Originally posted by: PoorYorick
Originally posted by: Dacalo
Use RivaTuner and use hard monitoring. Also, try clocking your card to 430MHz and see if your 3d applications run without any problems... mine didn't.
Anyhow, the card is supposed to throttle itself back and forth between 2d(275MHz) and 3d (430MHz or 450MHz with new bios), and it was not doing that, so I sent it back.
I set it higher in RivaTuner and got all sorts of graphical glitches, just like you said.
Even when set higher it only got 20fps or so, still nothing near the right amount.
Looks like you are plagued with the same problem. I would RMA it.
