theprodigalrebel
- Oct 4, 2004
- 10,515
- 6
- 81
Originally posted by: Ares202
If its priced as low as the 8600gts then ATI is in trouble, its going to be like when Nvidia blew the x700 out of the water with the 6600gt back in the day
9600gt probably cost slight lower than a 8800gt cost to make. Why would it cost like 8600gts? They are essentially the same minus 1/2 SP.
These are supposed to be competitve with 3850 prices far as I've heard.
What is the die size compared to a G92?
Originally posted by: Aberforth
it's nowhere near what it should have scored, Geforce 9 is a flop seires by nv which shows the inability of the company
...but am buying gx2 because it's the last souvenir card without PhysX.
.. we are looking at a 9600
-compare it to 8six00 series which truly sux at DX10
i know that, i was expecting atleast 15,000 3dmark 06 scores for 9600 and 25K barrier for 9800.......Nv rushed the model numbers because of that physx deal.
And you chose 15,000 from what data? Or is it a "pull it out of thin air" number?
8600's were a dissapointment as they were outperformed by previous gen high end.
9600GT is just about on par with current high end (up to 3870 & 8800GT) in some situations.
And please explain how the physx deal influenced model numbers. Not just your gut feeling either. Facts. I cannot stand FUD.
Originally posted by: nRollo
What.............................the.................................????????????
This thing has only 64sp's & 4 ROPs. How is it doing so well? I mean, HOW?
Thought the same, have a feeling GPU-Z is reading the ROPs wrong.
AFAIK this is still under NDA so I can't comment on the GPU specs, but the benches I saw showed this card as *ahem* a favorable choice compared to a 3850, so I would expect the factory OCd ones to perform like this.
PS. It only has 1 ROP.......heh...kidding!
Originally posted by: Killrose
Pretty impressive against the 3870 but I noticed they used 8.1 instead of the 8.2 Cats. But who knows maybe thats an advantage for the 3870?
I wish sites would throw in some tests with lower end CPU's for us X2 AMD guys![]()
Not quite, but it's within an earshot.Originally posted by: IsLNdbOi
Wait, so the 9600GT performs as well as my 8800GT?
Originally posted by: larciel
It all looked good until the noise level killed my interest.
Originally posted by: Rusin
Yeah..it's weird that actually 9600 GT and HD3870 were both louder when those cards were idling. And two cm...ftw? They should test one meter away to get results that could indicate about some real life situation..and then they would still have problem of having open test rig..
Originally posted by: SniperDaws
Is it out yet ? if not when its release ? i was about to buy a 3870 but im not keen on ATI and now this looks like it could be better and cheaper hopfully and its Nvidia aswell![]()
Did Nvidia finally implement double precision? Or Double the operations per clock?
I mean, it is dead even with a 3870, and sometimes manhandles is and is neck and neck with a 8800GT?? Something is amiss here. And if the specs are correct, then I, as well as most others in here, never really understood how ROP's function.
GPU-Z doesn't recognize new chips properly.
9600gt is basically G92 GTS minus 64 SP.
