Keysplayr
- Jan 16, 2003
- 21,219
- 55
- 91
Originally posted by: apoppin
i had great success because i did not change my resolution. 512bit is overkill for 16x10 and 256bit is not enough for my Pro to handle 19x12 - even together.Originally posted by: keysplayr2003
two .. of course NOT ... it is 256-bit ... the very issue you chided me on in pairing my 2900xt with my 256-bit 2900p.
You were "chided" for your motherboard limitations, if nothing else.
It *would* make a serious handicap if i gamed at 19x12 with all the details ... not at 16x10.
Really? A handicap? I guess that would depend on the game, no? Besides, if you can play at 19x12 with a single G94, Why don't you think there would be an improvement with two? Meaning more candy? Did you not say you had great success with your Xfire setup? More than you couldn't hoped for? And that is with your 2x 2900pro's (256-bit).
yes it was tested .. and i would much prefer the 2xGTS 512-bit for especially 25x16 ... NEVER even 2xG94 -256bit for the SMALL price difference IF i was running such a nice and expensive display.
I would agree with you, but the SLI scores for this card seemed to scale pretty well. I'd say that would leave room for some candy. And at 179 a pop, (358 total) not bad.
Keys, what you are missing is that no one who spends 3K for a display cares to save $50 if they might lose out a bit. AND they will with only 256-bit cards to drive 25x16 compared to a slightly faster 512MB card[period]
i rest my case
g94 is a very nice *budget* solution to take on 3850/3750![]()
Who's talking about 3K for a display? 24 incher could do 19x12 no? What is this regard for 3 thousand dollar monitors? I mentioned nothing of this. Who would put a 3K monitor on a mid range card anyway? Non gamers excluded
I play at 1680x1050 for the most part. My 22" native res. Crysis, I had to back down to 14x9 to get comfy.
