Page 69 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,007
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
jpiniero
17,211
7,584
New benchmark video shows how much better asset streaming latency is using DirectStorage with GPU decompression over not using it... but using the shaders to do the decompression hurts the frame rate. A fixed function block would def help.
blckgrffn
9,687
4,348
www.teamjuchems.com
Oh man, like the old days of physx can we off load to a secondary card? 😂
I have a short stack of 6600’s…
coercitiv
7,497
17,916
It does not hurt performance when used as intended. No matter how you look at it, it's still a net gain over what we had before. The point of using DirectStorage is to either shorten time spent in the loading screen or asynchronously load assets over a relatively long period of time for games that aim to avoid loading screens. So when the GPU can stream 8-10x faster than the CPU you can either shorten an 8 second loading screen to a 1 second transition animation, or you can stream with the same speed as with a CPU but with minimal load on the GPU and zero load in the CPU.
A fixed block would be even more efficient so may become tempting as assets grow in size. I can see it make perfect sense in the consoles. It would probably also introduce limitations, such as supporting only certain compression methods. For example, Nvidia is looking into beating traditional compression with some type of ML hybrid method.
Imagine the joy of transferring many GB of uncompressed textures over the PCIe bus :)
blckgrffn
9,687
4,348
www.teamjuchems.com
Haha, yes, I know. It just struck me funny how we seem to go through these cycles where everything is different but seems like flavors of the same.
Hopefully we'll see some algo agnostic decompression hw block, but if AMD were to add the same hardware as featured in the consoles to their cards - or a version thereof - so long as it was DirectStorage compliant it seems like whatever it is would quickly become the standard to measure other solutions by.
BFG10K
22,709
3,007
Happy 10th birthday, 8GB VRAM!
Here's to another ten more amazing years of 8GB, all thanks to Papa Jensen for allowing us to run "correct settings". o_O
Saylick
4,133
9,650
What’s old is new, and what’s new is old. :p
19,219
Sure, I've got no problem if they create a universal 8GB standard which mandates that games nust work at 60 fps with ultra quality graphics. Then put the good games following the standard on a Hall of Fame list and the offenders on the Hall of Shame list. That should force most PR sensitive developers to optimize their games properly.
Feb 4, 2009
35,862
17,407
I don’t get why this is even a discussion. I believe the spot price for 8GB of GDDR6 is like $20-something dollars. It just doesn’t cost all that much more to add it.
I know this is a huge simplification I am making however if it’s designed to have the larger memory it isn’t a big deal.
Just add the 8GB and charge $25 to $50 more to preserve margins.
Problem is the smaller memory is designed to encourage yet another expensive upgrade a few years down the line.
This is the problem.
SteinFG
743
873
3GB GDDR7 chips should be out by the time RTX 50 launches, and I hope Nvidia will just give every tier 1.5x VRAM, without anything stupid, so 5060 - 12, 5070 - 18, 5080 - 24, 5090 - 36. But If they're reducing bus width again next gen, the general sentiment will be very bleak.
TESKATLIPOKA
2,696
3,260
3GB GDDR7 chips should be out by the time RTX 50 launches, and I hope Nvidia won't be stupid and just give every tier 1.5x VRAM (5060 - 12, 5070 - 18, 5080 - 24, 5090 - 36). But If they're reducing bus width again next gen, the general sentiment will be very bleak.
It would be great If Nvidia gave us 1.5x Vram more per tier, not sure why you think that's not enough.
Problem would be If they reduced bus-width thanks to higher transfer rates from GDDR7.
coercitiv
7,497
17,916
I wouldn't be surprised if they're still milking 8 /12 next generation except at the highest tiers. With a virtual monopoly in GPU space NV have no reason to do otherwise.
They can increase it a bit even with lower bus widths. A possible scenario can be 5060 96bit/9GB, 5060 TI 128/12GB, 5070 160/15GB. AFAIK there will also be 2GB GDDR7 chips, so they could also make 5060 96/12GB if the market is willing to pay. These SKU predicitons are not my cup of tea, but it should be obvious they have more room to maneuver with both 3GB and 2GB chips as options.
Overall I would expect the most cost effective SKUs to come out the gate, both in terms of die size (so bus width) and BoM. Even more room for the SUPERs! :p
TESKATLIPOKA
2,696
3,260
This is also a possibility, but I think they will go for 3GB modules If available.
96-bit bus means 3 memory modules, so you would need 4GB(32Gbit) modules for 12 GB Vram or 6x 16Gbit modules in clamshell.
Don't think many would pay for the extra Vram, If Nvidia will once more ask an unreasonable price for It like they did with 4060Ti 16GB.
GDDR7 would allow a significant increase in BW, so Nvidia won't need to increase L2 cache and could also decrease controller width.
128-bit 16-18gbps GDDR6 -> 256-288GB
128-bit 30-32gbps GDDR7 -> 480-512GB/s
96-bit 30-32gbps GDDR7 -> 360-384GB/s
The nextgen *107 chip could have 32SM:128TMU:48ROP paired with 24MB L2 and 96-bit 30gbps GDDR7. With 10% higher clocks It will be faster than 4060Ti.
coercitiv
7,497
17,916
Except my post mentions 96bit / 9GB config for 3GB chips. The 96/12GB config is mentioned for 2GB chips, obviously in clamshell "if the market is willing to pay".
Reactions: TESKATLIPOKA
TESKATLIPOKA
2,696
3,260
Yeah, I saw that later, that's why I added clamshell but didn't change the first part.
Unless GDDR7 starts at much lower speeds, It's very likely Nvidia will reduce memory width because It's not needed. In desktop they could go for clamshell, but in laptop they would be limited to 9GB. Successor to 4050 could be once more limited to 6GB using 64-bit width and 2 modules.
Reactions: Tlh97 and coercitiv
19,219
MrTeal
3,919
2,708
Entry level? The 4060 Ti firmly midrange; you could buy a Series X at Walmart before the holidays for less than you can buy an 8GB 4060 Ti.
Reactions: Elfear and Ranulf
Status
