- Mar 3, 2017
- 1,779
- 6,798
- 136
what model do you have for that score ? And its an ES, right ?Silverbench P60424 Normal , X5194 Extreme
Cinebench 14242 Multicore singlepass
Instead of real 8-wide, they split it up into two 4-wides. I think they did it that way for SMT uplift so that the virtual core can boost some other branchy thread in parallel. An optimization could be that you deliberately write code that tries to stay within L2 cache and uses thread synchronization between the real and virtual core to eat its way through gobs of data.a CPU that excels on unoptimized, branchy code.
No. It's a release laptop. An ASUS OLED with 50 TOPS AI power.what model do you have for that score ? And its an ES, right ?
These scores are on battery with balanced profile?Silverbench P60424 Normal , X5194 Extreme
Cinebench 1939 Singecore singlepass
A comparison point:Silverbench P60424 Normal , X5194 Extreme
Ugh. That's as fast as a 7840U. Kraken will be a total dud with 4+4. Probably will be slightly slower in both CPU and GPU compared to Phoenix.Edit: 13679 with battery
Can you try Cinebench 2024?Silverbench P60424 Normal , X5194 Extreme
Should be noted that this is a *very* thin laptop, it's not designed to eke out every percent of performance.
Well it has dual fans and Asus says 28W. It could be a bit lower than that in that specific setting, but i dont believe it when its plugged in. 7840U has 13000 something at 32.5W short burst and 28W sustained in Thinkpad T14 G4 according to Notebookcheck.Should be noted this is a very thin laptop with what I suspect may be a quiet fan profile (I will look in the bios in a minute). This laptop is Macbook Air thin.
I agree with you Strix Point looks to be a minor improvement in CPU performance over HawkPoint.Well it has dual fans and Asus says 28W. It could be a bit lower than that in that specific setting, but i dont believe it when it’s plugged in. 7840U has 13000 something at 32.5W short burst and 28W sustained in Thinkpad T14 G4 according to Notebookcheck.
Most CPUs run at 100% in BIOS so naturally it would get hot.Ok, this thing runs hot (according to the pretty basic bios). Idling in the 80s. That's a bit odd.
Actually what you want is something like Dr. Cutress' 3DPM v1 with its cache thrashing. It constantly dumps the pipeline. It loves SMT.So if you wanted to purpose build an app to exaggerate the uplift of Zen5 over the competition, maybe branchy code could do that. While still being net slower than a comparable optimized program.
That’s not normal. I would return it. Might be shoddy thermal paste. Even Apple fanless M chips idle at 40C.Ok, this thing runs hot (according to the pretty basic bios). Idling in the 80s. That's a bit odd.
Yeah I edited my post. It’s all good.👍Igor is right, it will run hot in the bios now that I think about it. My desktop does that also. It's fine in Windows. I was certainly concerned for a minute though!
I think they would have advanced UI based BIOS only in their TUF or ROG line.I wish the Bios was better, it's very basic. No fan profiles or anything, even in advanced mode.
