Question Zotac RTX 2060 AMP! Mini Heatsink Problem
Orodruin
41
Hello everyone.
I am using Zotac RTX2060 Mini. I have a problem with the heatsink.
I removed the thermal paste and pads of the gpu to renew it.
However, the surface that corresponds to the VRM part and that I marked in the photos is out of place.
They normally glued the part where we place the Thermal Pad to the aluminum heatsink. But when I removed the card, that part came out. What can I paste it back there with? What heat resistant would you recommend I use glue?
So I need a heat resistant adhesive that will bond metal to metal. Which adhesive should I use?
I would be very happy if you give me an idea.
legcramp
1,671
113
0.75mm-1.0mm thermal pad cut to fit should do it. If 1.0mm is thicker than the original just squish it a bit inside a ziplock bag and a book.
Feb 4, 2009
35,862
17,406
This looks like a great opportunity to add one of those AIO water cooling adapter things. Basically a mount for a lower cost all in one water cooler.
I haven’t read about them in a few years and not sure what your budget is however it seems like a fun project.
