Review Zen4 3D review thread
Page 15 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Hitman928
6,754
12,500
Thread to focus on Zen4 3D cache CPUs.
New gaming king (as most expected), though the 2 CCD 7950x3d does seem to have issues with some games, more than I would expect of it getting stuck on the "wrong" CCD. I imagine it will get cleared up with subsequent updates but we'll see. Simulated 7800X3D showed no such issues and overall has the gaming lead (real product might be slightly slower though depending on in game clocks).
Computerbase also has the 7950x3d as the gaming champ. They (and TPU) also show that efficiency while gaming is extremely good.
Just to toot my own horn a little, it landed spot on with my prediction of fastest gaming CPU but not significantly so over a 13900k on average, but with much higher efficiency.
Additional reviews, will add more later.
Gamers Nexus
biostud
20,177
7,301
Electricity everywhere is usually priced at an hourly rate. The idea is that when usage increases, the price should also go up to incentivize people to cut back or to delay consumption until off-peak hours.
Here you can usually buy, with hour rates, quarterly or yearly fixed rates. But it is quite of topic from this thread.
In2Photos
2,626
2,794
My bill
Energy charges 685.42 Basic Charge 11.00 Energy Use Charge (1,000.000 kWh x $0.06642) 66.42 Energy Use Charge (4,202.000 kWh x $0.07002) 294.22 Transmission Charge (5,202.000 kWh x $0.00585) 30.43 Distribution Charge (5,202.000 kWh x $0.05447) 283.35 Regulatory charges and credits 81.82 102 RPA Exchange Credit (5,202.000 kWh x $-0.00676) 35.17 (CR) 105 Regulatory Adjustments (5,202.000 kWh x $0.00016) 0.83 109 Energy Efficiency Funding Adj (5,202.000 kWh x $0.00579) 30.12 110 Energy Efficiency Customer Svc (5,202.000 kWh x $0.00004) 0.21 112 Customer Engagement Transformation Adjustment (2,511.310 kWh x $0.0003) 0.75 118 Bill Adjustment Cost Recovery 1.14 123 Decoupling Adjustment (5,202.000 kWh x $-0.00222) 11.55 (CR) 125 Annual Power Cost Update (5,202.000 kWh x $0.01007) 52.38 126 Power Cost Variance Mechanism (5,202.000 kWh x $0.0008) 4.16 135 Demand Response (5,202.000 kWh x $0.00094) 4.89 136 Community Solar Cost Recovery (5,202.000 kWh x $0.00021) 1.09 137 Solar Payment Option Cost Recov (5,202.000 kWh x $0.00005) 0.26 138 Energy Storage Cost Recovery (5,202.000 kWh x $0.00012) 0.62
Hard to read, but its essentially $0.15 per kwh. And Europe appears to be about $0.52 or more than 3 times our rate. So the difference between a 142 watt 7950x and a ~250 watt 13900k is considerable per year. My 64 core 7742's are only 225 watt !
Your bill isn't that hard there's just a lot of different charges. Essentially you pay a basic facilities charge, an energy charge for the first 1,000 kWh and a different rate for everything above the first 1,000. Then you pay a bunch of different charges or receive credits for various things.
Markfw
May 16, 2002
27,401
16,247
Point being.... Those not in the USA, definitely Europe, pay more than 3 times what we do, and the gaming wattage can make a significant difference in your power bill. Just one more reason to dump your 13900k, maybe even the 13700k or even the 13600k (would have to evaluate those), in favor of a 7950x3d.
And for DC work, those in Europe need to be rich to do it, as my usage @ 0.52 per kwh = $2,707 !!!
Mopetar
8,529
7,795
I'd honestly wait for the 7800X3D. You'd have to game for a lot of hours to make up the difference between a 13600K and a 7950X3D to justify the price difference, particularly when we know that Intel isn't nearly as inefficient in gaming loads where it's not trying to run every core well past the efficiency curve.
If you already have an Intel CPU it's probably not worth changing unless you can get at least 90% of what you paid not just for the CPU but the board as well. Even if we just use raw TDP values and the worst possible case for Intel and the more expensive European power on top of that, it's a nickel per hour more expensive for an Intel user.
Never mind that in most titles the CPU difference won't show up unless you've got a top-end GPU, and that's going to be sucking down more than the CPU. Last generation a 3090 was almost an order of magnitude more than a 5800X3D and while it's not quite as bad this time around, top-end GPUs are still going to make the CPU look a lot less significant by comparison.
biostud
20,177
7,301
And for the same reason it is a good idea to explore the possibility of undervolting your GPU, as you probably can save a lot of electricity and only loosing little performance.
DAPUNISHER
32,417
33,398
I think the energy use discussion is missing caveats. Tech Testers showed the 7950X 3D idling at 40-50W on the Asus board they used. The firmware needs to mature, because that is unacceptable. Which makes power calculations tough, as you can't count on your AM5 board to use similar power to another. The result is throwing around numbers for power usage is highly speculative.
E.G. I spend a lot of time online reading and watching content. 50W idle would be 5 to 6 times the idle of my 5800X = that board would be going back.
Mopetar
8,529
7,795
Aren't a lot of the people who are undervolt doing so in order to get higher clock speeds? The overall power is still similar, you just get more from it.
Though with current GPUs you can usually drop the power limit by a fair bit and still get around 95% of the performance.
In2Photos
2,626
2,794
It's not just the 7950X3D. My R7 7700 idles at almost 40W with EXPO enabled. I used a Kill-A-Watt to measure my PC at load and idle. 160w @ idle, 416W during a gaming benchmark. My daughter's 7600X uses about 10W less than my 7700 @ idle. I would love to see that improve with firmware updates.
Hail The Brain Slug
3,890
3,331
Your 5800X must be running at 3200mhz or lower ram speeds to have that low of an idle. Any ram overclocking above the rated memory frequency of the CPU causes the SOC to run in "overclock/full power" mode all the time, amplifying idle power consumption.
Granted that, my 7950X3D idles at around 25W PPT even with EXPO + ram overclock, which is around what my 5950X idled at with very fast ram.
DAPUNISHER
32,417
33,398
Pardon me for being a fool and a lout. I was looking at CPU+SoC, my PPT is only a couple of watts lower than yours'. I run 4x8GB 3600 XMP.
Kocicak
1,177
1,232
Talking about energy efficiency in gaming, I just tested what the CPU does while I am running around the main square of Hogsmeade, and the CPU shows cca 50% utilisation on 6 P cores (main threads) and pulls around 50W. Both CPU and GPU 6750XT show nearly zero power draw in idle.
Kocicak
1,177
1,232
This game alone consumes 9-11 GB of RAM, I tested more locations now.
Edit: now the game decided to use half of that. What is happening. Perhaps before it used even more than 11.
Just Benching
Banned
Sep 3, 2022
307
156
All Intel cpus consume the same power in hogwarts. THe game doesn't really utilize the CPU - just a couple of cores.
Just Benching
Banned
Sep 3, 2022
307
156
The 7950x 3d is a good cpu - but the 7800x 3d will be much better and easier to work with out of the box. The problem - tradintionaly - with amd cpus for games, is what is now called "the amd DIP". Haven't checked a lot of games, but warzone 2 that works great on AMD hardware - 1% lows on the 3d are just bad , worse than my stock 12900k. Averages are of course much higher, but 1% lows are horrific.
Markfw
May 16, 2002
27,401
16,247
Saying that lows are horrific, based on this is just trolling. Its 20 fps higher on 1% lows from the 12900.
Shivansps
3,918
1,570
Did you disabled virtual memory? dont do that, Windows needs the pagefile to assign unused memory requests.
Markfw
May 16, 2002
27,401
16,247
Yeah, that's exactly my point. Look at the 1% lows
It's worse than a stock 12900k. A tuned 3d gets around 150 to 160 in quads matches, a stock 12900k gets 170-180
12900k is not even on that list. So even though its average is the best of all cards in 1% lows, in ONE game, ONE cpu is better and you call that horrific. That is trolling.
Just Benching
Banned
Sep 3, 2022
307
156
I wasn't talking about the list but about the video he posted.
It's not the only game, now I'm testing cyberpunk.
It is horrific in the sense it's losing to a stock 12900k - that cpu is slower than a 13600k man...
