You don't even need SLI 9600GT for that. Isn't 1 fine?
GT 240 DDR5 is $100, and this is a superior card in virtually every way. Those wanting pure DX10 or less gaming performance at that price range will try to find a 4850 if they can, or a 9800GT. But if you want super low power gaming performance this is the way to go.
It's a 9600GT killer, and that card offered similar performance to an 8800GTS 640MB. Now you can get that same performance (or a bit better) for uber lower power consumption.
Yeah that's what I meant by "this" card - the 5670 is superior to the GT 240. Poor GT 240 had but weeks as the fastest low power card.
Though I still want to see wattage benchmarks on the 550MHz 9800GTs that don't need a power connector. Does their consumption compete with 5670?
Wow, ATI has all the bases covered before Nvidia even shows up to the game.
I remember reading that the 5670 shouldn't require a 6-pin PCI-E connector. Can anyone confirm? If not, looks like I will be replacing the 4670 in my HTPC. 😀
From the photos looks like 80shader part @ 650MHz with GDDR3 and scores 3884 in 3dmark06.
even if it had a better cooler thats still the same amount of actual heat thats getting released. a 5670 uses much less power than an 8800gt so the case will be cooler regardless of the temp of the chip.Not too bad of performance and I love the reference single-slot cooler. Don't like the high temperature though. I was thinking of grabbing this to replace a 8800GT for my sis's Shuttle, to help it cool down for hot summers, but only if they fix the temperature. Wished there's more mainstream cards with single slot cooler that doesn't get up 90+*C inside a Shuttle.
that thing needs to be priced cheaper for sure.
Can't wait to see what a bios flash and more voltage can be applied to these little cards. 900-950mhz core? We shall see 🙂
You be the first one to up the voltage and tell us how that BSOD works out for you when the card passes the 75w Pci-E limit 🙂 The 5670 already sits at 61w and nothing ups the power draw and cranks out the heat like am itsy bitsy bit of power not to mention that you decrease your maximum OverClock more than likely as I'd wager that OverClocked to the max on stock voltage a 5670 prob pushes that 75w envelope as-is.
It's like the 9800GT EE, using the 65nm A1 GPU's they become EE cards by droping a mere .5v on the GPU dropping thier board power down to 66w from 110w. Given that thats on a 65nm GPU and the increases shouldn't be that drastic on a 40nm GPU but still, volt modding a board with no Pci-E 6-pin is kind of an act in retardation.
the 9800gt has been 55nm for quite a while and theres no way the power consumption could have been low enough at 65nm.You be the first one to up the voltage and tell us how that BSOD works out for you when the card passes the 75w Pci-E limit 🙂 The 5670 already sits at 61w and nothing ups the power draw and cranks out the heat like am itsy bitsy bit of power not to mention that you decrease your maximum OverClock more than likely as I'd wager that OverClocked to the max on stock voltage a 5670 prob pushes that 75w envelope as-is.
