Page 728 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
inf64
3,884
4,692
At first I was a bit disappointed but after checking more reviews (especially the ones with PBO and EXPO tuning) I think the Zen 5 is a nice gen on gen upgrade. It is not revolutionary (on desktop at least), but it brings ECO mode Ryzens to the regular SKU list. I think that 9950X will top all of the charts and will be a tough matchup for 285K ARL part.
X3D models, if they are allowed to boost better than 7800X3D, will likely be top dogs in gaming for years to come.
Hans Gruber
2,543
1,372
First Im not cherry picking anything, thats a (bad) assumption.
I literally said - "Thats the only thing I have had time to look at" and you still feel the need to insult.
Second 5% more performance for much less power consumption still supports my original statement of more performance for less power.
That power consumption gain is largely due to switching from N5 to N4P. What design or engineering performance improvements exist beyond the benefits of TSMC silicon?
Hans Gruber
2,543
1,372
With the experience they now have with V-Cache, I wonder if it might have been beneficial to launch X3D from the beginning. Combine some increased engineering resources with a 2 to 3 month delay in launch. Especially if they are able to make another cut in the max frequency gap.
I’m also very curious to see the the suite of benchmark results with 16 cores on a 256-bit bus (Halo.)
Based on the reviews, AMD may have to ditch the X3D v-cache and just make it the standard on all Zen 5 chips. They need to be able to push 3D v-cache to the maximum clock limits, identical to standard Zen 5 max clocks.
CouncilorIrissa
788
2,857
lol
You do realise that Apple chips exist? They use the same TSMC nodes as everyone else, but M2 on N5 is massively more efficient in 1T compared to Zen 4 on N5, as well as their ARM competition.
Reactions: Tlh97 and carancho
Hans Gruber
2,543
1,372
lol
You do realize Apple is a different architecture entirely? Nobody compares X86 architecture to an entirely different platform. I am comparing Zen 4 to Zen 5 efficiency. When Zen was originally released in 2017, they had it mapped out all the way to Zen 4. Everything beyond Zen 4 is uncharted territory for AMD.
TSMC's own numbers for performance uplift and efficiency (power consumption) are inline with the increased efficiency of N4P.
Abwx
12,034
4,996
lol
Better to look at actual numbers than doing such statements that are contradicted by measurements, 8700 pts in CB R23 at something like 20W, Z1 Extreme does 10700 pts at 20W and 8600 pts at 15W, so the latter is much more efficient, you just got the numbers backward.
To score the same as the Z1EX@20W the M2 would require roughly 32W.
Reactions: lightmanek
Markfw
May 16, 2002
27,408
16,257
If you want 1) efficiency and
2) avx-512 strong performance
You may buy the 9950x just for that. There are quite a few in the TEAM discord that want to replace all their 7950x's with 9950x's, just for those 2 reasons alone.
30-40% avx-512 improvement at -30-40% power reduction.
CouncilorIrissa
788
2,857
If there is no efficiency improvement coming from the architecture, then how come HX 370 pulls less power 3-4W less power in 1T while being within ~100MHz compared to Phoenix, despite N4P having no power savings compared to N4? Fairy dust?
FlameTail
4,384
2,762
HurleyBird
2,818
1,553
But they are
Sorry, but I find it extremely hard to believe you have a source with that level of information, who simultaneously didn't have enough information to steer you away from your 40% IPC insanity.
If it's anything like the last time, you are maybe at best privy to some small kernel of truth that you are inappropriately extrapolating from in order to reach an unlikely conclusion. And if that's the case, you'd think you would have learned better after Zen 5.
exquisitechar
727
1,033
If it's anything like the last time, you are maybe at best privy to some kernel of truth that you are inappropriately extrapolating from in order to reach an unlikely conclusion.
He's not the only one that's said that's what's on AMD's roadmap...I'm afraid it might be true.
Very much hoping it's not and I have to agree with the others that said that AMD may as well give up if they take that long.
poke01
4,888
6,235
Council was talking about 1T. The Z1 Extreme is a 8C/16T part and your comparing MT to a 4P+4E/8T M2. Of course Z1 is going to score higher in MT, not to mention the disadvantage of using R23 for ARM based products.
Anyway better in the meantime AMD, starts work on custom ARM silicon. Get a seperate team and kill Qualcomm push before Nvidia makes a move.
Hans Gruber
2,543
1,372
From your chart. N4P provides 22% better power efficiency over N5 and 11% performance uplift over N5. You are citing N4 vs N4P in your response which is not accurate. Zen 4 was based on N5 silicon. How AMD utilizes that performance boost is up to them. If they add a AGESA bios update with 65w/95w/105w/120w, we would see significant differences/improvements in performance for the 9700x. The 7700x was originally 105w TDP vs 65w for the 9700x.
Hans Gruber
2,543
1,372
It's better to say single thread rather than 1T. It will confuse people with 1t memory timings on DDR5 memory.
Hitman928
6,755
12,502
Phoenix was on N4, not N5.
HurleyBird
2,818
1,553
Not saying Zen 6 2027 is true, but if somehow it is, how much V-cache has been improved for the Zen 5 generation may have a large impact there, especially as things are becoming more bandwidth constrained.
Little reduction in clocks, 128MB stacks, or also stacking L2 could make a good difference. Although, given the extent to which the L3 area in Zen 5 has shrunk, those last two items are probably mutually exclusive.
CouncilorIrissa
788
2,857
Wrong. First, it provides either 22% power reduction OR 11% perf. Not at the same time. If you ever saw a single node comparison chart, you'd know that.
Wrong again, only desktop parts used N5. Phoenix and Hawk Point both use N4.
We don't have desktop parts at the moment with the same power limit running at the same clocks (we will with the release of 9950X, but even still, you have to account for the IOD power, making obtaining the data for the comparison very difficult). Hence, the comparison between 8940HS in Razer Blade 14 and HX 370 in the Zenbook -- neither hits a power limit under 1T workload, and both parts are monolithic with no savings coming from the node.
Your original claim was that all of power savings were explained by the node changes and not by architecture.
It is disproven by the graphs from the Computerbase's Strix Point review.
Abwx
12,034
4,996
That change nothing, from the 20W Z1EX MT score we can deduct that it use 2W per core for 1020 pts per core excluding SMT.
To score the same as the M2 1585 pts ST score a Z1 core would use about 5W, wich according to the power measurements is the power used by a single M2 core to score those 1585 pts.
So despite the lower frequency a M2 performance core is not more efficient than a Zen 4 core at same ST score, and it s undoubtly quite less efficient than a Zen 5 core in the same conditions.
Reactions: poke01 and Markfw
JM Popaleetus
375
47
heatware.com
Did AMD not address every complaint people had with Zen 4's launch? The MSRP is cheaper, they're more efficient, and they're faster. Stock vs stock, on average the 9700X is 5% faster using 35% less power than the 7700X in applications. As a cherry pick, der8auer's video has the 9700X using 44% less power than the 7700X in HWBot X265.
The only people that find this release disappointing are likely gamers, who should be waiting for the X3D chips anyway (or buying a discounted 7800X3D). Even then, from that video, the 9700X is still faster and more efficient:
  • Assassin's Creed: 2.19% faster using 9.67% less power.
  • Cyberpunk: 1.25% faster using 19.83% less power.
  • Counter Strike: 2.43% faster using 4% less power.
  • Valorant: 6.02% faster using 5.2% less power.
SFF community will love these chips, the 9950X should be a hit, and I eagerly await the 9800X3D (especially if the rumor it's completely unlocked is true).
