? about Athlon 850
frogg
65
How would I go about doing this? What setting in the BIOS is this? I have the Asus K7V with an AWARD BIOS. If this doesn't work maybe i'll go for the Athlon Liberator 2 GFD.
Quickfingerz
3,176
I can run my athlon at 950 mhz at 1/4 cache. True 850's can always do 2/5 at 950 mhz. Most 750's should not be able to do it.
frogg
65
Thanks guys for doing the research on this (presumably just for me? :)) Anyways I'll tell you what I find. I hope we all learn a little something from this.. :) And thanks once again for helping me so much
frogg
65
Well.. I disabled my L2 cache in the BIOS and it still wouldn't POST. Either it's not disabling it correctly (or not completely) or it's something else. Could it be my Voodoo 3 AGP? I don't know but it seems that it might be something other than the L2 cache.
Insane3D
19,446
Jgtdragon- I don't think his cache is the problem, it is most likely a low tolerance to FSB bumping. Even if he has the cheaper cache that will not go over 350, he would not hit 350 at 2/5 cache until 950...
Jgtdragon
3,816
19
<<it is most likely a low tolerance to FSB bumping... >>
If thats the case, the only way to get it higher is with GFD to change the multiplier.
