2017 Prius Prime launches at $27,100
ChronoReverse
2,562
31
Uh, no. It has a very tight turning circle.
Well, I guess if you consider the ES350 to have a "very tight" turning circle then yes the C-Max has a very tight turning circle of 38 feet.
I don't know where you got the idea the C-Max has a small turning radius when it's one of the most common complaints about it.
desura
4,627
129
101
All right, dude. Whatever.
gus6464
1,848
32
Have you driven a C-Max? I test drove one 30 minutes before I bought a Prius and the thing couldn't make a u-turn to a normal size 2-lane road. Every single person who drives one complains about the turning radius.
desura
4,627
129
101
Uh, I own one and drive it everyday. I'm pretty happy with the turn radius and handling.
It is no worse than my old Honda Accord and it is better than my old Subaru Outback.
gus6464
1,848
32
The Honda Accord is 2ft longer...
Thump553
12,839
2,625
I looked hard at the C-Max a year ago when we replaced our other car. A bit bigger than what I need, pricer and one thing that really burnt me was a saw a number of reports online that not had Ford lied originally about their MPG but that the dash display was rigged to overstate MPG. Advertising hype is one thing but I want my gauges to be accurate.
When it comes time to make the buy decision I'll take another look at the C-Max but will be starting at or near the bottom of the heap.
Ns1
55,420
1,600
if only there were an easy way to research this....oh yes:
2016 Ford C-Max Hybrid/Turning radius
19.19′
2017 Honda Accord/Turning radius
18.8 to 19.8′
2017 Subaru Outback/Turning radius
18.05′
2017 Toyota Prius/Turning radius
16.75 to 17.7′
tweakmonkey
728
32
tweak3d.net
Another car with a famously terrible turning radius:
Fiat 500 Abarth
18.8'
And just for fun, if you ever get a chance to drive one of these they're a riot:
2013 Toyota IQ turning radius
13'
2016 Smart ForTwo turning radius
11.4'
I remember driving a Suburban in 2001. Checked it out, 21.5-22 feet :(
Thump553
12,839
2,625
I'm suspicious of posted turning radii. Google reports the Mini Cooper at 17.7 to 18.1, more than my Prius which can't be correct.. When I test drove a Mini I thought it was the most fun to drive since a go-kart and did a complete 360 turn in two lanes,
Ns1
55,420
1,600
car and driver googling says...
What you notice first about driving the Mini is that its electrohydraulic speed-sensitive steering is heavy. It's also very quick. You don't often find those traits in the same bed. It'll cause you to hit apexes too early for the first few days, and a strong sneeze on the freeway can land you in a new lane. Tracking is otherwise good for a car with a 97.1-inch wheelbase. Not so the turning circle, which exceeds a Honda CR-V's. As if to match the steering, the clutch and shift linkages are also relatively high-effort devices. The accelerator pedal is adequately positioned for heel-and-toeing, but it emits a nasty metal-to-metal clack every time it meets the fire wall.
I'm also surprised.
Reactions: Thump553
monkeydelmagico
3,961
145
On the list of my auto purchase priorities the turning circle is near the bottom. I don't think I have ever gone on a test drive and thought to myself "damn this car couldn't turn around in a football field".
gus6464
1,848
32
U-turns are very common in SoCal. If I can't do a complete u-turn on a road with 2 lanes with a small car then there is a problem. The C-Max couldn't do this.
ChronoReverse
2,562
31
Back to the Prime, it seems like some reviewers are finding that Toyota understated the range of EV mode.
This one particularly stands out:
As mentioned earlier, Toyota claims a range of 35 kilometres, which seems like a gross miscalculation. Either that, or the company wanted to be conservative, because we easily travelled 49.6 kilometres in EV mode. Had my driving partner and I known the road better and exploited the various modes more effectively, we likely could have covered 56 kilometres before depleting the battery.
Yuriman
5,530
141
For what it's worth, I have a friend who regularly commutes in a 2012 Volt, which is rated for 35 miles EV. His commute is 48 miles, and he usually has an estimated "12 miles" range left when he parks it. It really depends on how you drive it.
Kaido
Feb 14, 2004
52,135
7,513
That's pretty good news. I'm considering leasing either a Volt or a Prime for my next car. My daily commute is about 50 miles round-trip.
