So I am thinking about making the jump to a 27" 2560x1440 monitor. I was looking to get some info from people running that resolution already. What card or cards are you running and do you find yourself having to run lower settings cause of the higher resolution. Just trying to get a feel for what I might be in for.
The buttons are fine, I do however have the Display Port bug. It wont come out of sleep without turning the monitor off then back on. That does bother me seeing its a $600 monitor, might bug me enough to get rid of it and get an Overlord Tempest. I also thought this being a semi gloss would pop much more than my HP did, but it does not, so another reason I might not keep it. I am using DVI, so no sleep issues, its just IMHO everything should work on something of this price.
If you are not gaming, something as low as an ATI 5450 with 512MB to 1GB of ram is good enough. I think Visiontek makes a ATI 5450 with a Mini-DisplayPort output. If you are a gamer and running a single 2560x1440 monitor set up, then a Nvidia 660 or AMD 7850 with at least 1GB is good for Medium settings.
You only get the DisplayPort bug (not wake from sleep) if you are not using a VESA compliant DisplayPort cable - most that are included with monitors are not VESA complaint sometimes. The only one I know for sure that is VESA compliant are the Accell DisplayPort cables.
Why do they even include the DP cable then. My HP worked fine with its cable, the same cable does not work on this one, neither does the one they supplied. Pretty stupid if you ask me.
Most of the time, the supplier/maker of the cable is not VESA compliant or not consistant. And sometime in a production run of the monitors, some included DP cables work and some don't (in regards to wake from sleep). Only way for sure that the DP will work correctly is if the cables come from a VESA compliant manufacturer, which can cost more.
I know because I use a EVGA GTX 280 for backup while my R9 290X is down for tweaking running a PLS QNIX 2560x1440 from the cards DVI port between 60 to 120Hz.
What more can we say to convince none believers that 1080p is passe.Only difference is mine is a EVGA GTX 275 while I was getting my 2 XFX R9 290's and everything else ready for the new water cooling gear. Love my QNIX/X-Star so much I'll be adding two more to really stretch my 290's legs in an Eyefinity setup.
