Page 94 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,007
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
Timorous
1,989
3,918
Oh wow, the usual flag of TLOU again....
I showed you screenshots with textures at high vs ultra, on my 4070ti and that at 4k. There is virtually no difference. At least nothing for a user to be worried about. The cost was a whopping 1.5GBs.
Still a compromise that the owner of the cheaper GPU does not need to make and that is the problem.
I only say they are good enough for their tiers and correct settings
If they were good enough for their tiers they would not require the user to make more compromises than lower tier offerings. Yet in some scenarios they do so clearly they have an unnecessary bottleneck.
psolord
2,142
1,265
Some very few scenarios to be exact, where at the end of the day, the card with the more gpu power, almost always wins, if you try to bring things to the playable goldilocks zone. I said from the start of the dispute, that it was not out of the question that in some games, there would be some elevation due to more vram. These are the vast minority though. I don't know how you elect governments in your countries, but in mine, the majority is what counts.
Feel free to go to gamegpu, since they have the most complete database, either you like it or not, grab all 1080p results of 2024, compare the 3060ti with the 3060 and tell me what you see.
19,219
Because Nixxes are not idiots. All their games are fine.
Sounds like a great title for a new thread. Games that are not developed by idiots!
Anything that doesn't work right on GTX 970 is made by idiots. Let's see how many you can find. Should keep you busy for a long, long time.
Head1985
1,867
699
I have big problems with Vram in ghost of tsushima.After 1-2hours of gameplay i ran out of Vram on my 4080super.Its because i use 4K(DLAA) with frame gen and frame gen need another 3+GB Vram in 4K to work properly.So after some time performance goes from 90fps to 50-60fps.Only fix is restart game or turn off frame gen.
So someone should create new topic: 16GB is not enougho_O
19,219
So the 4080 Super is ALSO not a 4K card??? Oh wait...maybe the wrong settings are being used. If it's causing VRAM insufficiency issue, don't use framegen!
Not directed at you, Head1985. Thanks for reporting!
Reactions: Tlh97 and Mopetar
Ranulf
2,921
2,602
Ghosts tested at Techpowerup:
DAPUNISHER
32,462
33,496
They test it for 15sec in test scene.This game can take 13-14GB Vram after 2 hours play without Framegen.Those test for Vram are complete BS to be honest.
Precisely. Bigger bar better reviews are insufficient to evaluate hardware. Those of us that play the games, not just test them, have known this for a good number of years. It is best to wait for user feedback like yours, extended gameplay videos, and deep dives by a big channel, if the game gets one.
DAPUNISHER
32,462
33,496
GPU temp 80C on 4060? :oops:
Not sure what's going on with that Storm X card. Palit isn't really a thing here in the U.S.
Pedro aka zWORMz tested the 4060 in that game too. If you enable frame gen without restarting the game, it's sometimes broken completely. After restart it is no better than DLSS alone but with extra lag. 8GB can't leverage FG in yet another game, one of the main selling points of the 40 series.
Unsurprisingly the 4060 was outperforming the 3060ti, a more expensive higher tier card. Day one driver optimization for 30 series not there?
Game patches should get things smoothed out. As the way it handles settings changes is nerfed. Seems to be a memory leak too? Heck, the textures look last gen, it can't be that.
3060ti tests Pedro did -
4060 -
Ranulf
2,921
2,602
Good call. I saw the small heatsink there of the gpu in the case and it got me wondering. Looking at the Palit website, it is a single fan card so that explains the high temps and fan speed. So a loud, small 4060 single fan card for $300. Reminds me of the cheap single $279 2060 cards Asus/Gigabyte put out (vs $350 2fan models) that did not get great reviews.
Another port, of a 4 year old game that is best to wait for another 6-12+ months for a cheaper price and bug fixes etc..
DAPUNISHER
32,462
33,496
Thanks for looking that card up. Wow, it looks about like the ASRock Challenger ARC A380 I had...a $99 card. Indefensible to charge so much for 8GB and a cheesy little cooler like that.
EDIT: I love the full ray tracing line on the product page.
DAPUNISHER
32,462
33,496
It's another game where RDNA 2 comes out of the gate strong. I'd like to see the vanilla RX 6700 tested. Does that extra 2GB get it over the hump at 1080? Game being new, hard to know from just extrapolating 8GB and 12GB data.
Reactions: Mopetar
Ranulf
2,921
2,602
I double checked, I somehow got Ghost of Tsushima on PS4 years ago. Must have been one of those freebies in 2020 or '21. Its not PS+ because those installed games can't work now since I'm not a PS+ subscriber. Hmm, so $60 for this mess or free at 1080p or whatever rez the ps4 puts out at 30fps.
DAPUNISHER
32,462
33,496
After that initial shader comp dip, the stats were great. VRAM kept climbing, so probably have to restart after an hour or 2 in the game's present state.
Status
