7950 low unigine heaven 4.0 score?
I haven't used Heaven since valley came out. I do have a weird thing that happens running it. If I get low FPS, I reboot and then the numbers are significantly higher.
Would you mind posting the results of your 7950 running the same benchmark I did? I would be really curious to see the results.
yep seems low
Sapphire 7950 3L @ 1050/1350
Preset: Extreme
1600x900 8xAA windowed
(its the 'extreme' preset with nothing changed)
FPS: 37.6
Score: 947
Min FPS: 18.8
Max FPS: 85.9
http://unigine.com/products/heaven/download/
Why don't you download The Valley benchmark and run it at 1080p extreme HD presets? This is the most current benchmark and resolution to test your system with.
http://unigine.com/products/valley/
http://www.overclock.net/content/type/61/id/1292631/width/300/height/600/flags/LL
Erm, check your PCIe lane speed OP, I get 44 fps at 1050/1500 2.0 x16, 39 with 1.1 x1 ()🙂
Edit: I still think you should bump the memory to test, there is a memory hole after 1250 around 1300 which causes you to actually lose fps.
^ Are you sure you guys are using the same settings? His 7870 XT overclocked is going to beat up your stock 7950. Once you overclock your 7950 it will be well past the 7870 XT.
Face, he got almost 20 fps higher than me, and I have a 7950. This is not an overclock issue there is something wrong with my system.
Compared to WataGump your score seems fine...? unless I am looking at it wrong. Don't worry about comparing it too another model, We need more 7950's to run the bench. I am not at home so I cannot help you 🙁
OP: Update your drivers to the new Beta's and see if that does anything?
http://support.amd.com/us/kbarticles/Pages/AMDCatalyst13-3WINBetaDriver.aspx
Lol i overclocked my card to 1100/1500 and the benchmark is running still but it looks like the results are gonna be even worse than stock.
And it was hitching more during the benchmark. It almost seems like my card isnt getting enough power, but I have it hooked up to 2x pci-e connectors from a Rosewill Capstone 650 watt 80+ gold psu.
