11th Annual Folding@Home Holiday Season 3-way Race
Page 15 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
TennesseeTony
4,335
3,803
www.google.com
We're currently set to overtake a number of teams very quickly:
Tom's Hardware (15 Days)
Hardware Canucks Forum (14 Days)
Hewlett Packard (8 Days)
The Tech Report (4.5 Days)
TechPowerup! (1.8 Days)
I think the estimates are based on our "24hr average", which is actually based on an average of the last 7 day's output. Right now the site says our average is about 6.5 million less than we are actually producing, so we should overtake those teams a few days earlier than predicted. :)
Subject to change of course! I doubt everyone has started folding early like most of us have. :)
iwajabitw
828
138
Couldn't get the f@h sig to show in preview, but FreeDC for the other projects seems to work. Scratch that, doesn't show up in my post.
bds71
60
31
46
I think you have to have 10 posts before you can have something in your signature.
cool, thanks for the info!
Ionstream
55
24
51
Anyone noticed that running experimental 0xa7 WUs return much higher PPDs? On full power, I can usually rake in 80k PPD with 30 cores. I was pleasantly surprised to find that my rig was pulling in 200k PPD on medium power, with 2 0xa7 WUs.
Reactions: crashtech
petrusbroder
13,347
1,154
Here is a test run of my spreadsheet for the inter-teams-race:
Any comments?
I'll do the other spreadsheets later tonight and tomorrow.
Reactions: TennesseeTony
petrusbroder
13,347
1,154
I will use these numbers to set up the sub-teams:
The racers with "0" in the last column have not started folding as far as i can see.
Those with ??? in the last column do not come up in the search for users.
Markfw
May 16, 2002
27,134
16,033
Any comments?
So, ppd will not really factor in this race, just total points over the 7 days, right ?
crashtech
10,694
2,291
indydude345 is having problems with his PC, so he may be starting late. If it gets fixed, it should be good for about 200-250K ppd.
VirtualLarry
56,579
10,215
One of my boxen, was apparently Tango Uniform last night. I adjusted the OC and rebooted. If it does it again, I'm taking off the OC. (Pretty mild OC, really.)
Samastrike
25
4
Hey guys having some issues here. So when my GPU (GTX 960M, 376.09 drivers) finishes a task it moves onto the next one, starts downloading, and then fails and won't start folding again until a reboot. I get a similar thing with the CPU where it finishes a task, moves onto downloading the next one but then gets stuck on downloading. This persists across a reboot and I've been unable to get it to continue. Does anyone have any suggestions for fixing these?
Markfw
May 16, 2002
27,134
16,033
373.06 are the most current drivers that work with F@H. Download and install those, and you will be fine.
Reactions: Ken g6
Pokey
2,781
480
My first suspect with GPUs is drivers. I would recommend dropping back to a pre-375.xx driver at least for the race. The latest drivers may be good for gaming but not necessarily for Folding. Next for the CPU look at the number of cores being used and if it is an odd number drop down to the next even number. Try that and get back to us.
OOPs. Did not see Mark's post.
Samastrike
25
4
Ok I've dropped back to the 373.06 drivers and will let you know if that fixes the issue with new tasks. Unfortunately it seems to have started a pretty large task estimating 9 hours to completion so it'll take a while to find out.
Changing CPU threads from auto 7 to 6 seems to have got the new task working there too but again I'll have to wait for it to finish before I can tell if it's truly fixed.
Thanks guys!
bds71
60
31
46
note: I only signed up with the team yesterday (your total points resets to zero when you switch to a new team). to my knowledge the 24 hr average actually averages over 7 days - since I only have been folding for the team for 1 day my 24 hr avg is WAY low (1/7th) - my actual avg will be closer to 250-300k vs the 38k showing now (38k x 7 = 266k).
