hawtdawg
- Jun 4, 2005
- 1,223
- 7
- 81
I've been spoiled by PVA/MVA/IPS. I won't buy another TN panel. Eh...
I've been spoiled by plasma televisions. All LCD monitors are trash.
You aren't going to see an IPS 120hz monitor for some time. They struggle to even switch the pixels within 16ms let alone the 8ms that is necessary. IPS just doesn't have the speed to support 120hz at this point and its not looking like it will anytime soon. Its a technology designed for colour professionals like photo and video editors, its not a gaming panel technology because while it looks good on a static image it looks blurry in motion.
If you can find plasma monitor, more power consumed by you![]()
If you can find plasma monitor, more power to you![]()
I don't know about LG IPS but my Samsung PLS runs at 120 hz just fine. The only side effect is the gamma/brightness/contrast gets a bit wonky but the pixel refresh speed is there.
Typically IPS pixels respond between 12-20ms depending on the colour to colour adjustment. A TN pixel on a 144hz monitor can do the same thing in 1-5ms. Even at 60hz the IPS monitors have a lot of motion blur, because the pixels are in constant moving state when the scene is changing, they are always in transition. The TNs on the other hand get to where they are meant to be (overshoot unfortunately) quickly and then sit still for the rest of the frame. Under motion when you do them side by side the IPS is a better image stood still but in motion the TN monitor is much clearer.
I actually had a lot of problems on a high quality IPS (Dell 2410) because I found that my games looked amazing colour wise but I just couldn't effectively aim and shoot in my FPS games. I tend to strife a lot around corners, its part of my aiming process and that is about the worst case for a high blur monitor. I could not initially work out what was wrong, I just thought it was me but then I heard about the new Nvision 2 monitors and the benefits of 144hz and on CRTs I used to run 100hz+ so I figured I would try it and see if it helped. As soon as I got it even on 60hz I realised what the problem was with the IPS, it was the motion blur. I don't personally care what people buy, if people want to run around with an IPS and some rubbish Logitech mouse that is fine, its just another person helping to improve my K/D.
But as always with my advice on monitors I do urge a bit of caution. I am an ex pro gamer, I use a flawless mouse which I take to near failure speed, I think I want to try 240hz or more etc etc. I probably have less tolerance for performance issues than most. I mostly play FPS games. I do play a wide range of games but I choose most of my kit to cope with FPS games as that is my stable go to game and its what I am best at.
I guess you missed the worst part of it all..
The Acer XB280HK starts shipping in Q2 in Pan America, EMEA, Japan, and Taiwan.
That about settles that.
Just out of interest,who was paying you to play professionally and roughly how much per year?
Were you able to win any notable tournaments and was the prize money given to you or your sponsors?
my point is that all LCD monitors are shit in one way or another. dogging TN while praising IPS and VA is silly. IPS have god awful black levels, and VA monitors have gamma shifting.
This is something that I've been aware of for a while now, but you managed to get me thinking of one more thought related to this which I had not thought about much before.
Under motion, due to the TN panel's superior pixel response, and the IPS panels poor response, wouldn't the colors be more accurate with the TN display?
4K with Gsync is a good idea. Unfortunately it'll be TN from the 170 degree viewing angles which is not cool.
It suppose it could if motion blur affected colour...but does it? I didn't think it did
Correct. But really, what's the better answer? Currently you can get a 10 bit IZGO panel with perfect viewing angles for color critical work and 4k resolution which will basically cost you north 2000$+ in most cases.
Or you can make concessions and get a TN based 4k panel for under 1000$. What's preferable? I certainly would not use a TN panel for any color critical work, but for gaming? What's the problem? TN is generally fine for gaming. Now I prefer IPS myself for productivity, but AFAIK there are no IPS 4k panels. There's IZGO and TN. I could be mistaken on that, but there's an OBVIOUS cost difference between the two technologies.
Hopefully IZGO will lower in price in the coming years. It's just how panel technology has been, it's always a give or take and nothing is perfect. IPS has great viewing angles and color accuracy, but has horrible contrast ratios and poor black levels. AMVA panels have good viewing angles (note AMVA not VA) and retains great contrast ratios and great black levels, but doesn't have the response time that TN has (it is better than IPS, worse than TN). Then TN has the worst viewing angles, not so great black levels, but amazing response times (for an LCD) and are great for gaming.
What's the best answer? It really depends. I'd say for gaming, a TN panel is fine. Most gamers simply don't do any type of work on their monitors that require any extent of color accuracy; so TN would be fine for that type of use. Or you can get IZGO for color critical work and pay much, much more. But I wouldn't characterize IZGO as the best solution for gaming. If IZGO had price parity with TN, then the argument could be made for it.....but IZGO costs 2-3 times more than TN at this time. With worse response times to boot. So that essentially means professional work = IZGO, gaming = TN.
Really, it's still early yet for 4k. None of the solutions are ideal. Personally the ROG Swift 1440p 144hz monitor is on my to buy list, 4k is just not mature enough yet to get my $.
No North America.
Huh? Pan America, EMEA, Japan, and Taiwan essentially covers everything but India, Australia, Russia, Africa, and a few oceanic countries. That monitor is going to most of the developed world.Interesting. Why not elsewhere? Supply reasons? Licensing reasons? IP infringement? Really curious they are skipping most of the developed world with such a hitech product.
What, exactly, do you think Pan America means?
