HybridSquirrel
shens. can you provide a link showing it's rated for -20F?
Costco.com. the brocure at the tire shop for the bridgestones I got say operating temperatures will range between -20 and 110f....jelly.
You were the one praising the EPA's driving advice.
Why did you think I quoted them
And the EPA is right. If you want proper gas mileage, you need to drive fast. According to their graph, you should be going at least 40mph all the time. People on all season tires drive slow as hell. They take the off-ramp going 20mph instead of 40-50mph, they never go anywhere near the speed limit on straight roads, they take forever to get up to speed when merging and they end up running red lights because their piece of crap vehicle can't stop in time. Because they slow down the overall flow of traffic, it means more of us are idling our cars and waiting for them to get the hell off the road. People on all season tires also have the problem of tires spinning but producing no effective power. When winter tires spin, they throw snow around, they dig to find ground, and the car moves. When all season tires spin, all they do is spin. No snow moving, the car isn't moving, so gas is being consumed for basically no reason.
winter tires = better mileage (not safer because you're more likely to die in a 40mph crash than in a 20mph crash, especially if you're the pedestrian)
did anyone point out to fleabag the initial investment of buying winter tires, vs just dealing with the $1.50 of lost gas? haha
I would really love to know where you live, because I can't think of any place on this planet where the conditions would warrant using snow tires and exits would be safe at 40-50 MPH.
If the weather / road conditions call for winter tires, driving faster to raise your fuel economy should not be one of your concerns. If the weather and roads are decent enough to get up to 40-50 MPH in most areas, winter tires aren't necessary.
cost to fix OP's car because he didn't have winter tires: many many hundreds, possibly thousands of dollarsdid anyone point out to fleabag the initial investment of buying winter tires, vs just dealing with the $1.50 of lost gas? haha
I've never slid off the road before (in winter) and I've never been ruled at fault for an accident. That doesn't automatically mean going 40mpg on ramps is safe, but if I've been doing it every year for many consecutive years then chances are it's pretty safe. It's sort of like sky diving.a)there is such a thing as 'too fast for the conditions', congrats you seem to achieve this every day.
😕b)the accelerator is capable of being modulated, it is NOT an on/off switch. This will help you when you can figure this out.
Next time you drive one of your automatic transmission cars, pay close attention to the rpm gauge. When the cruise control is on, a Corolla will sit at 1500rpm in top gear in regular city driving. The guys who designed it are under the impression that it should be in that gear at that rpm.c)There is a point of maximum efficiency in regards to speed, engine speed, and gear. Going 30mph in 5th gear? lol, FUCK NO. I would bet that you use MORE gas in that gear than say 3rd which would probably only turn in the 2-2.5k range.
You can put any kind of reason you want on it. The simple fact remains. If you are going 20mph, it will take more gasoline to move 1 mile than if you were going 40mph.d)You should realize that EPA graph is not applicable for many scenarios. What it is saying is that on a flat surface, because you are only going 10mph you will end up using xx amount of fuel over this span. Not because the engine is using MORE fuel to go slow, but simply due to passage of time.
All modern Corollas have instantaneous fuel consumption gauges on them. Yes I actually have tested this before. When traveling at speeds that are too slow to allow it to pop into overdrive, gas mileage is significantly less. What's fun is to travel at a constant speed then switch it through the gears. Have the cruise control in D and see what the mpg is, move the stick to 3 and look at it again, move it to 2 and look at it again.Want to see for yourself? Get a scangauge.
You guys need to stop talking to him. He thinks that anyone who drives a FWD or RWD car in the snow is going to automatically die.
This is definitely not true at all.
It's really about RPM's and it's not always the slower speed that burns the least gas in practice.
This is not true either. Drive the car in overdrive at 2000rpm in your highest gear and look at the instantaneous fuel consumption. Now try the exact same thing in first gear and look at fuel consumption. Lower gears consume waaaaay more gas even when running at the same rpm.
coefficient of friction is determined by tyre material, not pressure
of course ATG refuses to believe such a thing as coefficient of friction exists and therefore ATG assumes winter and summer tires have the exact same coefficient of friction on ice. I'm not even putting words in peoples mouths. Someone posted that, and I've heard people say that in real life. Do those people ever wonder why tires are made from rubber?
Depends on the engine programming. My car uses a lot of gas in 1st for no reason at all (no throttle).I can coast in 1st gear at 2000rpms and consume way less gas than at 5th gear and 2000rpms and my foot on the gas. To say you consume less in low gears is misleading. You consume gas accelerating, not simply by staying in low gears.
It measures fuel leaving the gas tank but it doesn't measure fuel going into the engine? Where is it going?That figure is NOT counting how much fuel is being put into the engine. It's just a basic x by x, calculation.
I do every day and it's never a problem. When your car isn't a total piece of shit, it's not a problem. I even a started a parody thread about this concept. You guys were saying it's perfectly normal to drive on useless summer tires that can't take corners going 40, and you guys said the correct answer was driving slower. Without skipping a beat, the exact same people then said driving on bald tires that can't take corners going 40 was totally unacceptable. So which one is it? Do you expect drivers to use proper rated equipment so they can actually go the speed limit, or do you expect drivers to continue using garbage equipment then drive way slower?please, drive really fast the next time it snows and get back to us. especially go 45mph around a turn too
Measure the mpg when you're going 60mph on the highway then compare that against the mpg when idling in first gear. I'll even tell you what the results are so you don't need to spend time doing this. When idling in first gear and going about 5mph or however fast first gear idles, my Corolla's computer says the instantaneous gas mileage is 12L/100km or 20mpg US. That's horrendously bad mileage and that's at a nice and steady 800rpm. If the gas mileage is based on rpm rather than gear, why is the mileage so bad? On the open road at 60mph, fuel consumption jumps over 40mpg even though the engine is spinning more than 2x as fast.I can coast in 1st gear at 2000rpms and consume way less gas than at 5th gear and 2000rpms and my foot on the gas. To say you consume less in low gears is misleading. You consume gas accelerating, not simply by staying in low gears.
You know I don't like calling people out and naming names, but I'll do it just because you asked:(1)False. Tires' coefficient of friction is sensitive to contact pressure/loading. This is why high-performance cars are designed to minimize weight transfer.
(2)Quote the post or GTFO.
He is saying that the coefficient of friction between hard rubber and ice is exactly the same as soft rubber and ice. That's so obviously wrong that it makes my balls hurt. If you watch the video I posted right after that, you'll see that the softer tires with no studs stop in half the distance and they can take corners going twice as fast. It's pretty damn obvious that different rubber compounds have wildly different coefficients of friction against ice.jaha2000 said:You do realize that winter tires are designed for deep snow correct? On ice, they are no better than regular tires. Ice requires studs or chains.......
Engines generally don't like a severely limited throttle. Thermodynamic efficiency of the engine is much higher when it's working hard. In first gear at constant speed, the engine is not working hard at all; you're probably feathering the pedal as light as possible just to prevent it from accelerating. Here's what wiki has to say:Depends on the engine programming. My car uses a lot of gas in 1st for no reason at all (no throttle).
Gasoline engines also suffer efficiency losses at low throttle from the high turbulence and head loss when the incoming air must fight its way around the nearly-closed throttle; diesel engines do not suffer this loss because the incoming air is not throttled. Engine efficiency improves considerably at open road speeds; it peaks in most applications at around 75% of rated engine power, which is also the range of greatest engine torqu
Nope. It's because my engine ECU is retarded and gives me air when I don't want any; it controls a DBW throttle.Engines generally don't like a severely limited throttle. Thermodynamic efficiency of the engine is much higher when it's working hard. In first gear at constant speed, the engine is not working hard at all; you're probably feathering the pedal as light as possible just to prevent it from accelerating. Here's what wiki has to say:
http://en.wikipedia.org/wiki/Engine_efficiency
