Page 952 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
yuri69
699
1,252
AMD does this with mobile parts quite often. Unsure why folks are making this a big deal, this has been happening for years.
There seems to be a nuance. Last time they relied a whole year solely on a rebrand was back in cash-strapped Zen 1 days with Raven Ridge/Picasso.
SteinFG
743
873
7040 zen 4 phoenix to 8040 zen 4 hawk is also that - reuse of the same silicon.
poke01
4,873
6,204
I mean 2026 has nothing compelling from Intel anyway, Strix point refresh is fine.
Panther lake CPU seems to be a low key update.
yuri69
699
1,252
How is that the same situation?
* Phoenix launched in April 2023
* Hawk Point refresh launched in December 2023
* Strix Point launched in June 2024
Compare the Zen 5 situation:
* Gorgonzola refresh is scheduled to 2025-2026
* Medusa Point launches in Q1 2027
Joe NYC
4,221
5,825
Imagine there only 2 times of year: start and mid, and round to those:
Zen 4 desktop: Mid 2022
Zen 4 laptop Phoenix + 6 months - start 2023
Zen 4 laptop refresh Hawk +12 months - start 2024
Zen 5 desktop: + 24 months Mid 2024
Zen 5 laptop Strix + 0 months Mid 2024 (early)
Zen 5 laptop rest + 6 months - Start 2025
Zen 5 refresh + 12 months - Start 2026
Now, projecting to Zen 6
Zen 6 desktop: + 24 months, Mid 2026
Zen 6 laptop Medusa Point + 0 months Mid 2026
Zen 6 laptop rest+ 6 months - Start 2027
fastandfurious6
984
1,092
yep they're moving at breakneck speed
Yeah, but at what power limit? A lot of bigger 7945HX laptops allow 165W PPT, which for Zen 5 is only 35W below desktop 9950X(3D) at 200W PPT. Set a desktop 9950X(3D) to 165W PPT and I bet you only lose around 10% performance.
Not to mention, at least on Dragon Range, it ran JEDEC ram which meant the IOD power was very low, freeing up more power for the cores compared to desktop running EXPO. It also does funny stuff like clocking FCLK, UCLK, and MCLK down when under heavy CPU load that isn't doing heavy memory access, to free up even more power for the cores.
I think the ~10% avg will hold in other chassis too
SteinFG
743
873
AFAIK there is no leak supporting this idea.
It seems the Medusa Point would be Q1 2027 followed by the rest of mobile later.
it's a 2026-2027 prediction, obviously there's no leaks yet. I bet even AMD doesn't know. Summer release worked fine for strix point, It can happen again. Release High-end in limited quantities in 2026 Q3-Q4, increase production and introduce lower end models in 2027 CES
Reactions: Joe NYC
Joe NYC
4,221
5,825
As far as leaks, while not giving explicit dates, MLID talks about Medusa as 2026, implying Mid 2026.
2nd is, as @adroc_thurston says, cadence. The original goal has been 18 months, but it has slipped to ~24 months.
So, what you are suggesting that it will slip further to 30 months. There is nothing that would point to Zen 6 (as a core) and Zen 6 as a client CCD that would be high risk to blowing up the schedule. Quite the opposite. Few things that could have been high risk that are, instead low risk to schedule slippage:
- Zen 6 core is only incremental to Zen 5
- ring bus upgrade (to mesh) to support more cores - done
- mobos, socket - reusing existing ones - done
- new connectivity between chiplets - done in Strix Halo
- new IODs - template done in Strix Halo
Reactions: Tlh97 and Saylick
yuri69
699
1,252
A Zen 6-based product should come late 2026 but, apparently, not the mobile Medusa Point. There is Zen 6-based Olympic Ridge (and/or Venice?) to fill that 2026 release window.
As mobile is a notable source of income for AMD I've been a bit worried about that "rebrand-only" strategy.
Reactions: Joe NYC
Joe NYC
4,221
5,825
3 products should be chiplet based: Ridge, Point, Halo. Which imply the same CCD but 3 different IODs.
If the 24 month cadence is maintained, then 2 out of 3 need to be released in Mid 2026. Desktop (Ridge) and laptop (Point). Otherwise, it would be a slip. These two are also likely the most profitable products to have for 2026 Christmas season.
I speculated in another thread that AMD might be using cost reduced N4C process node, for the refresh, which, IMO, would be optimal strategy, with assumption that very strong chiplet based products are coming in 2026.
I think your worry about "rebrand only" would be justified, if Zen 6 is not released in Mid 2026. It would open the door wide open to Intel, to stop and reverse market share gains.
IMO, if Zen 6 really were to be a 2027 product, AMD would be pressed to be releasing N3 based refresh of Zen 4 laptops. Absence of such a product, IMO, is indication of Zen 6 taking the baton from Zen 5 right on time in 2026.
yuri69
699
1,252
I hoped for a N3 refresh filling the 2026 void but... AMD does irrational things like wasting their resources with "XT" desktops CPUs.
I guess TSMC 2nm is the #1 staller
AMD was so afraid of 3nm they split the lineup of Zen 5. Suddenly with Zen 6 they are willingly about to wait for acceptable 2nm yields with the whole lineup.
fastandfurious6
984
1,092
it's a more complex decision making process than just this pattern comparison
zeitgeist, timings, competition, perf/w/thermals/die improvement ratios, estimated market reactions...
2nm is 100% worth the wait for medusa
adroc_thurston
8,572
11,307
It's not a yield thing.
TSMC is the king of raw and parametric yield anyhow.
HurleyBird
2,818
1,553
it was mid-24 because it was redefined like a zillion times.
That sounds extremely dysfunctional. The obviously un-optimal (in terms of area and performance) dual CCX config is what I'd expect if AMD made the decision to sacrifice quality on the alter of cadence, and not something I'd expect given the opposite. Or do you mean the Zen5 core rather than the layout?
APU_Fusion
1,696
2,496
AMD is hedging their bets with server/data center as main focus along with trying to capture ai market share. I imagine zen 6 focus is server first focus? Desktop is distant second thought.
