Zotac GTX 980 Extreme review [GamersNexus]
do you think he might have just got a dud?
Overclocking is always luck of the draw. Even in binning, there could be some duds slip thru
While your statement is true. I do not believe you read the article based on your response. I ask you to summarize what the main problem with the card was, and how your statement corresponds with that.
I went against my better judgment a few years ago, having bought eVGA for the past 6 years, and went with a Zotac GTX580. Then I found out that Zotac had issues with some of their 580s not supplying the proper voltages. I don't OC any video cards as a general rule, but I agree with the reviewer that Zotac has some issues.
You may find this with numerous other vendors when a reviewer digs far enough into a product, but I will avoid the lower tier vendors after my experiment and go back to the reliable ones, even if it costs that extra $30+.
I was just looking at this card last night thinking, "Maybe I should give Zotac a chance, but EVGA and their support is killer..."
The Zotac card clocked up to 1510 in his original evaluation. That is pretty standard across the board for all GTX980's. He's saying his reference 980 is hitting 1593mhz, which is incredibly high (and I question whether or not it's actually stable).
He's freaking out over nothing. 1510mhz is a good OC and with the lower voltage brings lower temps and power draw.
I thought he said 1560 in the video for reference which is already impossible. then he said he ran 1.256 voltage and got 1593 on reference? that is bull crap as the reference card would hit TDP limits at just 1450 or so with voltage like that.
