harobikes333
Sounds like a plan.
Still not sure what you mean about the momo speakers though/ why not completely.
Originally posted by: QueBert
installing an amp is NOT hard if you have common sense and some patients. If you run the right gauge wire and make sure the remote and ground are properly hooked up, I don't see how you could possibly start your car on fire. I'm not good with shit like that, and I installed 2 amps in my car. It took me about 10 times longer than a pro but outside of it not sounding as good as it could due to my lack of tuning knowledge it wasn't hard at all. 12v goes to your battery, ground goes to any metal surface and if you have a newer, non ghetto amp the remote wire isn't needed as it will auto shut down when the car is off. *IF* you're going to pay somebody to do it, find a local, reputable installer don't go to a shop and pay way too much. I recommend the new Polk amp, you can get it for cheap on Ebay with the live cash back. Their old Momo amps are killer, the new ones own hard. Their components own too, I have 6.5's in the front and they sound super sick.
If you listen to this, your car deserves to go up in flames.
I'm not an electrical person and I've never had a car go up in flames, and I've always done my own car stereo, In fact I don't know a single person who've had troubles outside of hooking up the wires to their head unit wrong and having it drain the battery even when the car is off. There is a possibility of this happening sure, but installing an amp is easy as hell. How hard is it to run wire from your battery to your amp? An Amp will have 2 or 3 wires tops, anyone can drill a hole for the ground cable (how hard is that) Where is this "cart burning to the ground coming in to play?
I find it impossible I've just gotten lucky on the 10 or so systems I've installed to have never had problems. These people who burn their cars to the ground probably rush and don't pay attention. It's NOT hard to hook up 3 wires, the rest are all speaker wires and RCA's, the worst you'll do there is hook the speakers up incorrectly, no harm there. If a person is unable to follow simple directions and take their time, you're right they deserve to have their car burn up. But I would say it's impossible for anyone who has enough brains to follow some simple fucking directions to have a problem. As fir these professional stereo installers I do the exact same shit they do when I install mine. They don't have secret magical techniques they use, there's nothing hard about it...
A 4 channel amp is going to have:
power
ground
remote
front rca in
rear rca in
4 sets of speaker wires out
There are hundreds of things that can and will go wrong with an amp install. There are plenty of things that pro installers check for when they do an install.
But then again, why would you listen to a professional when you can listen to someone "who isn't an electrician and knows nothing about these things".
Originally posted by: spidey07
QueBert,
Most people who get their car burned down is because they didn't fuse it properly or use wire that is too small. I happens more than you think.
So instead of bashing the guy, why not say how to do it "correctly"?
Originally posted by: harobikes333
Righto. Well I"m willing to get a 4 channel amp for my infinity kappa 6x9s and these new speakers.... so... any advice?
