T_Yamamoto
- Jul 6, 2011
- 15,007
- 795
- 126
Nice machine.
But I kinda knew you could do that.
What really surprises me is the monitor setup.
I've never seen a setup with a mix of landscape and portrait mode screens. Very interesting. Now I am tempted to get such a setup myself. Can you elaborate a bit on it ? What monitors do you use ? Brand, type, resolution, size ? Is it a coincidence those sizes match together like that ? Are they all the same resolution ? TN or IPS ? TIA.
Very nice (and expensive!) rig man. Where is your pump located (assuming you only have one)? I couldn't figure that out by the pics alone. I see one triple radiator and one double radiator, what is that in behind (or in front depending on your view) of the hard drive cage? Looks like a single rad but don't see any tubes.
i have 2 pumps connected directly to the reservoir (2 pmp-400's) ... check out the link in my sig (first one) and take a look at the 2nd tab. It has a detailed list of all my watercooling parts.
I'm not understanding why the OP uses a GT 520? Would you care to explain what its there for please![]()
to run my side monitors
Thanks! Does Nvidia not have an alternative to eyefinity?
they do, it's called nvidia surround. it does not support a PLP setup
Mind posting in here would like to see your scores for heaven in Tri SLI.
http://forums.anandtech.com/showthread.php?t=2237529
Thanks
Your system blows chunks! My 166MHz Pentium overclocked to 200MHz and 2 Voodoo2's in SLI smokes your piss-ant system.
Damn, I'm losing it. I didn't really feel like that...I used to![]()
Now THAT is a rig. A+++ would look again.
