Page 597 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Hail The Brain Slug
3,888
3,329
Just as a note for my 7950x run quoted above, i ran static 5850mhz for my submission (this is pretty much a ST benchmark)
And you have to use LibreCalc, its much faster than excel
Test date: 13.02.2023
CPU: 7950x
#Cores: 16Cores/32threads
CPU clock speed: 5850mhz
Total system memory: 32Gb DDR5
memory speed: 6600MT/s, 2200FCLK (same results @ 6400MT/s)
Libre office version: 7.5.0
32/64 bit: 64bit
time to sort (in seconds): 14s (first run)
time to sort (in seconds): 9s (second run)
My 7950x is stock/pbo disabled 6400C30 2133 with tuned timings
also 14s first run, 9s second run, then 8s on subsequent runs on whatever the latest libreoffice version is.
Scratch that, indexer decided it wanted to index the file while I was running it. Just did it again twice to be sure, it's 13s first run, 8s second run. My guess is newer libreoffice might be slightly faster than when you ran it?
paging @igor_kavinski did your mystery CPU run it on the latest librecalc?
Hans Gruber
2,534
1,363
Maybe this time.
You are quoting a source that cannot be trusted. The same source is citing Igor for a different Zen 5 chip and even he says his information is 2nd hand. 3D v-cache CPU's are a gimmick. It reminds me of B-Die memory. Is it better? Sure, but not the price premium that they are charging.
Josh128
1,505
2,256
New 10 core Strix GB run from yesterday, appears to be running at 3.2GHz. If correct, its making ~700 points / GHz. At this point I have no clue. Ive seen runs from 599 points/GHz to over 700, as in this one.
itsmydamnation
3,091
3,931
its a whole lot less of a gimmick then the peasant core spam their competition is doing
19,203
Yield of V$ improve quite a lot.
Problem is, AMD makes a lot more by placing a single cache die on a CPU than if they were to place two dies on the same CPU. By placing two dies on the same CPU, they would have to recover the extra margin direct from the customer which would make the CPU very expensive and too unattractive for mass market appeal.
What AMD needs is something like Intel Thread Director, a hardware solution that dynamically and in a fraction of a millisecond, schedules the workload on the appropriate die. They could make things easier for themselves by doing the "software hints" thing that Intel has done and then game developers or any other developers with cache hungry software can hint to the OS to run their instructions on the V-cache die only.
CakeMonster
1,644
821
The jumping between a cache CCD and a frequency CCD on dual CCD X3D CPU's is an issue with regards to prioritizing threads, and which AMD has a really clunky solution for that obviously is suboptimal, proven by the fact that people run software to assign specific games or apps to certain cores.
However, the inter-CCD communication is still an issue with all dual CCD CPU's, like both the 7950X and 7950X3D. How big is that latency penalty? I'm asking because we currently seem to be obsessed with how an X3D CPU with dual cache CCD's would perform. We only have the data from the vanilla and the 'uneven' X3D models though. I am a fan of simpler designs, and I enjoy the piece of mind of my 7950X not needing more thread scheduling logic, but I do realize that this CPU also has a small penalty when data moves between CCD's. A CPU with two X3D cache CCD's would also have this penalty. Can anyone make a qualified guess how much of an issue that would be compared to the 7950X and 7950X3D? Would it for instance be more of an issue in applications that benefit more from more cache? As much as I dislike the need for cache/frequency logic, I'm open to the idea that the inter-CCD communication could be a significant part of the problem, and that is not going away in the upcoming generation even if AMD (unlikely) offers dual cache CCD X3D CPU's.
Reactions: Joe NYC
Timmah!
1,572
935
7950x3D ended up costing pretty much the same as vanilla 7950x. Or the price-difference was like hundred bucks. Under those circumstances, Dont think that adding another v-cache die should somehow make such hypothetical CPU “very expensive”. If someone is gonna feel that way, they very likely already considered vanilla price to be that.
19,203
The supply of V-cache dies being a limiting factor, using two of them in a single CPU prevents the "birth" of another CPU.
Suppose AMD has 10 V-cache dies. They can make 10 X3D CPUs with that or they can choose to make 5 X3D CPUs. Which one nets them the most profit?
It's the same issue that prevented Intel from going all in with eDRAM. You can produce 100,000 CPUs a month in a fab without eDRAM but with eDRAM, the production rate drops to about 45,000 per month. Which one do you think the bean counters gonna approve of? They can't sell the eDRAM CPU for twice as much coz it doesn't offer twice as much value. So their only option was to drop it.
Reactions: Tlh97 and Mopetar
