the stone. A team of scientists made it work and drilled a hole into granite but doesn't mean that was exactly the original method. I think they used horses to walk around in a circle.
Ken g6
Moderator
Dec 11, 1999
16,703
4,661
75
some ancient greek guy came up with the size of earth like some time between 500 bc and 300 ad
Eratosthenes, also known for some very good work on prime numbers. ;)
And more importantly they had a nearly endless supply of expendable slaves.
True of Greece, if not of Egypt. And most of those slaves were from other countries. So they did have aliens help build ancient wonders. They just weren't space aliens. ^_^
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
Well, I sort of line up with the "you'd be surprised what they could accomplish" camp. Boring straight holes in stone and metal was not a problem for the Greeks and Romans. Imagine boring a canon bore out of a bronze casting in the age of water power :). The Italians could do it in... like the 14th century or so. For all I know the Chinese may have done it earlier than that. Precision work from ancient craftsmen does not impress me nearly as much as the heavy construction work they were able to do. The mathematics and measurement techniques were well-developed by classical Greek times, at the latest.
BUTCH1
20,433
1,769
I'm not picturing how this would work but even if it did, these holes are like "1/4 and there are dozens of them on this one stone alone, it would take forever to make all the holes found at that site never-mind what's underneath which has been been discovered by ground penetrating radar but they don't want to maul the existing site to see what's there.
HeXen
7,838
38
^Maybe they're wrong. I saw it on History channel but it's more believable than Aliens or giants or magic.
GagHalfrunt
25,284
1,998
Maybe they came from space before they were enslaved by other countries. They could be space slave aliens.
bradly1101
4,689
294
www.bradlygsmith.org
These shows appear to me to be trying to prove that earlier humans just couldn't be as advanced and inventive as we are. If you ask me, native (North, South and Central) Americans were MORE advanced; they respected the environment.
SlitheryDee
17,252
19
I think it's a difference of expectations more than anything else. If you start a major construction project knowing that you might not even see the finished product before you die of old age, there's not much reason to get in a hurry. If your only argument against it is that it would have taken too long, remember that you're judging "too long" by today's standards. "Too long" was all there was back then. It probably took a huge amount of time. They were willing to spend that much time, and that's all there is to it.
Doppel
13,306
The pyramids are impressive and those finely cut rocks are in some ways more so. Incredible math and skill behind those cuts with old tools.
norseamd
13,990
180
Yes they murdered a relatively few to appease their God. We go on murdering a lot more for whatever reason. Yes we are more 'advanced'.
no i meant that climate collapse was one of the theorized reasons for the collapse of the maya civilization. the north american tribes do have a lot of respect for the environment though. at least after the collapse of the mississipian culture
BUTCH1
20,433
1,769
IIRC these ruins date well before Greek times but anyway imagine what it must have been like when the first cannons were used in combat, I'd bet you probably never saw an army retreat so fast once they knew what they were up against..
Markbnj
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
I think the earliest examples were almost always deployed against fortifications. They were big, cumbersome affairs, and only their creators knew how to work them so they often came complete with a crew to operate the weapon. One account I've read describes a Venetian squad and the hours-long ritual they would go through to prepare the big gun for firing.
norseamd
13,990
180
the earliest use of gunpowder would have been rockets in china. firelances would have been used not long after. in the middle east and europe the first use was artillery. the black prince used some in a field battle. firearms and then naval cannons were developed some time later
tommo123
2,617
48
i think some of these rocks would have been granite though (mentioned in one of those acnient aliens eps). that's a very hard rock though right? to shape them so well to be able to pack them together without a need of something like cement makes me wonder what tricks they had that we've lost
John Connor
22,757
619
121
Ancient Aliens and America Unearthed are two show I can't stand to watch. Biggist bunch of bull shit ever. It's like really? Fuck!
BUTCH1
20,433
1,769
Here's a video of our astronauts walking through ruins on the moon. Not that I believe or disbelieve but it's fun to watch. I am curious as to what exactly that mummy is with that thing over her eyes as I'm sure it's not what was found on the moon but whatever, there it is.
http://www.youtube.com/watch?v=DRWbmiXQba0&list=TLH3bBi_2x3iRUwhl4xVDem4KIGl6JRo8r
Yea, that shit's kinda WAAAY out there, hidden moon bases and inter-dimensional beings that have "infiltrated" all of the governments of the world, if these alien "baddies" really exist all they would need to do is release a virus that wipes out humanity in a few weeks, if your capable of hiding entire bases on the moon then they should be easily capable of wiping us out without wrecking the planet.
