LaLaLand,
I see a substantial increase in WWW page loading and file d/l with WWW and FTP. I download a ton of Binaries from Newsgroups using Agent 1.92. I have 5 pc's behind my router so I do not use multiple instances of Agent on the same pc..rather I use separate pc's each using Agent. As far as speed, I can honestly tell you that I see absolutely no difference (not measured..just seems so) in the speeds as far as Usenet is concerned. If you read my earlier post you will note that this is the one reason why I will most likely cancel Hyperspeed before to long. Get it and try for awhile there is no cost for cancelling.
