zip drive are almost as old as floppy itself, some people still using it doesn't make it not obsolete just like removable harddrive. but since the introduction of CDRW, there is no reason to use zip media. you can rewrite just as much. but the fact is cd require better care then zip, it is not protected in a sleeve. making it much more expensive, 10 dollar per megs, or 10 per 250 megs is the most economical way for a backup media. Floppy on the otherhand is much cheaper and serve only one uses, to boot up your computer if you can't boot from harddrive. at best buy, there was huge section of cdr/cdrw media but the zip media was in a very small section as if it hiding from the consumer
LOL you're still obsessed with CDRW?
First, zip isn't as old as floppy itself. Floppy has been in use for about 15 years, whereas the zip is about 5 years old. And your definition of obsolete is entirely wrong.. if some people ARE using it, then it is useful and NOT obsolete. It becomes obsolete when people stop using them, like the CDRW.
At my university, and i assume it's like that for most universities and colleges, zipdrive are much more popular. Infact, i doubt i've ever seen a single university computer that is equipped with a CDRW and the correct software to read them.
