Hi I'm assembling a workstation with a set budget and making wise decision making on where to spend makes a difference. I do not need any overcloking headroom. This thing needs to work on stock without thermal throttling and for at least 5 years. All without extensive maintenance (I may bother to repaste and dust once or twice if I notice something wrong with temps). The machine will never be crunching 24/7 but it will be used heavily nonetheless.
Noctua is listing the NH-U12S as compatible with the 10980x (the 18 cores cpu on socket 2066) with some headroom to spare, should I trust them or scale up to the 140mm single fan version NH-U14S?
I'm not set on Noctua, they just make stuff that works reliably without sounding like a leaf blower. Silence is not may main concern since there will also be a 2080s crunching numbers in the same machine.
