accelerating hard and shift shock, is it unavoidable?
EightySix Four
5,122
52
MJinZ = Casiotech spliced with fleabag
Great combo.
I hate to say it, but stop calling him out without contributing to the thread. Yes he shows a certain lack of knowledge, but if you have nothing to add let it go so we don't derail a thread again.
KIAman
3,342
23
The shock is even worse if your upshit from redline is at or very near your engines peak torque output.
Even my slushbox (ZF 6HP19) produces a nice whack when upshifting full throttle in sport mode, where normal mode is smooth as butter.
DivideBYZero
24,117
There is pretty much nothing you can do to prevent that slamming feeling when shifting hard apart from shifting a little less hard. BMW fit clutch delay valves so that even if you drop the clutch like a bad habit it won't be as harsh as it would be without it. Not ideal though.
EightySix Four
5,122
52
Yeah, I kinda like that feeling though :p
Jul 10, 2007
12,041
No, you need to let the RPMs drop down to match the speed you're going for the next gear, though this is less efficient than power shifting through.
rev hang on hondas make this really difficult when driving hard.
drove a genesis coupe and it was pretty bad too, but they're known to have rev hang issues as well.
EightySix Four
5,122
52
that's what i mean. it's stock so it's programmed into the ECU. everything is electronic throttle these days.
... Yes, but if it has a heavy flywheel then you can't "fix" it from software, you have to physically replace the flywheel.
alpineranger
701
Doh.
The conventional torque-converter auto in your Camry has nothing to do with DCT/SMG, which are computer-controlled manual gearboxes with clutches (dual in the case of the DCT, obviously).
There is no slushbox M3, ditto the M5. The C63 does use something of a slushbox, but typical of Mercedes, it's engineered exceptionally well.
Just remember : slushbox =! DCT/SMG
EDIT : I was incorrect, the new Mercedes 7-speed autos are in fact DCTs from Getrag, they've done away with the slushbox (they were the lone holdouts when BMW and Audi went to SMG/DCT style autos for the high end).
Which mercedes 7 speed is this? The little I've read seems to indicate it's a traditional auto with a torque converter and not a dry clutch. Wikipedia agrees with me, although it could be wrong.
http://en.wikipedia.org/wiki/7G-Tronic
As far as I know the BMW gearboxes have torque converters too, except for the SMGs.
http://en.wikipedia.org/wiki/ZF_6HP26_transmission
EightySix Four
5,122
52
http://www.emercedesbenz.com/Nov08/..._Popular_Science_Best_Of_Whats_New_Award.html
Wet clutch, no torque converter.
EightySix Four
5,122
52
The computers tuning simulates an Idle Air Control valve.
I was asking because in the case like my car, where the PCM controls almost everything, it is still almost impossible to get rid of this lag because my flywheel weighs 55(!)lbs.
punjabiplaya
3,495
you can get a lighter flywheel for improved response, but then you can also stall it easier. Flywheels are supposed to be heavy.
amdhunter
23,332
249
I was thinking about a lighter flywheel for my 8 so it can rev faster, but I also read somewhere that lighter flywheels can decrease torque at lower RPMs? Is that true? This car is pretty torqueless as is already.
TraumaRN
6,893
63
Any shifting in any car feels strange and rough to me especially since my car has an e-CVT/single planetary gearset...but I guess my car does away with shift stock so yes it's avoidable
Arkaign
20,736
1,379
Yep, the newest Merc C63 has the dual-clutch MCT7, dropping the torque converter slushbox design. Most Mercedes don't use the MCT7 though.
The BMW autos are still slushboxes, but the M cars have SMGs instead.
As the DCT/SMG design is a rougher, more performance-oriented solution, it doesn't have a place in replacing the conventional auto slushbox design in most passenger cars, particularly in pure luxury models that depend on smoothness/quietness as far more important than shifting in .00x MS.
Jul 10, 2007
12,041
how many manufacturers do you know that don't optimize clutch/flywheel operation for ease of use?
esp. pedestrian makes like honda and hyundai.
i thought it'd be pretty obvious.
overst33r
5,761
12
To avoid the drivetrain shock it causes, I just shift slow and wait for the revs to come down for the next gear. Unless you have a 2lb flywheel, you can't shift fast/smoothly at the same time.
I cringe on a hard 1-2 shift on most cars. A bit less when the wheels brake loose which alleviates some of the shock.
