Page 798 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
fastandfurious6
984
1,092
Josh128
Banned
Oct 14, 2022
1,542
2,295
the 1% low increases are absolutely epic.
very important metric, stutters is the most annoying stuff even top specced pcs suffer from
but some graphs are messed, ratchet clank -20 fps 1% low?? also baldurs gate 3 loses -10%? lol
The good seems to outweigh the bad but overall really strange and mixed results. Gains for dual CCD Zen 5 dont necessarily apply to single CCD Zen 5, etc.
Reactions: marees
Josh128
Banned
Oct 14, 2022
1,542
2,295
If you can't bother to look up any of the day 1 reviews from the launch I can't help you brother.
Why would I? Those were not run with the 2H24 update, and everyone here has already discussed them ad nauseum. You said you had synthetic results post-update.
19,218
https://www.hardwareluxx.de/index.p...rsage-zen-5-mit-windows-11-24h2-getestet.html
Seems like they found a significant performance improvement with W11 24H2, though not quite like Hardware Unboxed.
That's a very enlightening review.
The results that caught my eye:
CP2077
Spiderman Miles Morales
Control
Anno 1800
Notice something in 9700X vs.9600X scores? What a difference extra 2C/4T makes in the minimum fps!
AMD really needs bigger CCDs. Who knows how much extra game smoothness they could get with 10 core CCD or even a 12 core CCD?
In2Photos
2,626
2,794
Show me where I said that? I said that HWUB performed the 24H2 tests strictly on gaming because that is where Zen4 to Zen5 showed the least amount of improvement.
CouncilorIrissa
788
2,855
CP2077
Control
Anno 1800
More cores in a CCD will cost you intra-CCD latency.
biostud
20,200
7,319
Also when Zen 5 goes down so does Zen 4, so no matter how "different" thes designs are they do seem to behave quite similar in gaming.
Josh128
Banned
Oct 14, 2022
1,542
2,295
I would say they tested games only because that is where they saw very little improvement from Zen4 to Zen5. That has been the focus since the release of Zen5, the lack of a performance uplift in gaming. There was improvement in synthetic benchmarks. And while they may be "easy and quick to run", the 40 gaming benchmarks he did run were not. Neither were any of the other 4-5 videos they have posted on the topic. If it's so easy why don't you run them?
In response to me saying they should have run GB6 to see if scores improved after the update, you posted above.
19,218
Conspiracy theory: coz game engines detect non-Intel CPU and then clobber them with extra unnecessary workload. Ryzens still coming out ahead is a true testament to AMD's superior engineering prowess!
In2Photos
2,626
2,794
Good grief man, read it again. It literally says Zen4 to Zen5 showed little to no improvement in gaming while synthetic benchmarks showed some improvement. How hard is that to comprehend? HWUB has been focused on the gaming aspect since the day 1 launch. It's pretty easy to understand.
Kaffeekenan
104
176
Speculation around Zen 5, the next-generation AMD architecture, suggests it will include EPYC Turin for data centers and Strix Point/Granite Ridge for Ryzen 9000 series processors. These upcoming chips are expected to deliver significant performance improvements, with EPYC Turin focusing on enhanced efficiency and scalability for servers, while Strix Point and Granite Ridge aim to boost performance and power efficiency for consumer desktops.
Thanks for the news, really good to know.
cebri1
373
405
So starting to see some outlets reporting smaller gains compared to HBU. Any other respected outlet has published new results?
Det0x
1,488
5,114
Josh128
Banned
Oct 14, 2022
1,542
2,295
We do not allow members to bait others by calling them ignorant. There are better ways to get your point across.
Good grief? Look at what you replied to and maybe read it before you respond. YOU RESPONDED TO A POST TALKING ABOUT RUNNING BENCHMARKS COMPARING ZEN 5 TO ITSELF PRE VS. POST 2H24, NOT ZEN 4 VS ZEN 5 UPLIFT. Im not responsible for deciphering that you were ignorantly referring to useless Zen 4 vs Zen 5 benchmarks that have zero relevance to what I was talking about in the post you responded to.
Its pretty easy to understand that you were and possibly still are completely oblivious to what you responded to and your ugly initial and continued responses are adding nothing to the conversation in this thread.
Reactions: In2Photos
Josh128
Banned
Oct 14, 2022
1,542
2,295
It appears that these updates are possibly fixing an issue present in some systems that is not present in other systems, even though they may be running an older version of Windows. So now you have multiple angles of what is causing the uplift and/or the slowdown (depending on your viewpoint). Whats unclear still is, what is the problem and what is the fix? So far:
1.) Windows 11 "Super" Admin - helps fps, but not wise to do
2.) Disable VBS - helps fps, but not wise to do.
3.)Windows 11 2H24 update: Helps fps for some systems, does nothing for others, some games may see regressions.
4.)Windows 11 2H23 branch prediction update KB5041587 : Still waiting on results?
Markfw
May 16, 2002
27,406
16,255
1.) Windows "Super" Admin - helps fps, but not wise to do
4.)Windows 11 2H23 branch prediction update: Still waiting on results?
speeds up games, but not other APPS, not systems is the way I read it. Exactly what we need. Games was the only weak area of speedup for Zen 5 that I know of.
Kepler_L2
1,090
4,705
Steve from HUB noted many months ago that he saw lower performance when upgrading from an older Zen generation to a newer one on the same OS install vs a fresh install.
My guess is that until this 24H2 update Windows was incorrectly applying security mitigations based on the original CPU your system was installed with, rather than your current CPU. So newer CPUs get more performance (due to HW-level security fixes) but results will vary depending on how the pre-24H2 OS was setup.
