Will give that a shot as soon as the copper shim shows up.
Good luck :thumbsup:
I wasn't aware that MSI will still honor with the broken sticker, there is no physical damage to my card at all so good to know for the future.
I don't have a dremel will have to see if I can borrow one.
Any suggestions on what type of dremel tool?
You might want to check in Canada. Just because they honor it in the States doesn't mean they will any where else.
To be honest guys I'm not to concerned about it. I've been replacing stock coolers for years now which in general will void warranties. If I run into an issue that I caused during the install I won't be that prick that boxes it up and send it back after I damaged the card. That shit causes prices to go up for all of us.
Take it like a man and move on to the next card and the next mod!
100c is pretty ok. Nothing to worry about.
Your VRM temps should be much lower than that. Is the fan sitting right above the VRM area? Your GPU temps should be a lot lower as well, not higher than the stock cooler. Did you put TIM on both sides of the shim? Something tells me it's still not making good contact.
Very odd about the vrm temps. Are you sure the fan is spinning? Also, did you make sure to tighten everything up good when you put the vram/vrm plate back on? make sure the thermal pads are touching the mosfets. Sometimes on TF3 cards they can hover over them just a tiny bit, which would create higher temps.
Your thermal tape is fubar on the VRMs, with a plate-sink with cold air blowing on it, it should be MUCH cooler than reference design due to the fans blowing hot air down through the heatpipes.
110C is definitely not safe for prolong use, and your current is so high is due to it running at such high temps. At around 100C there is a sharp decay in VRM efficiency and it gets worse real quick. More current, more heat, more heat, more current. Runaway POP anytime.
Old thermal tape on most cards get dried and fragile, if you noticed its dried out, and if you demount it, re-mounting it again means its no longer effective. Get a new thermal tape in there asap.
Edit: Actually i'm pretty damn sure your thermal tape is the culprit, since your VRM2 (for the vram) is running so hot. NAKED VRM2 on 7900 series card run around 65-70C with some cool airflow on them. Now what you have, is a defunct thermal interface thats acting as a insulator and preventing cool air flow over the VRMs, causing them to run worse than naked. Try it next time you take it apart, test it all naked with the hybrid fan blowing cool air down. Bet your VRM1 and 2 will be cooler than what you get here.
Also try putting the stock plate back on.
My experience is that you want that nice pressure on the thermal tape that is provided by the plate, pushing the metal down on top of the tape and underlying VRMs.
The plate is a big heatsink itself, it's just flat without fins. Likely the fan blowing on it will be enough to keep the VRMs cool, maybe even cooler than if they are left naked.
So after removing the stock VRM/Memory plate I saw there was thermal tape under so I decided to reuse them.
Very surprised you get normal temps with reference coolers installed back on that stock plate which you did take off to install ram/vrm sinks (which are a bad idea without thermal adhesives or some mount for pressure).
Does the reference heatsink installation somehow apply more downward pressure on the plate?
So the issue you are having is the VRM and not the GPU now right?
It looks like the Accelero does not have a way to coll the VRM other than the fan at the back of the card. I would assume that means the other VRM chips have little to no cooling and that is why you are seeing the temps. The stock cooler blows down on those chips, and thus you would see better cooling.
Unless you can get air on those chips, you may have to either downclock the VRM, or try and get some air over them.
Your problem is poor pressure on the VRMs and re-using old thermal tape.
