Hmm.. If you make "fake" screenshots to show a overclock, you need to move on with your life!
This obviously is not intended at you Lopri.
Nice overclock though, on some nice voltage.
Originally posted by: Zebo
How are your temps so low? 47C load? I was on water with my 165 @2600Mhz at 1.45Vcore and registerd that high. That's why I got rid of it - big cache chips - too hot for my loop..
BIP III and 3 x 120mm Nexus @ 7V on her. Setup for silence....a GTX and CPU in loop.... but I still think it would cool better than air... meh could be mobo sensor too. I don't read much into temps anyway - just asking.
What was ambeint?
Originally posted by: RichUK
Zebo: In your opinion what is the best 2 x 120mm rad you can get. On a 1/2 barb/tubing?
Also what is better cross flow rad?s or normal ones?
Sorry for the questions in this thread, just looking to buy very soon.
Grill is "radgrillz" -$18
Res is swiftech too $18
HD "suspecsion" is surgical tubing.
Pump is eheim 1048 on a custom made foamy cusion to kill vibration. (this you can not hear- i 've tried all those fancy watercooling pumps - all are louder than I like)
-fans are nexus 120mm's (Yate loon sleeved low speeds)
Dremel? fun "toy" but I used a mans tool - a cut off tool connected to a 90 gallon air compressor.😛 Took about 2 min to make the cuts for radiator.
Holes are 5/16th's and beveled if you can tell. Looks more "factory" that way.
Thanks Elfear: With regards to that heater core you are using, do you have any links to it? 🙂
Also does it supply better performance than a normal 2 x 120mm rad?
Many thanks.
Many thanks.
The heatercore I'm using is from a '77 Bonneville w/AC. You can pick it up at most any parts store.
Here is a very good sticky over at XS. Maxxracer is a VERY knowledgable person when it come to watercooling components.
It's worth reading through some of the posts in the Watercooling Forum. Radiators/heatercores are discussed extensively there.
Many thanks.
