2100+ Tbred B (? -> yes!) at newegg for 92->101 dollars (1/14/03)
MichaelD
31,528
Originally posted by: Shimmishim
IT CAME!!!
AXDA2100DUT3C
AIUHB0301MPMW
That's 2003 week 1 yay!!!
hopefully it'll do as well as though other ones...
i'll post my results soon ... gotta figure out how to attack this slk-800 :)
Wow, to my knowledge you're the first one to get a 2003-made 2100 chip. Let us know, bro!
cliftonite
6,899
63
Hrmm, cant seem to get this b!tch past 2200 Mhz. Does the Epox 8RDA+ automatically lock the PCI and the AGP to what they are supposed to be? Im at 11*200 and if I push it past that windows will not boot. Says it cant find windows/system or whatever. I think my Enermax is crapping out on me though. the +5 is 4.89; +12 is 12.281; -12 is -12.281; and the -5 is - 5.35. The Vdd is 1.568, Vcore is 1.824, Vdimm is 2.608.
MichaelD
31,528
AGP/PCI speeds are locked on the 8RDA+ but for peace of mind, you can lock the AGP bus at 66MHz (or whatever!) in the bios. :)
It sounds more like a cooling issue. When windows doesn't get past the splash screen that usually means more CPU voltage is needed. But if you're at 1.825 already (you set that in the bios, right?) then maybe try 1.850 and see what happens.
cliftonite
6,899
63
CPU temp is at 36C, so I dont think it is that. I even tried to go higher with 1.9 volts, but it still doesnt boot :(
chizow
9,537
I wouldn't press it too much more on the voltage side. W/out knowing your stepping and mfg date, you may have very well hit the limit for that chip. I think the earlier 2400's maxed out anywhere from 2.1 to 2.2 ghz. Pumping more volts into probably isn't a good idea. At this point I'd try different combos that stress your RAM and lower your multi, like maybe 10.5x203. Keep going with that until you hit a dead-end and see where you're at.
Chiz
cliftonite
6,899
63
Chiz
Thanks, ill try that now :D
Shimmishim
7,504
how much power is everyone using? cuz i'm only using 300W (160W total) and i can't get this baby past 2.0 ghz ... keeps failing prime95 after 1st test... i think it's my PSU... anyone else?
Jen
24,206
14
try useing motherboard monitior to monitior your line voltages. may help to determine if its the powersupply etc. i use a 450 watt pcpower and cooling.
Jen
BD231
10,568
138
Can everyone test how far you can get your new B cores to at default voltage?
Dug
3,469
Just got mine today. 1/24. It's brown :(
I like green much better- it means go.
brown means something else.
AIUHB 0250MPMW
Jen
24,206
14
AIUHB 0250MPMW
only one way to find out. put it in and let it fly
Jen
Dug
3,469
Unfortunately I have been screwed by 3 reputable online vendors, trying to get an Epox 8RDA+.
TCWO, Censuspc, and AICMircro. All had good resellerattings. All said the board was in stock when I called. All took money out of my account. None of them have a product to ship. Their reselleratings will be going down.
This has been a 3 week process trying to get this mb.
cliftonite
6,899
63
I got mine from Mwave, they shipped it a day after i ordered it :D
cliftonite
6,899
63
Chiz
seems like ive hit a wall at 2.2 gigahertz, oh well im not going to complain about it
Dug
3,469
Out of stock. So is Newegg, which I would have ordered from if they had stock. They have been pushing the instock date back for weeks.
Jen
24,206
14
total crap to take your money three times and not ship
who has them in stock?
BigJ
21,330
My friend ordered from AICMicro Monday, got it today.
Dug
3,469
Guess I'm just unlucky. I even tried going to Fry's and they were sold out.
Maybe this is a sign to get a different mb.
BigJ
21,330
Don't do it! Get the board! :D
chizow
9,537
Originally posted by: LastRide
If you guys want an 8RDA+ board bad you can get one on the link below.Its a Canadian site but they shipp to the U.S.The 8RDA+ is 199.95 Canadian plus $17.95 Canadian shipping to the U.S 3-5 days.You are looking at $145-$150 U.S shipped,no taxes.Thats $18 more than newegg if you don't care.They have 4 instock.
Bigfoot Computers
Did you Canucks have any luck locating confirmed T-bred B's @1700+ to 2100+ yet? I know Yield and others have been looking for them since release.
Chiz
LastRide
946
Chiz[/quote]
No,not much luck yet.I tried calling one place today and no go.Best thing to do maybe is check your local computer stores and see who has them in stock.They might even let you pick one out.I am gonna call another place tomorrow and see.
Shimmishim
7,504
I have determined after some research that my PSU is causing my limit in o/c-ing...
I have read in multiple places that for the newer xp and p4 systems, the combined wattage of the 3.3V and 5V lines need to be at least 220W.... my antec 300W PSU is only providing 160W to the 3.3V and 5V lines combined!
60W short of what is needed...
I am going to best buy tomorrow to buy an Antec Smart Power 300W Solution Series PSU... it supplies 220W to the 3.3V and 5V lines total :) or should i go with the 350W... 230W total to the 3.3V and 5V lines....
hmmm... i'll decide tomorrow... it's only a difference of 10 dollars...
so far i've hit 2.05 ghz @ 1.7V but i think this baby has a LOT more room :) i'll tes this baby out again after i get my new psu...
mechBgon
Oct 31, 1999
30,699
If you're considering spending the extra $10, consider getting the Antec TruePower330. It has fully-independent 3.3V + 5V lines totalling 242W, extra-tight load regulation, and is quieter too! :D
