Originally posted by: sisq0kidd
Here's where I have a problem with your argument though. I have tested 1gb. You have not tested 2gb. Even with your testimony, you say you left textures at medium settings. That's where the hogging starts. Crank that up to high and tell me your 1gb can handle the load.
He plays at 1280x1024 res in BF2 on max settings. I answered his question straight about what would yield the best results. You are merely side stepping and saying the obvious that a better video card is a better video card. Maybe next time you can answer the OP's question instead of arguing something you have no clue about.
$70 to upgrade ram is the price you pay to upgrade from a 6600gt to x800. Which ever is the smartest move in real life is up to the user. However, to answer the OP's question again, 2 gigs would yield better results.
From all the things mentioned above, I can only see the things I have stated as obective. Twist my words and arguments all you like, but everything above still stands.
Here's the thing, though. With a 6600GT he's not gonna be able to play at 1280x1024 with everything maxed out. Not unless he likes to play at 10FPS. He will be playing at about the same settings that I play at, since his system will be about on par with mine. People here are saying that it's at 1280x1024 and up, with all maxed settings where you really start feeling the need for 2GB. I guess I can accept that, but it doesn't really apply to the guy who started this thread. It only applies to people with high end video cards that can actually run with those settings.
As for the comparison between 6600GT and X800, I've seen deals on both of these recently for about $130, so there isn't much of a price difference. That's why I recommended he get the X800 because in my book it's the better card.
Fair enough. I still want to know for sure if a 6600gt can handle max settings with 2 gigs of ram on that res though.
1280x1024, all settings to 'high', including textures
2xAA, probably not 4xAA because the 6600GT needs more pipes and memory
but the fast DDR3 VRAM should allow you to use 'medium' or 'high' AF
100% view distance of course
dynamic lights & shadows you may not be able to turn up past 'medium', GPU limitation
that being said, heck yeah 2GB will allow those settings. At that point the limitation will strictly be the 8-pipe GPU and only 128mb VRAM.
i am using exactly those settings above except:
dyn shadows->off
dyn lighting-->low
textures-->medium
lighting--->medium
effects--->medium
with 1GB and no stuttering for the most part
but increasing any one of those and it really gets into system memory and the stuttering starts
those are all things added system memory will help with temendously, but the 128mb vram is still going to limits some things like dyn. lights&shadows and AA.
