7950 low unigine heaven 4.0 score?
Face2Face
4,100
215
OC'ing to 1100/1500 only nets me +1.3 FPS.
That doesn't sound right.. What are your thermals while testing? Are you seeing any throttling in GPU-Z while you are running the bench? Update your drivers and are you giving your card +20% powertune in Afterburner?
WaTaGuMp
21,207
2,506
Compared to WataGump your score seems fine...? unless I am looking at it wrong. Don't worry about comparing it too another model, We need more 7950's to run the bench. I am not at home so I cannot help you :(
OP: Update your drivers to the new Beta's and see if that does anything?
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst13-3WINBetaDriver.aspx
Benchmarks can sometimes just give me headaches. It says I dropped to 7.6 min FPS, give me a break. No games I play drop that low, also the difference when running Heaven between the top window with the temps etc never matched the bottom window that tracks the numbers. as I stated in Valley, doing a reboot makes a huge difference for me, as much as 30 FPS in some parts of the test.
BallaTheFeared
8,115
With Heaven if you cycle the bench once it will reduce the loading stutter and bring your min fps up quite a bit.
WaTaGuMp
21,207
2,506
I am not surprised a bit, these Unigine benchmarks all seem a little quirky. I use them mostly for initial testing before having games up and running.
futurefields
6,470
32
So pretty much upping the power setting to +20 is mandatory for these cards? And my card seems to be running as expected then for a 7950?
BallaTheFeared
8,115
Not +20, I only need around +16 for 1200, but +20 is easy and it doesn't really matter.
Basically AMD has a hard limit of x power usage, when you overclock you exceed that so it starts to reduce clocks to base clocks or even reduces usage to around 60% without dropping clocks to keep the power target.
Powertune is pretty much mandatory for high overclocks though, and yes your card runs as I'd expect it to.
WaTaGuMp
21,207
2,506
I went into AMD Overdrive and upped the Power Setting to +20
Here's my new results at 1100/1500:
If you want better looking images from your desktop etc, use the built in Windows snipping tool, its awesome. All you do is open it and drag over the area you want to capture.
futurefields
6,470
32
I'm still miffed about this Durvelle's 7870 kicking the sh1t out of everybodies 7950.
Durvelle, can you share the rest of your system specs and setup procedure to how you get that kind of performance?
futurefields
6,470
32
Lol I barely know my way around Win 7. I tried print-screen, got a black picture, so I took a picture with my cell phone.
futurefields
6,470
32
Also, since I've ran the benchmark several times now does that mean my OC is stable? Temps seem to peak at 58c and never go above that.
Durvelle27
4,102
Spec's in sig and it could be because i ran that at 1600x900 windowed and the other was 1920x1080
Face2Face
4,100
215
