Alec Baldwin shoots and kills a woman, injures a man.
Page 37 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
pmv
15,142
10,043
Did he point a weapon at a person?
Was that person harmed?
If you answered Yes, to both question, he can ONLY be guilty.
Seems a very weak argument. If you deliver a take-out meal to someone (because it's your job) and they die of food-poisoning can you only be guilty?
I again say I don't much care if Baldwin is convicted or does jail time or not, but my sense is he won't, because it seems a very weak case.
[Edit] And, amazed that this is still unresolved and this thread is still going. The US justice system is slower than video game developers.
cytg111
26,628
15,945
Question from someone who doesn't know a lot about guns.
Why can they make firearms with barrels a slightly smaller caliber for movies so live rounds don't fit?
Cause you might still want to cycle the gun with blanks, get authentic recoil and a muzzle flash? Just stabbing here(!).
[DHT]Osiris
17,473
16,807
So this lady's life and Brandon Lee's life are not worth the cost of making live rounds NOT fit? You only have to fix the guns that get "fired" at people on set.
That's a lame argument.
What I mean is, nobody is making .21cal (or equivalent) barrels for a thousand different firearms and blanks because armorers can't figure out how to keep .22's off-set. You're asking for an entire manufacturing base to be built for one industry, AND an entire regulation infrastructure to ensure a) it's required to be used and b) nobody else makes use of it for live rounds. It's an overbuilt solution for a very, very specific problem. It would probably be easier to just regulate that film can't have any functional weapons on-set, force them all to use plastic, and do all 'firing' in post-production.
And not to go too car analogy or school shooting on you, but I'd wager more movie/tv cast members are lost to vehicle accidents on the way to the studio/set than are to firearm failures of this type, tragic though they are.
NWRMidnight
3,620
3,114
You are kind of ignoring one basic, but huge fact, or should I say facts:
1) the weapon you are referring to was a movie prop, that was not supposed to have live rounds in it.
2) would have it been possible for the same outcome (someone killed by the same movie prop) if he waited and used the gun on set during filming and it had the same live rounds it?
3) who is responsible for ensuring the proper ammo is in the movie prop, and who is responsible for all ammo on set? Who is required to have a license to fill that roll? (Hint: it's not the actor or producer).
NWRMidnight
3,620
3,114
The problem with this though, is if you are close enough (usually point blank range) a blank can still be lethal.
cytg111
26,628
15,945
Sure, so it makes sense to have someone in charge of safety…
edit: plus in terms of problems, I'd argue that a blank is still the lesser problem.
cytg111
26,628
15,945
A blank is usually shorter than its live version, a small welding spot(or glue or whatever..) at the right spot would make the gun unable to load a live round but fit a blank just fine.
- I have to imagine these things we talk about is already done in the wild?
Paratus
17,728
16,030
But a blank in a revolver looks like a blank not a bullet as you can see the heads of the rounds in a revolver. For the revolvers they tend to use dummies (rounds with a bullet but no powder) for the visible chambers.
cytg111
26,628
15,945
Heh… was thinking that id still rather have the gun blow up rather than actually fire a bullet…. But that would hurt the expensive actor and not some likely stunt double..
But then again maybe actors gonna check their props then?
andy2000
Fix it with CGI? Or, considering how many other unrealistic props are used in movies, maybe we can live with seeing a gun that's not 100% perfectly authentic.
thraashman
11,112
1,587
Brandon Lee wasn't killed by a live round. He was killed by a blank that propelled a squib stuck in the barrel from a previous firing of a badly made dummy round.
you2
7,082
2,129
My opinion and only an opinion is the armorer was guilty of gross negligence because it was her job to ensure the gun was loaded with blanks. She clearly was not fit to do the job and this was likely obvious prior to the incident but I'm not a lawyer and can't say if the studio (or production team) was negligence for not replacing her from a legal perspective.
Baldwin was sloppy and negligence for not checking the gun but legally i suspect he was not guilty because that was not his job. Also if the gun discharged without his pulling the trigger or intending to pull the trigger that would likely be the armorer responsibility (faulty weapon); but again i can't say if that would legally be the case.
So in my non lawyerly opinion i would say Baldwin is likely innocent though he should feel miserable about the matter.
Paratus
17,728
16,030
I don’t agree he was negligent for not checking. You don’t want an actor messing with a gun that the armorer has safed. If a second check is required (and I hope it is) an assistant armorer should be checking the weapon before handing it to the actor.
Reactions: dank69
dank69
37,540
33,267
Yeah this is why I said he won't be found guilty as an actor for not checking the gun. If anything he will be found liable as a producer who was aware of the highly unsafe conditions on set.
Reactions: Paratus
Bitek
10,676
5,239
I wonder which case is more political - prosecuting Baldwin for this accident or prosecuting Trump for hush money payment.
You misspelled "hand waiving away" Baldwin's responsibility for this accident.
As the persecution argued today, this is a case where an equipment operator AND executive was playing make believe with real firearms and killed someone carelessly.
A rich, famous and well connected and well lawyered actor dumping all the responsibility for the appalling disregard for safety in the workplace on the little person is horrific, but also a story as old as time.
Thought Democrats were better for protecting workers, and not just siding with management/owners, but I guess not when the rich guy also dunks on Trump.
fskimospy
55,712
The armorer’s entire job is basically to ensure that the firearms on the set are safe.
I definitely agree that Baldwin as a producer should be liable in a civil sense but I’m sorry, that woman’s conduct was egregious.
Reactions: [DHT]Osiris and pmv
