FYI, if you search the avsforums regarding this monitor you will find a lot of good info on this monitor. I discovered that it can actually display a 1280X720 desktop if you have a rage tweak or powerstrip to adjust the available resolutions for your vid card. For 4X3 viewing its not going to be the best (comparable to a 24" 4X3 TV or so) but for HDTV and widescreen gaming(x-box at 720p anyone?) this is an amazing deal for the price and will make a better HTPC monitor than many $2000 + Hi-Def TV's becuase you won't have nearly as many problems setting the resolutions and display timings as it is designed as a computer monitor.
For those looking for a flat screen- Monovision also sells a 34" 16X9 monitor with a flat screen but it's almost $2600.
Lastly, I dont see why Deepinya thinks these refresh rates would suck for gaming - 60+ at 1280X720 will work fine even for FPS especially if you sit a few feet away from the screen (People don't complain about refresh rates on CRT televisions which are often worse than this monitor at these resolutions). Now I wouldnt want to read text at 60Hz all day but for HDTV and gaming it will be fine.
