Tempered81
- Jan 29, 2007
- 6,374
- 1
- 81
Originally posted by: Tempered81
Originally posted by: toyota
Originally posted by: Jacen
I've been told through the grapevine that it is 300W max load, not 376W. Not going to call Faud's bluff quite yet but he is usually only right like half of the time at best.
well then max load would have to be around 150watts on 5870 if true
Just average load wattage would have to be around 150. A 4870 can pull as much as 210 watts by itself, and they had no trouble X2'ing it and average 260w load...
http://tpucdn.com/reviews/MSI/...ages/power_maximum.gif
http://www.xbitlabs.com/images...sfire/4870cf_power.gif
All I can say is those numbers are not valid in the second link. HD 4850 pulls 147W? The theoretical max is 150W and I doubt AMD would have released it with only one pcie connector knowing it would use close to it's limits. The Xbitlabs numbers are closer to reality.
Originally posted by: MrK6
376 = 188W x 2. That's way too convenient. I seriously doubt AMD made a combined card and didn't save a single watt in power consumption.
well the 4870x2 uses TWICE the power of a single 4870 http://www.xbitlabs.com/articl...hd4870-x2_6.html#sect0
The second link IS xbitlabs, so Im going to guess you mean the first link is "not valid". Note that by calling out xbit and TPU as not valid, you are calling W1zzard and Anton incompetent, while listening to fudo. Here are all the graphs, and yes the cards pull well over they're rated TDP when peaking at maximum values. You can measure the card at idle, 2d, 3d load, 3d peak, and maximum. I don't understand why anyone would want to second guess this data for a minute, the only one shooting smoke up everyones ass are the rumor mill sites (like for example Fuad with this 5870x2 TDP goofy article) The two graphs are to represent that even though a 4870 has a tdp of 160 and an idle of 80 and a load of 130-140, that a 4870 can still peak at ~180-190, and max at 210 or more watts. A 4870x2 has connections for a rated 300 watts of maximum power, however it has been observed many times pulling well over 375 watts when peaking or reaching maximums. Those figures arent sustained for any relevant amount of time.
The 5870 can have a max of 180-190 watts (which is identicle to the ratings of the 4890, and slightly higher than the 4870) and it can achieve much higher maximums than 188w. It also likely operates at full load at an average of 140-160watts......
Anyways, I'm not sure what you're calling invalid but here are the rest of the charts:
Idle: Windows Vista Aero sitting at the desktop (1280x1024 32-bit) all windows closed, drivers installed. Card left to warm up in idle until power draw is stable.
Average: 3DMark03 Nature at 1280x1024, 6xAA, 16xAF. This results in the highest power consumption. Average of all readings (12 per second) while the test was rendering (no title screen).
Peak: 3DMark03 Nature at 1280x1024, 6xAA, 16xAF. Highest single reading during the test.
Maximum: Furmark Stability Test at 1280x1024, 0xAA. This results in a very high non-game power consumption that can typically be reached only with stress testing applications. Card left running stress test until power draw converged to a stable value.
http://tpucdn.com/reviews/MSI/.../images/power_idle.gif
http://tpucdn.com/reviews/MSI/...ages/power_average.gif
http://tpucdn.com/reviews/MSI/.../images/power_peak.gif
link:
http://www.techpowerup.com/rev...90_Cyclone_SOC/28.html
The xbit link shows a 4870 pulling 130 watts at load (4870x2 pulling 260w), even though its rated at 160w and can obv reach 210w in furmark (well over it's designed specs)....I hope this isn't confusing.
edit: BASICALLY here is what I'm saying is funny: 4870 TDP 160W 4870X2 TDP 280W, FUDO Sees 5870 TDP 188W, thinks 5870X2 TDP is equal to 5870 TDP times two (When it isn't) and people believe him and create controversial discussion. 4870X2 TDP is not 4870 TDP times two, why would 5870X2 TDP be 5870 times two...
This is just ROFL stupidity.
Bingo!Originally posted by: lavaheadache
You people who say the power consumption of this card is unexceptable need a reality check. look at the work this thing can put out. what the hell do you want? It's llke asking a v10 viper to not consume alot of gas when you put the pedal to the metal.
I for one DO NOT CARE if the power consumption is a little high, as long as it is within reason for the performance I'm getting. People don't balk at buying 850-1000 watt power supplies. hmmm, why? Probably because they are expecting to buy POWER HUNGRY hardware.
If you are buying an hd5870 x2 or whatever this thing will be called I'm sure it isn't going in an netbook grade pc,
376W is not 'a little high'!
Theres no way they will release a card that uses above 300W.
I'm sure somebody said the same thing about 200W some time ago.
