It was a prop gun. I would be interested to know how it was designed, etc....
2 people were injured in the malfunction. It's not like only one person was "shot"... The report this morning sounded like the gun exploded possibly.
I used to own a .22 starter pistol. It actually had a baffle in the barrel that would keep a round from going through the gun. The blanks were like 5mm long...just long enough for the powder required to make it go "pop". The baffle directed the sound and muzzle flash out. I'm wondering if this was a similar kind of gun with a round that wasn't packed to the correct specifications.
That's a different situation altogether. Someone loaded that gun with REAL bullets.
From what I recall of the Crow situation they had someone lacking training in use of blanks and props making the blanks.
The first issue was a “blank” that still had a bullet and the primer. Apparently that’s a bad idea. It was fired in one scene and pushed the bullet into the barrel.
The next time they used the gun with a regular blank the bullet was still in the barrel. The blank fired the lodged bullet at Lee killing him.
They didn’t check the barrel nor were they using appropriate blanks.
Possibly but only partially if that is what happened. Regardless, when handed a firearm, prop or otherwise, it is the responsibility of the person handling the weapon to ensure its safe use. You never, ever point a gun at anything unless and until you are ready to shoot whatever it is you are pointing the gun at.
Basic firearm safety. All guns are loaded until the handler verifies clear. Never point a gun at anything you do not intend to shoot. There are no unloaded guns.
That’s nice that you understand gun safety.
However you may not be aware but actors are hired specifically to fire guns at other actors and at cameras which have folks standing behind and beside them with the express purpose of not shooting them.
If you were filming a movie would you leave it to the actor (the handler of the gun) to verify it was safe to fire? Or would that be the responsibility of the props/arms master that you hired to make sure the guns were safe?
Actors who handle guns would be advised to learn appropriate gun safety but unless more information becomes available the failure here was by the props master and the process they had for preparing the weapons.
