Page 97 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,007
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
psolord
2,142
1,265
9-10 fps gaming. On Volcano area also massive drops even in gameplay
That's an interesting find. You made me look.
My disputants, already know what I will say. Personally, I wouldn't use an 8GB card for anything above 1080p. Or at least not with maxed settings. It's not a matter of vram alone, it's mostly a matter of gpu power. I know we are talking about a 3070 (for which I don't really care about), of which the price was too extreme indeed and would warrant a more stable 1440p experience down the line. I never disputed that specifically, I only say that I got the 3060ti instead. Plenty good for the money.
Speaking of the 3060ti, which belongs in the same family and since you got me curious, within the vram boundaries of this thread, I did the following test, which is in the Landfall area (start of the game really)
(non monetized channel-just for fun)
What this is, is the same 6min run, with 4 different settings.
0:01 high settings with dlaa (native resolution)
6:02 high settings with dlss balanced
11:39 high settings(-) with dlss balanced
17:41 medium settings maxed textures dlss quality
The first part, is essentially what the user above did. Crank everything to over9000 and be done with it. It also has some 10fps drops. For this first test, the game runs at 30-40fps, which is by definition ridiculous for PC standards. It's problematic from the get go. When I see that in a game, my brain tells me that it's fine tuning time and not crank everything over9000 time.
The problem gets X3 improved, if you enable dlss balanced which is the second test. Performance also goes way up, where it is now a mostly 60fps experience (capped).
It gets even more improved if you take down two settings, which is the third test.
And it gets even better, if you use the medium preset, with maxed textures and even higher dlss setting, which is the 4th test.
All that is put on quad side by side windows, with youtube multiplier.
I know the windows are small, but I want everyone to see the graphical differences between them, which are very very small. What is largely different however, is the performance.
More on that, here are two screenshots, of the game at 1440p DLAA maxed and 1440 DLSS Balanced.
On the top right it's the bus usage. With DLAA Native, it's obvious that the bus is used much more, due to vram round trips I will give you that. So what? The game would be unplayable, even if both the 3060ti and 3070, had 128GBs of vram. Look what happens when you enable DLSS Balanced. Performance goes up +117%. VRAM drops by 500MB. The game gets almost playable, almost. It needs further reduction for the 3060ti, is shown in the above vid.
psolord
2,142
1,265
That bolded part is the essence of the conflict.
In my opinion, an EXTREMELY arrogant statement.
Why is it arrogant? Each card has a specific target usage. You can't just go cranking everything over9000 and to hell with it. There are cards from 200$ to 1600$. Why do you expect to use all in between cards, every way you see fit?
psolord
2,142
1,265
This is the point of the thread.
The 3070/ti is not the point of this thread. If they were, it should be mentioned on the title and I would have said nothing.
8GB parts have limited value due to compromises users need to make with them.
You are generalizing and putting all 8GB cards in the same basket. They are not the same. The GTX 1070 and RTX 3060ti have nothing in common.
If you want to argue that in some situations, the strong 8GB cards, will lose some performance, due to memory roundtrips, you have to take into account what the real performance would be, if it had more vram.
You can study my findings in Hellblade II above. Even the 3060ti is losing some processing power at 1440p maxed. It doesn't matter man. It would be unplayable anyway. Same goes for the 3070/ti. They are not THAT much more powerful. However there are easy solutions, settings fine tuning, that will make ALL problems go away, yet people tend to ignore them. You are paying for nvidia features (dlss) and then you don't use it and complain about vram. What is up with that?
The 3060 12GB MSRP was fine for its performance level so the price/perf/lifespan expectations were in line.
It's not fine though. It has a framebuffer that will be useless for 95% of the time. I am telling you, I have a 12GB card (4070ti) that is more than twice as fast and still has gpu power problems mostly. How is the 3060 going to take advantage of these 12GBs?
The 3070Ti/3070/4060Ti 8GB all had the wrong price/perf/lifespan expectations because the 8GB VRAM buffer requires the user make compromises sooner than they should / larger compromises than they should given the price that those products retailed at and how old they are.
I have no interest defending the 3070/ti, as I have said many times. I didn't buy them, because I also saw the wrongness in their pricing. The 4060ti 8GB could be a little better price wise, I also have agreed on that. It is however, an engineering marvel, all things considered. This is what Nvidia is selling.
The 3060Ti is probably on the cusp of acceptable at its MSRP (shame mining screwed that up) because of its age and the 4060 is probably similar.
Yes and this is the card I mostly care about.
The 3060 12GB should not be a better GPU than the 3060TI/3070/3070Ti/4060Ti 8GB in any scenario, those 4 cards are higher tier and more expensive parts, that the 3060 12GB can offer higher IQ at playable frame rates in any title is a failure of those higher tier cards and illustrates the point being made, which is not that the 3060 12GB is a better part in general than those higher tier parts, just that it is less compromised at its MSRP than those higher tier parts are at their MSRPs.
I vastly disagree. The 3060 is OK for its price, sure, but it's exactly where it should be. It gets better only in unplayable scenarios to begin with. In the above Hellblade II Landfall test, it probably would be able to sustain 20fps instead of 10fps in these extreme framedrops. So what? These are not useful scenarios. In gamegpu tests, it is already unplayable even at 1080p. My evaluation stops there. All other data is useless.
See my Hellblade II multitest above. The 3060 would also have to do, way more fine tuning, than the 3060ti has to do. It's easy to understand. See the power draw numbers per frame. Even at medium+max textures, which would be the scenario the 3060 would be used, the power draw of the 3060ti ranges, from 95W to maxed 220W. It hovers at maxed power half of the time really. It's very easy to understand that the 3060 could never have this kind of output.
Timorous
1,989
3,918
No. You just can't see past your view point.
A 1070 was good value. It has had a great life span and the MSRP was balanced with it's performance level. The 3060Ti less so.
New 8GB cards are value limited because they have performance anomalies. Those anomalies will increase in frequency as they age. This is why we say a new 8GB card should be limited to $250 or less. With that in mind the compute performance should also be balanced for that price point.
It is perfectly fine. Price/performance/longevity are all fine. It may not need the 12gb often but it does come in handy now and again and that will be more common in the future. It was a great pick for a budget gamer who wanted to keep the card a long time. Sure it won't play at max settings but it strikes a good balance of IQ and won't suffer the same performance anomalies 8GB cards do at the same IQ level.
As for your 4070Ti, if it struggles have you tried using correct settings? It can fix all problems.
And the issue is that the more expensive 8GB cards are not where they should be. They have performance anomalies that should be priced in and they are not with the 3070Ti being most egregious on this front.
Given the price difference and the same generation that is the expectation, that some games have the 3060 perform better than the Ti at playable for the 3060 settings is not at all the expectation. The 3060 should perform better in exactly 0 games.
psolord
2,142
1,265
My viewpoint is smoothness, always. For which, up to this point, gpu power is far more important.
They only had 70$ difference and are 4 years apart. I'd say the 3060ti is exactly where the 1070 was. Also the 3060ti has some VERY important features the 1070 does not. It's not just a matter of doubled gpu power. The 3060ti has a very solid and very valuable upscaler, which becomes ever so important, not due to vram, but due to gpu power. Whenever the 1070 will be forced to use a software upscaler, it has already lost the game. I mean I see it all the time, since I have both.
They are value limited only in the eyes of the ignorants and meme seeking users, who do not really care about how their game looks and feels at correct settings, rather they try to find where an 8GB card got its framebuffer spilled over, with obscene settings, so they can point their fingers and have some meme fun. There is almost zero real problem.
I'd like the 4090 to be free. Ain't gonna happen. When you see the 4060ti being twice as fast compared to a rx6600 in many occasions and the rx6600 is at 200, you can't expect the 4060ti to be 250. That would mean the 6600 should be 125 and the 6500 at 99 and the 6400 at 70$. Sure I'm fine with that. Go tell it to AMD and Nvidia.
My friend what future? What future? We are in the here and now and the 3060 is already having serious problems, at 1080p.
Go to gamegpu, gather ALL 2024 benchmarks and see how perfectly fine it is and how many times it beats its bigger brothers.
I mean see here, gamegpu has also uploaded DLSS results of Hellblade II.
Screenshot 2024-05-24 at 15-44-37 Senua's Saga - Hellblade II - PC performance graphics benchm...png
One click of the mouse, boom, the 3060ti is nearing 60. The 3060 is below 50. This is a range of numbers, which is very very important. Being almost playable with being completely unplayable, at mere 1080p, is a huge difference. Much bigger than the 70$ of their MSRP. Whoever got a 3060 instead of a ti, is already facing ugly surprises. No need to wait for the "future".
I do. Always.
19,219
I see a big opportunity here for some PC repair company to start a huge international operation modding existing powerful 8GB cards with double capacity VRAM chips. Could be profitable for them and the card owners and it would prevent these cards from getting stripped for parts/precious metals or becoming environmental waste due to forced early retirement.
maddie
5,205
5,618
I'll save @DAPUNISHER the typing.
Bar graphs don't show it working properly. They show measured frames.
If the dev states 12GB is what its going to take to work without issues/errors, I'll believe them.
Remember when frame time consistency was all the rage? Nvidia went overboard in seeding the community with narratives and provided software to expose the failings of AMD vs Nvidia. They were correct.
I can only conclude that AMD's marketing dept is incompetent, they should be making noise about this Vram difference and how it affects actual gameplay vs raw graphs. The same thing Nvidia did for microstutters & frame pacing.
GodisanAtheist
8,549
9,983
Shockingly competent showing from AMD for an Nvidia sponsored game unless, bar graphs being bar graphs, the only reason AMD is as competitive as they are is because the RT isn't being rendered correctly.
blckgrffn
9,687
4,348
www.teamjuchems.com
Ditched my Crossfire 7950's for a 290X largely due to this data and it really reinforced that my feelings that while my FPS was up, the games played like butt.
Sounds familiar? lol.
*edit, first sold a 7950 and got a deal on a 290X later, but point being it changed how I perceived things*
Mopetar
8,534
7,799
Rumor has it there will be an 8GB 50 series. It'll probably be overpriced again and heavily outsell Intel and AMD competition. SSDD.
Well we all know one person who insists that's plenty and will have no qualms buying one.
Battlemage is looking decent enough that Intel could gobble up a lot of the low end of the market by just offering reasonable prices.
Even though AMD will price below Nvidia, they won't do so by more than they have to, which is still much higher than many would like.
DAPUNISHER
32,478
33,535
it's usually Valorant, dota, CS2 etc users
Those all run great at competitive settings on a potato if the CPU has the grunt. Are gamers really buying the low end RTX cards to play those titles? If so, that's the Fry "shut up and take my money!"
I would hope they at least buy them to leverage DLSS and AV1 for streaming and encoding.
Reactions: Ranulf
SolidQ
1,542
2,547
UE5 game... Optimization is "Super"
I saw on stream, same FPS on 4090 in 1440P
Yeah great, but maybe some people want 240-480 fps.
Yeah, streamers can buy it, also new gen can give some new functions
for this price don't understand this card, while 6600 is cheaper.
psolord
2,142
1,265
I am telling everyone for a long time now, what is going to happen, with vram/gpu power ratios, especially on UE5. They don't listen man.
They all collectively agree that I have a thick skull and I don't understand how important vram is. Well, here we are. 3060 12GB 17fps 1080p in this one. The fastest 12GB card is 3 times faster btw. The fastest 8GB is 65% faster. Vram ain't gonna save you mates.
psolord
2,142
1,265
Seems in full hd is ok.
GGpu test
The 3060 12GB is surely saved by its vram in this one too...NOT.
The 3060ti is a healthy 31% faster, which is a proper performance delta. They are both unplayable anyway, so there is only academic interest in this one.
I have Atomic Heart of course, if anyone wants to see, I can test, no prob.
You should also post the rest of the latest tests of gamegpu and show everyone how vram matters. Show Bodycam, Test Drive Unlimited, Soulmask, F1 2024. Come on. Show it. If I do, I will be accused of uploading a "splurge" of screenshots again. I mean, I have seen them, but I try to not be petty and rub it on everyone's face!
Eeeew, psolord is uploading graphs again, MMMOOOOMM!
Status
