Page 40 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,007
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
Jaskalas
36,467
10,749
So it makes games look like Redfall. Ouch.
From what I can tell on these review videos.....
These days, turning down the texture settings will result in the LOD replacement textures being used. Meant to be viewed from a distance and never seen up close. The muddy result is considerably worse than my experience the last time I had an entry level GPU (GTX 750 Ti). Of course I never expected a $400 GPU to provide an equal or worse result. I felt safe with the idea of turning down the textures (if needed) based on past experience 8 years ago. That was a mistake.
psolord
2,142
1,265
I recently sold my 3060ti, which I bought during the pandemic for $449 through the Newegg shuffle. It's a good thing I have the money to waste, because I feel like it was a bad purchase in retrospect.
You are running Hogwarts at 1080 ultra no RT. You may think the upscaled image looks better than native 1080, cool, but it's still 1080 not 4K. No way would I have been happy about my $450 card not being able to hold 1080 60 locked, with no RT, 18 months after I bought it.
The upscaling does take some processing to be done, so in terms of performance, it's not the same like a native 1080p.
I would make a new run of the same section, at native 1080p, to highlight this, but the previous run was capped, since I was aiming for as much smoothness as possible and not max performance, so it would be an unfair comparison.
However I did do some tests on Returnal, on the 3060ti, 1080p/dlss and 720p native, at epic settings, since it has a built in benchmark that comes in handy and fsr / dlss options. Here are my results.
Benchmarks
native 720p
then 1080/dlss quality which is rendering at 1280X720
then 1080/fsr quality
So the bench results are:
native 720p = 114fps
1080p dlss = 103 fps
1080p fsr = 111 fps
Dlss has some 10%+ performance hit, so its not the same.
But as for the quality, they are night and day.
Here is native 720p
and here is 1080p dlss quality
Put them in full screen and notice the ferns inside the bubble, how much detailed they are and also the door on the left.
1080p Fsr is also much better than native 720p, but not as good as dlss (stupid camera moved a little)
I will do this test on the 4070ti at 4k, to see how it fairs. But no, it's not the same performance wise, nor quality wise.
Reactions: blckgrffn
BFG10K
22,709
3,007
Hilarious to see DF twisting themselves into a pretzel to avoid knocking 8GB too much. Even their own tools show massive stutter with DLSS3 when it runs out of VRAM.
They use the "most gamers have 8GB" argument, so developers are at fault for going over it. But when Turing was just released and was a total minority, DF had no trouble heaping praise on developers using ray tracing @ slideshow performance.
Not to mention the reason we have still have so many 8GB cards is because the GPU monopoly keeps it that way. Nine years after 8GB was first available affordably in consumer space, NV releases a new 8GB GPU in 2023 @ $400. According to DF, that's "the developers fault", LMAO
And finally, the biggest online polls all say the majority of gamers don't give a crap about ray tracing. So which is it, DF? Do we follow the trend of "most gamers" or not?
DAPUNISHER
32,462
33,493
I watched the review last night, and was going to comment on some of the same points you just hit on. Rich did everything he could to polish the turd. It was fun watching him squirm right from the start. The lead in being about how everyone else already roasted it; you could see how the script was crafted to immediately put you off your guard, so he could start polishing. As he knew he couldn't go full shill due to what happened to Jay's boyz for doing it. Probably cleared the negative remarks with his handler first, to be certain those sweet greenbacks and exclusive looks aren't jeopardized.
Jaskalas
36,467
10,749
Have you seen some of the game updates / patches?
They appear to be getting new texture packs that don't look like LOD mud while remaining below 8GB.
If they put in the work to support 8GB, then they can actually do a reasonable job of it. Like they have in the past.
And if you are going to launch a product on PC, it may be wise to properly support the vast majority of PC hardware. Having greater than 8GB of VRAM is rarefied territory.
Reactions: psolord
BFG10K
22,709
3,007
So again I'll ask, who gets to decide when games are allowed to use more than 8GB? Is it you? Or someone else?
Why don't you apply the same standard to other specs from 2014? In 2014 most games called for dual-core CPUs and 4GB system DRAM. Should games in 2023 also be required to support this?
Why is VRAM given special treatment to stay frozen for nine years because a GPU monopoly with bloated profits continues ripping customers off?
O'rly? You mean like the first ray tracing games that launched when Turing was a drop in the ocean of the GPU market, and almost nothing could run it?
How come developers are allowed to push RT but not high resolution assets which run on anything, but with reduced quality on <=8GB?
DAPUNISHER
32,462
33,493
That's extra work and adds to cost. We will go from $70 games to even more money real fast, if they have to keep doing it. Quote from a 3D modeling artist -
"the reason most game devs have requirements go up is to reduce the time on the retopology process where you have to reduce poly counts on the model so it is less GPU taxing. By increasing the requirements, you can ship the 3D model with high poly counts straight to the game engine and render them in real time."
We start getting Playstation exclusives and PC peasants that pretend to be master race immediately ruin it. 😂
jpiniero
17,214
7,588
The nvidia VRAM rollercoaster, over two generations.
I wouldn't be surprised if the 4060 Ti 16 GB gets unlaunched. I feel like they should spiff it with faster GDDR6(X) but without knowing how much more it'd be (x8) it's tough to say if NV would seriously consider it.
That's the poly count and not the actual texture (?)
DAPUNISHER
32,462
33,493
I didn't quote the whole post. And I know jack/almost nothing about the topic personally. His point was all of that is done faster the way he described. Retopology takes time, time is money.
BFG10K
22,709
3,007
16GB 3070 spotted at Computex, made by Gxore. Remains to be seen whether NV locks it out of their drivers.
They wouldn't want it stealing their thunder when the 5xxx series arrives with 64-bit 4GB VRAM @ $5000. And revolutionary "Dee Ell Ess Ess" 4.0, which stores textures in 1 bit black & white format and upscales to color using "aye eye".
19,219
I hope they wouldn't care at this point. Should help to sell off the last few thousand units of that GPU. 3080 20GB would also be welcome.
Mopetar
8,533
7,797
Has anyone done more fine-grained testing to see where the cutoff point is at? There aren't a lot of 10 GB cards, but it be nice to know if trying to snag a 3080 at a low price is actually a deal or not.
DeathReborn
2,786
789
I think we need some testing on the RX 6700 10GB as that isn't much faster than the 7600 but has the extra 2GB & a 160bit interface.
Reactions: Tlh97 and Mopetar
moonbogg
10,736
3,454
I just noticed something. You're one of the few real ones left around here, forged in the fires of the golden age.
Jaskalas
36,467
10,749
Do not pretend it is one or the other. Low, Med, High, Ultra settings are not mutually exclusive.
D-GPU market is small enough as is, do not argue that devs should only properly support 19% of that market. (PCs above 8GB VRAM).
(19% already, that 3060 is doing some heavy lifting.)
blckgrffn
9,687
4,348
www.teamjuchems.com
Which games are struggling at low/medium texture settings with 8GB of ram?
I mean, they can look ugly but run fine, right? Isn't that what you expect when you turn the settings down?
Current consoles with more than 8GB of vram flip that ratio, I am sure. We've already heard how much developers hate the Series S. I like the price of the Series S but I think the digital PS5 was the right choice long term.
Status
