- May 21, 2007
- 2,143
- 24
- 81
I was pretty impressed as well until I saw the keyboard, only an A++ from me
what's wrong with the g15? what do you use? I haven't looked at a keyboard in about 3-4 years
I'll answer with a picture (albeit, just using the center 30inch monitor now since PLP isn't supported in surround):
Im not a fan of this at all. Because there, the 2 inches gap is no good. I miss the image flow smoothly,, thank you, gl
Hes gonna play @ 2560x1440 , that is what the SLI will allow for. gl
Badass.
We are running the same fittings, is that also TFC UV white hose ? Wish I had of gone with a bay res like you did. I find my tube res clutters it up too much, and because my PSU is so long I had to jerry rig my pump into the shelf.
What are your serial GPU temps like ?
I am tempted to get a 3rd card just because thermals are so good on these cards, but holding off to see if tri-sli scaling gets improved on the 680 with future drivers.
PrimoFlex White Tubing
(these vary on ambient temps)
Idle 29C, 29C, 30C
Load 42C, 42C, 43C (+75GPU , +425MEM ... so 1250Mhz GPU and 3523MHz Memory and 2160Mhz shader)
They are nearly ALWAYS all within 1C of each other. My CPU obv is a little warmer
:thumbsup:
So it's hardly a big deal at all. If I let my cards open up in a game like BF3 without a framerate cap, my temps are very similar to yours. I even see a 1C variation between the two and mine are in parallel.
I think your CPU is probably holding you back some, at least in 3DMark. My score is very close to yours. Mostly from better CPU results. Your graphics score is crushing mine, but not by enough. Usually there is perfect scaling on graphics in 3dmark11, at least there was with fermi cards.
Could be a little CPU, but I think it's mostly drivers and sli scaling not carrying over to 3 cards or more.
that was from a member on evga forums had told me.Not exactly your CPU, but the chipset is what is holding you back. I went from 4.2 Ghz X58 980x -> 4.2 Ghz X79 3930k, and gained ~3k in 3D Mark when I had my 3-way GTX 580 HC2s (and I even had the 580s clocked slower on the X79: 955Mhz -> 850Mhz).
The best i can figure is the latency in the X58 chipset between the PCH (Platform Controller Hub), which was part of the Northbridge, and the CPU. With the introduction of the "Sandy Bridge" chipsets (P67/Z68/X79 and newer), Intel moved the PCH onto the CPU die itself (part of the CPU) to remove that latency.
CPU, being in 16x,8x,16x, scaling (this will get better as newer drivers come out) ... also this:
:::drool::: Nice looking rig. Would you mind posting more pictures of it? Exterior, top, etc?
