2600k not detecting 8 cores w/hyperthreading UPDATE: FIXED!!!
Krynj
2,816
8
I'd say the next step is to just do a fresh install of Windows and see what that does.
Mopetar
8,529
7,795
Run some common benchmarks and compare them with published results. The difference between 4/8, 2/4, and 4/4 should be fairly noticeable depending on the benchmark. If the results are similar to published numbers, it should be working fine and using all of its cores regardless of what the OS or other programs are reporting.
Drsignguy
2,264
If you think it's a windows issue, try to do a system restore to the earliest time. I know it sucks but what the hell, give it a shot.
I just completed the build with a new Chip (2600k), motherboard, Ram and a SSD with Windows 7 and Everything is working correctly. Board is a Gigabyte P67A-UD3P.
Edrick
1,939
230
Run > MSCONFIG > Boot > Advanced options > Check Number of cores and choose 8. (Or if checked already, try unchecking it.)
This same thing happened with an i7 950 build I did for a friend.
tviceman
6,734
514
www.facebook.com
Hooray that fixed it! I had selected 4 cores originally, so I unchecked it, rebooted, and now it's showing all 8! You are awesome! Thank you! And thanks to everyone else for the suggestions! Now I can concentrate on overclocking!!!! :D
Edrick
1,939
230
It is never good to use that option to select the max number. Always leave it blank and Windows will use the max available. A lot of tweak sites claim that if you select a number, it works better. But that is not true. Always leave it unchecked unless you want to limit the number to less than what you have. :)
Glad it worked for you.
tviceman
6,734
514
www.facebook.com
Got it. I had reselected 8 after unchecking it, but I'll let Windows auto select in the future.
